Building My Home
Discussion in 'Home Improvement' started by mdavis, May 19, 2016.
  1. Jul 19, 2016 at 12:15 PM
    mdavis
    mdavis [OP] I need a beer.
    Michael
    Rock Hill, SC
    Been plagued with permit issues but finally going again. There is a creek in the back of the property (more than 250' back in the tree line) that has caused way more trouble than its worth. I had to end up getting a storm water permit which between paying the civil engineer and all the fees it cost me $1113 and about 5 weeks of time. All to promise I wont let my dirt end up in the creek and if it does end up in the creek, I have to pay to remove it. :crazy: Anyway, Footers are being dug in the morning and everything is good. Hoping to be in by Thanksgiving!
    GODZILLA, MotoTundra, Law323 and 3 others like this.
  2. Jul 19, 2016 at 1:18 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Next they will want you to install a bulkhead. Was wondering what was going on. Hopefully no loopholes or bs to deal with the rest of the way.
    GODZILLA and mdavis[OP] like this.
  3. Jul 19, 2016 at 4:08 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    We looked into this a while back. I think the current consensus is, it is cheaper to buy than to build. This did not use to be the case back during the real estate boom. However, while house prices plummeted from their all time high, labor and material costs did not keep the same downward pace. Of course you have to factor in the value to you of having it built exactly as you want it, vs. someone else's idea.
    My next door neighbor who built recently on his property described it like this; "Figure out what you think it will cost and double it"
    trayday[QUOTED] and mdavis[OP] like this.
  4. Jul 19, 2016 at 4:27 PM
    mudsweatngearz
    mudsweatngearz New Member
    Grant
    Arizona
    2016 Limited TRD CM 2016, Tacoma TRD Sport, 2005 Tacoma TRD Sport
    Window tint
    I built a new house in 2012. When we moved it became our home.
    mdavis[OP] likes this.
  5. Jul 19, 2016 at 7:28 PM
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    If you have access to a local farmer, you could place a row of small straw/ hay bales to control run off.
  6. Jul 19, 2016 at 7:54 PM
    Or move to Alaska. Outside of Anchorage/Eagle River north...........zero zoning issues. ZERO (Kenai ,south, is a different story)
    NewImprovedRon likes this.
  7. Jul 19, 2016 at 8:08 PM
    frogger
    frogger just boost it
    Stephen
    Louisville Ky
    2008 S/C Tim Mica SR5 5.7L DC 4X4
    too much to list
    Good luck on the house
  8. Jul 19, 2016 at 9:09 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Looking great Mike!!! So jealous!! Id love a plot like that! Maybe in a few years!
  9. Jul 19, 2016 at 9:12 PM
    I'm looking forward to see the house when your are done. (When is the house warming party by the way? How many Tundras can you fit in your new drive way?????) :bananadance::bananadance::bananadance:
  10. Jul 19, 2016 at 9:42 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Pro Comp Lift, towing mirrors, Fuel rims, Toyo A/T, Nav, Viper remote start
    I had one built in 2013, it was a residential plot and I got to choose a model and go through a design center. It was fun but what a headache. I was glad someone else did the build because that is way to consuming.
  11. Jul 20, 2016 at 4:16 AM
    mdavis
    Michael
    Rock Hill, SC
    The inspector actually allowed me to use the mulch from the trees instead of a silt fence. Saved me about $1500. I took the tractor and dumped buckets all the way around the cut.
  12. Jul 20, 2016 at 4:17 AM
    mdavis
    Michael
    Rock Hill, SC
    Plenty...
    GODZILLA, Law323, 2cID and 1 other person like this.
  13. Jul 20, 2016 at 3:49 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    We built what was to be our retirement home in 2010, 1 floor, 3 bedroom,well insulated, 1500 sq ft,with attached oversize 2 bay garage. I worked swing shift in a paper mill, so was not interested in building a house in my spare time, cause I didnt have much spare time. So found a builder I trusted, cause I had seen several homes he had built in the past, and knew the owners, who were pleased with the build, and turned it over to him, he took care of everything from the site work (clearing the property)to putting in the blacktop driveway, and seeding the lawn once the house was finished. All in 45 days no less! This is the 3rd home my wife and I have owned, and the 2nd home we have built in the last 38 years and it was the easiest, and most exciting house we have done!
  14. Jul 20, 2016 at 4:47 PM
    mdavis
    Michael
    Rock Hill, SC
    Here's the driveway. It's about 200 feet from the road to the front of the house.
