2018+ LED Headlights Customized (Pics)
Discussion in 'Lighting' started by TundraCoast, Nov 23, 2018.
  1. Nov 23, 2018 at 2:31 PM
    TundraCoast
    TundraCoast [OP] Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    Finally got around to modifying/customizing my 18+ LED Headlights.
    Heres a description of what I did, I'm really happy with the finished product gives the Tundra a modern clean appearance.
    Main housing bezels, low beam surround trim, turn signal bowls: semi-gloss black
    Upper and Lower LED diffusers: frosted
    Klearz mfg side markers: frosted
    6000K white LED side marker bulbs
    LED turn signal bulbs amber
    Inner housing bezel stock (without lens)
    Inner housing bezel after (without lens)
    Inner housing bezel stock (with lens)
    Inner housing bezel after (with lens)
    Finished product back on truck
  2. Nov 23, 2018 at 2:33 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Nice work that looks tight!
  3. Nov 23, 2018 at 2:35 PM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    how'd you frost them? very smooth
    TundraCoast[OP] and Mountun Goat like this.
  4. Nov 23, 2018 at 2:57 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Would love to do something like that to mine. Do you have a step-by-step reference or narrative? Looks great and refreshing to see an OEM upgrade that isn’t hundreds of dollars
    Berdine likes this.
  5. Nov 23, 2018 at 2:59 PM
    TundraCoast
    Ian
    California
    1794 4x4
    Used Rust-oleum Frosted glass spray paint, cleaned the diffusers and clear side markers several times with denatured alcohol, went over the surface with super fine steel wool #0000 to knock-down any burs. With the frosted spray paint, thin coats to build up the look is the best way. I did about 20 light coats with short dry time in between coats.
  6. Nov 23, 2018 at 3:16 PM
    Mountains49
    Mountains49 New Member
    2018 White Platinum
    Very Nice! Strong work!
    TundraCoast[OP] likes this.
  7. Nov 23, 2018 at 3:16 PM
    TundraCoast
    Ian
    California
    1794 4x4
    There are a handful of tutorials on YouTube. Everyones experience is different so there is a learning curve. The 2014+ Tundra lights are known to be a pain to open due to the perma-seal that is used to mate the housing with the lens from the manufacturer. Oven @ 240 degrees for 20 min didn't work the first time for me. I ended up putting the lights back in the oven 2 more times each at 240 degrees for 9 min. As others, I used expanding pliers purchased on Amazon, flat head screw drivers and a lot of elbow grease. Purchased the Morimoto Butyl from Amazon to reseal the lights. Rust-oleum 2 step primer semi-gloss black spray paint, Rust-oleum Frosted glass spray paint for the LED diffusers and side markers.
    Inquiringone likes this.
  8. Nov 23, 2018 at 3:22 PM
    TundraCoast
    Ian
    California
    1794 4x4
  9. Nov 23, 2018 at 3:28 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    AlmightyCrash likes this.
  10. Nov 23, 2018 at 3:30 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Turned out awesome!
  11. Nov 23, 2018 at 3:38 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    Awesome! Fairly newbie here. Thanks for your time!!
  12. Nov 23, 2018 at 3:56 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Yep, those look great! Good job!
  13. Nov 23, 2018 at 4:03 PM
    Trpl7
    Trpl7 My best friend Tate
    Rob
    Washington
    Super White 07
    Partial level kit, Total chaos UCA, coach builder shackles, magnaflow ex. Tuner, SABM, complete poly bushing suspension.
    The orange side marker, is that a replacement and if not how do you get it clear or frosted and still usable?
  14. Nov 23, 2018 at 4:35 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Wow those look so good. Great job!!!! And I love your truck and that color matched pro grille
  15. Nov 23, 2018 at 4:55 PM
    I did the same thing to my SR5 HL, turned em Into PRO HL, real PITA to get apart
  16. Nov 23, 2018 at 4:56 PM
    Great work!
  17. Nov 23, 2018 at 5:01 PM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    That really does look sharp
  18. Nov 23, 2018 at 5:04 PM
    TundraCoast
    Ian
    California
    1794 4x4
    The orange side marker is OEM comes with the stock 18+ LED Headlights. A company by the name of Klearz makes an exact fit replacement side marker. I purchased the "clear" version they have "light smoke" and "dark smoke" as well. The side markers have 2 tabs that clips in place on the inner trim housing, easy switch out once the headlight assembly is opened. I then used Rust-oleum frosted glass paint to frost them.
  19. Nov 23, 2018 at 5:05 PM
    TundraCoast
    Ian
    California
    1794 4x4
    Pics of your conversion? Did you use the cold glue tools? A couple of guys said they didn't, I think they would have helped in my opinion.
  20. Nov 23, 2018 at 5:12 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Sharp. That type of mod is on my winter list.
  21. Nov 23, 2018 at 5:16 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Damn!! Nice work! Looks awesome!
  22. Nov 23, 2018 at 5:17 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    WELCOME
  23. Nov 23, 2018 at 5:20 PM
    booyaa
    booyaa New Member
    you have a 17.. u could have threw a projector in there while you were at it
  24. Nov 23, 2018 at 5:24 PM
    TundraCoast
    Ian
    California
    1794 4x4
    Tundra is a 2017 the headlights are 2018 Toyota LED
  25. Nov 23, 2018 at 5:27 PM
    booyaa
    booyaa New Member
    im aware of that.. HIDs and projectors have better output.. because you have a 17 u can use these 18s but still retro with a projector... i have an 18 i get an error.. im stuck
    Ostrich, Ryuu, Pudge and 2 others like this.
  26. Nov 23, 2018 at 5:33 PM
    I saw YouTube vids on how to do, put in over at 220° 10 min left was a PITA, only tools was flat head screwdriver n small pry bar, right baked bit longer n pulled apart easy, cleaning glue with flat head was PITA but also has a heater gun to clean out
  27. Nov 23, 2018 at 5:37 PM
  28. Nov 23, 2018 at 5:43 PM
    TundraCoast
    Ian
    California
    1794 4x4
    Aaah got it, wasn't clear on your first post. For the most part, I'm happy with the output of the 18+ LED headlights. I agree that there is room for improvement in light output. Looks like you have the Morimoto fog lights (I have the same) I also added the Rough Country LED bar in the valance so lighting is good for my needs.
    The color match on your truck and the mods to the LED's & fogs is awesome. Did you do the conversion? I was thinking of adding a light accent on the low beam "blade". What the story on that?
  29. Nov 23, 2018 at 6:01 PM
    Pudge
    CT
    I was hoping youd finally post these publicly here. Very well done, theres some serious skills around this forum. so many good ideas
    booyaa[QUOTED] likes this.
  30. Nov 23, 2018 at 6:08 PM
    booyaa
    booyaa New Member
    haha ty my friend
    Only reason I am posting is to let others know if you have an 18+ and you try and retro you will get a huge error HEADLIGHT MALFUNCTION PLEASE SEE DEALER. These 18 housings have drivers in them that talk back to the ECU. I tried resistors, canbus, and even tried wiring the OEM drivers in WITH my retro - no go.
    So you CAN retro these housings pre 18
    18 and UP as of now LED module only
    carry on gentlemen
    lol
