2001 Toyota Tundra
Discussion in 'General Tundra Discussion' started by James H, Nov 15, 2018.
  1. Nov 15, 2018 at 6:47 PM
    James H
    James H [OP] New Member
    I have a 2001 Toyota Tundra V8, cylinder 5 just keeps misfired. I tried everything by replacing the coil and change the spark plugs. Nothing works! Looking for ideas
  2. Nov 15, 2018 at 6:48 PM
    Spark plug wire?
  3. Nov 15, 2018 at 6:49 PM
    James H
    Coils
  4. Nov 15, 2018 at 6:49 PM
    James H
    I change the spark plugs and the coil
  5. Nov 15, 2018 at 6:50 PM
    How old are the wires?
  6. Nov 15, 2018 at 6:51 PM
    James H
    No wires
  7. Nov 15, 2018 at 6:52 PM
    James H
    Where the wires are located?
  8. Nov 15, 2018 at 6:57 PM
    I have a '97 T100 3.4 V6 withe 3 coils on one side with spark plug wires connected to coils that run to other 3 spark plugs, you shud have same????
  9. Nov 15, 2018 at 7:01 PM
    Or the wire that connects to that coil
  10. Nov 15, 2018 at 7:02 PM
    James H
    Change the wires
  11. Nov 15, 2018 at 7:05 PM
    James H
    Were you having the problems?
  12. Nov 15, 2018 at 7:07 PM
    No, but I'm trying to narrow down if it's not coil (new) and plug too, only thing left would be wire, if they old or pinched, cut, frayed or something in that chamber (debris)
    831Tun likes this.
  13. Nov 15, 2018 at 7:39 PM
    James H
    Are they expensive?
  14. Nov 15, 2018 at 7:46 PM
    @Roman parts guy if you want OEM parts
    Roman and T-Rex266 like this.
  15. Nov 16, 2018 at 4:52 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Slim chance, but the new coil could be defective (cheap China one
  16. Nov 16, 2018 at 7:14 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    The 2UZ uses individual coils for each cylinder, so the only wires running to it would be from the engine wire harness. You can visually check those out and make sure the connection is good.
