Size matters....1.9” or 2.5” ?
Discussion in 'Suspension' started by Silv333, Oct 25, 2018.
Bilstein 6112’s, which setting for the front?
  1. 1.9”
    43.4%
  2. 2.5”
    56.6%
  1. Oct 25, 2018 at 5:02 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Load up stuff in the bed or hookup a trailer to it. Cab weight doesn’t cause the truck to squat much.
  2. Oct 25, 2018 at 5:22 PM
    Vizsla
    Vizsla pretend2send
    My truck above had 295s and required some plastic trimming. I had my front tires shoved forward to keep the mud flaps, so I had to trim the front liner, it would not push in far enough for no rub.
    BlueBottle likes this.
  3. Oct 25, 2018 at 5:50 PM
    ctraut5
    ctraut5 New Member
    Germantown,TN
    2019 Black TRD Pro
    I’d stay at 1.9”. Less preload equals a smoother ride.
    OR18TRD and BlueBottle like this.
  4. Oct 25, 2018 at 6:05 PM
    Silv333
    Silv333 [OP] Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Example; I went to the beach and put luggage, beach chairs and a cooler in the bed under my cover. Would it be nose high with that type of weight?
  5. Oct 25, 2018 at 7:00 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    No that is nothing.
    Silv333[QUOTED][OP] likes this.
  6. Oct 25, 2018 at 7:20 PM
    Silv333
    NJ-NC-MD-NC
    Ok cool
  7. Nov 18, 2018 at 3:55 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Where do you measure from to find out the rake?
  8. Nov 18, 2018 at 4:19 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Thanks. Got the math part, just didn’t know if the measuring point was different than the fender as I was thinking. Basically making sure it was still the obvious.
    OR18TRD[QUOTED] likes this.
