Unknown device in truck.
Discussion in 'General Tundra Discussion' started by jlaval, Nov 17, 2018.
  1. Nov 17, 2018 at 6:04 PM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    Yeah I would unplug it ASAP, since each module is registered to one owner, if is still connected to a remote starter you can get a new mycarcontrols unit and register it under your name.
  2. Nov 17, 2018 at 6:09 PM
    Dmas
    Dmas New Member
    FTL, FL
    Forgot to add, you can just unplug it from the harness, it would not cause any issues with the truck.
    Leo's first, TomC843 and ColoradoTJ like this.
  3. Nov 17, 2018 at 6:53 PM
    Md211
    Md211 New Member
    No offense but everyone is wrong it is a used vehicle and that is a GPS lock out so they can disable the vehicle when you don't make your vehicle payment I'm not sure how you bought the truck and if it was installed by the dealer that you bought it from but you have to be aware of that and sign a paper saying it's there or it's against the law but you cannot remove it if you signed a paper saying it's there and you finance a vehicle through them
  4. Nov 17, 2018 at 7:45 PM
    jlaval
    jlaval [OP] New Member
    Jeff
    2015 Toyota Tundra Crew TSS 5.7
    Sorry folks for the late comment. Ive been gone all day since its my son's 13th Birthday. Im going to look at it closer tomorrow and trace where the end of the larger cable connects to. Then Im going to remove it. Here is another photo of the side of the unit. It does have a red led on the side that blinks red.
    As for the dealer knowing about it. I dont think so...never signed a piece of paper about it and was never informed of such a device.
    Also, the truck was never a fleet vehicle. When I purchased the truck it had only 35k miles on it for a 2015.
  5. Nov 17, 2018 at 7:48 PM
    jlaval
    Jeff
    The ride in question.
  6. Nov 17, 2018 at 8:03 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Nice truck!!
    Pinay likes this.
  7. Nov 17, 2018 at 8:15 PM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Md211 is right. The previous owner most likely had a title loan against the truck. If the previous owner missed a payment or skipped town, the financier could track down their collateral and repo. I ran into this exact same scenario with my 2010 DC. Bought from a private party, all was good at time of purchase. As I wired up a new head unit a year later, I came across that exact same device. I called the previous owner who gave me the run down, said the loan company (poorly) installed 3 transponders total but had no idea where. I dug deeper and found them all (I hope).
    1 behind the head unit
    1 behind the driver kick panel
    1 behind the overhead sunglass cubby
    Good luck and congrats on the rad truck
  8. Nov 17, 2018 at 10:00 PM
    Socaldan
    Socaldan New Member
    It is a gps tracker. Some finance companies will not release funding until the tracker is installed and active. They do this in case you stop paying and have pulled the fuse for the factory on star or other system depending on make of vehicle. Usually these are sub prime lenders
    Leo's first likes this.
  9. Nov 17, 2018 at 10:45 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The numbers do come up as a GPS tracker. You should definitely get it removed and search for others.
    Remove it correctly to avoid the truck from not running.
    Taking to dealership might be the way to go.
  10. Nov 17, 2018 at 11:13 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    ^This is correct, depending on your financial institution some banks require to install a GPS tracker and is removed only after you make the very last payment on your loan.
    My friend bought a brand new GMC truck a few time ago, when he did the last payment the bank send the title and a letter to make an appointment at the dealership to get the tracking device removed from vehicle, WTF??? :eek2:. They install this devices to track the cars for a easy repo is something goes wrong. But they don’t use it for other purposes only if a repo is required.
    You better ask your bank before removing this device from your truck to avoid any trouble with them.
    This is the complete info for the device including user manual, installation guide, frequency etc
    https://fccid.io/2AEB4ALT01
  11. Nov 18, 2018 at 6:06 AM
    Dmas
    Dmas New Member
    FTL, FL
    I stand by my first post...yes, it is a GPS tracker but also much more than that, connected to a remote start it will let you start/shutdown/lock/unlock and track your vehicle from anywhere in the world, it works with cell towers and wifi.
