Air Conditioning Vent Flow
Discussion in 'General Tundra Discussion' started by OHP, Nov 15, 2018.
  1. Nov 15, 2018 at 8:24 PM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    2018 Tundra TRD Sport
    Current Mods: JL Audio Stereo System, Truxedo Bed Cover, Console Organizer, Tint, Matt Gekko bed lights, tailgate auto lock, black badges Upcoming Mods: Level, Leather, Remote Start
    Strange question. In my 18 CM Sport with manual AC it doesn't matter which position I choose for the air flow direction, (floor, vents, defrost) it always blows air out of the vents. It does blow air to the floor or defrost if those positions are chosen, but always while continuing to blow through the dash vents. Is this normal Tundra/Toyota operation or do I have an issue?
  2. Nov 15, 2018 at 8:28 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Hit the recirc button and it will stop...I think...
    OR18TRD and Pudge like this.
  3. Nov 15, 2018 at 9:11 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    This^
  4. Nov 15, 2018 at 10:16 PM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    I tried the recirc button this evening and it didn't light up or make a difference. The system was on full heat at the time. I'll give that a try again in the morning and see if it makes a difference.
    Thanks
  5. Nov 15, 2018 at 11:29 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Recirc doesn't work if set to defrost FYI
  6. Nov 16, 2018 at 8:41 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    Okay, this morning when I got in the Tundra to go to work I tried the recirc solution. This didn't change anything. With the system on full heat and set to blow out of the floor vents, it's still blowing air out of the dash vents. Can anyone confirm whether or not their late model truck does this?
    Thanks
  7. Nov 16, 2018 at 8:45 AM
    15whtrd
    15whtrd Mr. Blonde
    Is the light turning on now?
  8. Nov 16, 2018 at 8:49 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    Yes, until the knob is turned the first notch toward defrost, which makes sense.
    15whtrd[QUOTED] likes this.
  9. Nov 16, 2018 at 8:52 AM
    15whtrd
    15whtrd Mr. Blonde
    My truck always seems to blow a little bit through the vents when the other positions are chosen. It’s not a lot but it’s enough to notice. My previous Chevy used to do the same things as well as my old Dodge. I want to say it’s normal depending on how much is still flowing. I don’t know why Carmen you facture‘s have not figured this out. I don’t want the air blowing in my eyeballs lmao!
    So I just direct it away from me and have learned to deal with it.
  10. Nov 16, 2018 at 9:03 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    I just came out of driving an F250 for the last several years and I don't remember it doing this. Maybe it is a normal Tundra thing. After all it is pretty easy to just reach up and shut the vent.
    15whtrd likes this.
