Largest tire with 2" front level?
Discussion in 'Suspension' started by bigoltater, Jun 29, 2016.
  1. Jun 29, 2016 at 10:46 PM
    bigoltater
    bigoltater [OP] New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    Does anyone know the largest tire I can go with just a 2 inch front level? I don't want the jacked up look, I would like to keep it lower but stuff the largest tire I can. I'm going 18×9 +20 or +18, thanks
  2. Jun 29, 2016 at 11:37 PM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    There are members with 295/70/18 on Pro Tundras which has 2 inch lift in the front. Personally I think that's too much rubber for 2 inch. I have 295/70/18 on 3 & 1/2 inch OME lift and feel the tire is on the large side. For 2 inch, I would either go with 275/70/18 or 295/65/18.
    bigoltater[OP] likes this.
  3. Jun 30, 2016 at 7:52 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I've seen people with 295/70r18 on 2 inch lifts. To me, that just looks entirely too stuffed in. I have 275/70r18 on my 3/1 and it looks great (may jump to 295/70 when these wear out though) like @chphilo said, I'd go with a 275/70 or 295/65. Still gives you that solid built look without it having that "jacked up" look and you won't have to do any trimming. Win win
  4. Jun 30, 2016 at 10:46 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Thanks for the info fellas, I'll probably just do a 3/1 and call it good.
  5. Jul 1, 2016 at 3:51 AM
    chphilo
    Western PA
    Have you considered Bilstein 5100 instead of spacers? Not that much more $$ and a whole lot safer, especially if you go off road. Personally, I would not go with spacers for anything more than 2 inches in the front.
    tonynw318 likes this.
  6. Jul 1, 2016 at 6:00 AM
    Agreed. My lift is pretty much the same as yours. 305's would definitely be a tight squeeze. My new 295's seem to fit well. I had it off hi-way last weekend and didn't get any rubbing. I still want to get the cab mount chop done. It's one thing to have no rubbing driving around on the highway, but you definitely want to have no rubbing when hitting the trail.
  7. Jul 1, 2016 at 6:29 AM
    DLack33
    DLack33 New Member
    Dylan
    2010 Slate Tundra SR5
    I have 285/55/20 and love them. Definitely a little more room in there, but that size looks good imo.
  8. Jul 1, 2016 at 8:25 AM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Would you mind posting a pic when you get a chance?
  9. Jul 1, 2016 at 9:59 AM
    jfrd30
    jfrd30 Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
    Here you go Tater. 285/55/20's on my '13
  10. Jul 1, 2016 at 10:05 AM
    TheBeast
    TheBeast The Beach
    33x12.5x18 with just pro comp leveling kit on mine. I had 305/60/18 before.
  11. Jul 3, 2016 at 7:42 PM
    DLack33
    DLack33 New Member
    Dylan
    Tough country 2" leveling kit. I did it myself and forgot some bolts that went on top of the main metal part. So ended up being about an inch and a half and not quite level. But still looks good, I'll fix it when I get the time. Not hurting anything.
    Also have not put in differential spacers that return axel angles to original angles. I think I know where to put them, after looking at it only one real sensible place to. But the picture in the directions looks much more different, need to do some research and make sure I do that ride. Still, not a big deal and not hurting anything.
  12. Jul 3, 2016 at 9:11 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Looks good, thanks for the info and pic
  13. Jul 19, 2016 at 1:36 PM
    MookTastic
    MookTastic Because I was inverted!
    Trice
    Rapid City, SD
    2013 5.7L White D/C TSS Offroad Icon Stage 8
    Icon Stage 8 AlphaRex Headlights
    What's a good price for a pair of 5100s front shocks of i wanted to level?
  14. Jul 19, 2016 at 2:15 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Around $300 for front, and $150+ for rear. Just a guesstimate. Or you could spring for the Bilstein 6112's for around $650-700 depending on who you get them from. There are venders on the site you should check out. Toytec and Wheelers Off-road. Hope this helps
  15. Jul 19, 2016 at 2:23 PM
    MookTastic
    Trice
    Rapid City, SD
    Thanks for the info!