    I know because I have the same unit installed on my vehicle, Installed by me, and it works great, I was able to start my vehicle from overseas 5k miles away. Also, the fact that it only has a red blinking light tells me that it's getting power but is not active, an active one like mine would have a solid red and solid green light.
    The trackers you guys are talking about are more simple cheaper devices that only work as a GPS tracker, the module on the OP pics is an almost $200 device, it looks to me like something that it was installed by the previous owner and probable did not take it off.
    I could be wrong but it all comes down to what is it connected to.
    TxLock21 and jewsNbrews like this.
  12. Nov 18, 2018 at 7:29 AM
    jlaval
    Jeff
    To clearify some comments. The device was never mentioned at the dealer. They didn't know about it. The previous owner must of installed it or had it installed.
    I have excellent credit and was financed through my own choice. So there wasn't a way this device was installed ahead of time by "said" financial company.
    Dmas, since you installed it on your own..where does the other end connect too?
    I'm going to have to look at it later. This morning I'm going on a charity motorcycle ride. I'll update once I'm back and get to looking at the device again. Thanks all for your input.
  13. Nov 18, 2018 at 8:06 AM
    Dmas
    Dmas New Member
    FTL, FL
    If is only connected to power it means they took out the remote start unit, but it should be another box connected to it and that should be the remote start unit
    Toyotoholic and NewImprovedRon like this.
  14. Nov 19, 2018 at 11:19 AM
    jlaval
    Jeff
    Well its out. Thanks all for the replies on this matter. Truck starts fine and no problems to report.
    MotoTundra and OR18TRD like this.
  15. Nov 19, 2018 at 11:24 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Id get rid of that shit asap
    jlaval[OP] and 15whtrd like this.
  16. Nov 19, 2018 at 11:42 AM
    15whtrd
    15whtrd Mr. Blonde
  17. Nov 19, 2018 at 11:48 AM
    HornFrog
    HornFrog Go Frogs!
    Fort Worth
    2016 MGM SR5 4x4 Crewmax
    TC UCA's, King 2.5, Ex-Pelf Bumpers and skids, TRD Pro Grill, 2018 Lights, BD Fogs, FRAC
    Could it have been connected to your key fob, for remote start? Just curious if you checked or not.
  18. Nov 19, 2018 at 5:55 PM
    jlaval
    Jeff
    I dont have a key fob with remote start (or) I should say...at least it doesnt start by the FOB on the third press and hold.
  19. Nov 19, 2018 at 6:03 PM
    Heatonrx
    Heatonrx New Member
    Sure looks like the Mycar module I added to my car starter like someone else on here said.
  20. Nov 19, 2018 at 6:19 PM
    #50
    jlaval
    Jeff
    I would agree.
  21. Nov 19, 2018 at 7:09 PM
    #51
    MotoTundra
    MotoTundra The Ocho
    Don
    Well I learned a bit about GPS units and whatnot...
    Glad you removed it and all is still well OP.
  22. Oct 31, 2022 at 7:03 AM
    #52
    KQtundra
    KQtundra New Member
    2018Tundra
    I purchased my Tundra from a Ken Garff here in Salt Lake. One of there "fees" they try and get you with when buying a used vehicle from them is an included GPS tracker with a monitoring app and 5 year subscription for $1200! I was able to talk the sale guy out of this service, but apparently they left the device installed. When I was installing a remote starter yesterday I came upon this exact device behind my driver side kick panel.
  23. Oct 31, 2022 at 8:16 AM
    #53
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Wont do any good, with all the apple tags in vehicle, have fun ripping it apart to find them all....You won't be trick or treating tonight. Happy halloween.
  24. Oct 31, 2022 at 9:20 AM
    #54
    4 year dead thread brought to life