    Found this guy hanging in the driveway tonight. About a 3 foot black snake.
  15. Jul 20, 2016 at 5:02 PM
    mdavis
    Michael
    Rock Hill, SC
    Footers are dug. A few really deep spots but overall not too bad. Just need some rebar and we're ready for concrete.
  16. Jul 20, 2016 at 5:14 PM
    rons23
    Ron
    Kill Devil Hills
    Keep him around, good for rats and mice
    GODZILLA and Mike like this.
  17. Jul 20, 2016 at 5:18 PM
    mdavis
    Michael
    Rock Hill, SC
    Oh yeah, he climbed right up a tree.
  18. Jul 20, 2016 at 5:21 PM
    rons23
    Ron
    Kill Devil Hills
    Looks like you got a new friend Mike, haha
    mdavis[QUOTED][OP] likes this.
  19. Jul 21, 2016 at 5:50 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I'm going to have to subscribe to this thread - wife & I are about to do the same thing. We got so tired of looking at houses and found nothing that justified doubling up mortgage debt that we just said screw it, lets build something that fits for us. Kudos to you for that lot though... The problem i find is that when looking at lots, especially in summer, you pull up to the side of the road and just look at a wall of trees & shrubs. Really have to stretch your imagination to envision what it will look like after all the work you're putting in!
    But thank you for the pics - your lot & clearing look great - inspiration that i shouldn't give up!
  20. Jul 21, 2016 at 6:16 AM
    #50
    mdavis
    Michael
    Rock Hill, SC
    Good luck to you in your build! If I went back and did it again, I would go ahead and pay the builder to do everything (clearing, permits, etc.). But me being the person I am, I was trying to save a little money and do some things myself. Told the builder to quote the house from going in and digging footers. All site prep was on me.
    Funny thing was, I thought I could go in with chainsaws, a few buddies and a wood chipper and clear the lot myself. Well after 2 days and a body that couldn't take anymore, I was 1/32 done. o_O Called a buddy and ended up paying $3500 to clear and grade the lot. Best damn $3500 I ever spent! But now that all the permits are in hand and the site is prepped, I have handed it over to the builder and so far I am liking how fast he has jumped on things. I think we'll get along just fine.
    In all seriousness though, it has been a struggle so far. There hasn't been anything that has been easy but you just have to keep your vision in your head and know it will all be worth it in the end. Take it day by day and don't let it get between you and your wife. If you do build, post up a thread here, I'd love to see it.
  21. Jul 21, 2016 at 3:51 PM
    #51
    mdavis
    Michael
    Rock Hill, SC
    Got the pier footers poured today and some rebar was put around the perimeter. Perimeter gets poured Monday.
  22. Jul 21, 2016 at 4:29 PM
    #52
    mdavis
    Michael
    Rock Hill, SC
    Haha! Your wife and I see eye to eye on the tide.
    SouthBoundSteve likes this.
  23. Jul 21, 2016 at 5:17 PM
    #53
    mdavis
    Michael
    Rock Hill, SC
    Clemson-Auburn!!!!! Can't wait!
  24. Jul 22, 2016 at 7:21 AM
    #54
    mdavis
    Michael
    Rock Hill, SC
    Took my buddies drone out to the lot this morning.
  25. Jul 22, 2016 at 7:40 AM
    #55
    Wow!!!!!!!
    Got your own little slice of heaven. Good work on the house building. Making some good progress.
  26. Jul 22, 2016 at 8:03 AM
    #56
    mdavis
    Michael
    Rock Hill, SC
    Absolutely! I even have a time lapse camera mounted on a tree facing the house. It takes a picture every 10 minutes and at the end of construction, will put it all in a continues video. Which of course I'll post here. ;)
    GODZILLA, khunk, Law323 and 3 others like this.
  27. Jul 22, 2016 at 2:29 PM
    #57
    rons23
    Ron
    Kill Devil Hills
    Cool stuff Mike
  28. Jul 25, 2016 at 12:55 PM
    #58
    mdavis
    Michael
    Rock Hill, SC
    Perimeter footers were poured this morning and the sand was dropped off for the mortar. 36 yards of concrete total for the footers.
  29. Jul 25, 2016 at 1:18 PM
    #59
    GayFish
    GayFish Member
    2016 Super White SR5 CM 5.7L 4X4
    Following.
  30. Aug 9, 2016 at 12:08 PM
    #60
    mdavis
    Michael
    Rock Hill, SC
    Fun to see it finally going up. I can go over there and stare for hours. Foundation getting done. Should be complete by weeks end.
