ICON 17" Six Speed Wheels Picture thread :)
Discussion in 'Wheels & Tires' started by TheBeast, May 17, 2017.
  1. Sep 20, 2018 at 10:51 PM
    #271
    Tundrago
    Tundrago New Member
    Nashville area
    2016 SR5 upgrade. TRD
    this thread just derailed what I had planned.
  2. Sep 21, 2018 at 12:40 AM
    #272
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
  3. Sep 28, 2018 at 11:14 PM
    #273
    kingkabong
    kingkabong New Member
    Eric
    Parker, CO
    2016 Tundra DC
    I'm still a few mods from any real off-roading, so I haven't solved this yet.
  4. Sep 29, 2018 at 10:59 PM
    #274
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
    I'm running a full size on a six speed, just wait for a big sale like Black Friday, etc and pick up what you need.
    805ebr[QUOTED] likes this.
  5. Oct 27, 2018 at 9:06 PM
    #275
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Hey man, saw you went with 35-12.5-17's. What all did you do to be able to fit those tires? I'm looking at going with 17" Icon rims and 35-12.50's.
    Tacotundra[QUOTED] likes this.
  6. Oct 29, 2018 at 3:48 AM
    #276
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    I had a cab mount chop, removed mud flaps and trimmed the the front bumper ends and the liner there in the front. With the icon wheels offset it worked perfect on stock suspension. No rubbing even offroad on stock suspension. Good luck
  7. Nov 2, 2018 at 7:45 AM
    #277
    TheGibbster
    TheGibbster Kumite Express leaves in five minutes
    SF Bay
    Hey guys, I'm going to be ordering up some rebounds.
    Is the general consensus that a 2.5" lift up front will allow a 315/70r17 to fit without cmc? I have no problem adjusting the liner or swapping the factory skid, I just don't want to grind away on a brand new truck.
    I'm also wondering if I might have more luck fitting a small 35 inch tire like the Bfg KM3, which is pretty much the same height as a 315/70, but it's a hair skinnier at 12.5" wide instead of 12.7"?
  8. Nov 3, 2018 at 8:38 PM
    #278
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    :popcorn:
  9. Nov 5, 2018 at 2:22 PM
    #279
    jzsquared
    jzsquared New Member
    I just installed a set in machine finish I wanted the contrast wrapped in 33” KO2 for now
    Berdine, equin, TheBeast[OP] and 2 others like this.
  10. Nov 5, 2018 at 8:20 PM
    #280
    Inquiringone
    Ter
    NorCal 408
    Get used to it, as it's happened to me frequently on here. I've learned to just breath and reflect.
    Remember don't listen to us, to much and guard your wallet... I feel like a kid in a candy store allot when I come and look at all the bad ass trucks that this site has. Good luck bud. :D
  11. Nov 14, 2018 at 10:44 AM
    #281
    Tundrago
    Tundrago New Member
    Nashville area
    22E604BA-0C97-4D98-A4DC-8E819C3F6499.jpg Well it was a good change of plans, i love everything about the new wheels and tires without a huge lift.
    Luckydog, airgunner, pdiddy and 6 others like this.
  12. Nov 14, 2018 at 10:46 AM
    #282
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    What size tires did you go with?
  13. Nov 14, 2018 at 10:48 AM
    #283
    Tundrago
    Tundrago New Member
    Nashville area
    295/70-R17
  14. Nov 14, 2018 at 11:03 AM
    #284
    InfernoPRO
    Scott
    Sacramento
    I am thinking of the same setup but with 315/70r17. Hoping for no rub :fingerscrossed:
    dcsleeper408 likes this.
  15. Nov 14, 2018 at 11:05 AM
    #285
    TheBeast
    TheBeast [OP] The Beach
    looks good
  16. Nov 14, 2018 at 11:26 AM
    #286
    Tundrago
    Tundrago New Member
    Nashville area
    I had to take off the front liner and the front air dam aka mudflap. I could have heated the front liner or moved the bumper but its just as easy to remove the liner.
  17. Nov 17, 2018 at 5:01 PM
    #287
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    yeah, want to know an answer to this as well. If this works, then i'm about to find a credit card my wife forgot about.
    Silv333 and TheGibbster[QUOTED] like this.
  18. Nov 17, 2018 at 6:03 PM
    #288
    TheGibbster
    SF Bay
    Agreed :spending:
    Silv333 likes this.
  19. Nov 17, 2018 at 6:09 PM
    #289
    TheBeast
    0% APR for 18 months are the best CC :spending:
    Jengel451 likes this.
  20. Nov 18, 2018 at 8:02 PM
    #290
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Looks good, did you lift/level at all?
  21. Nov 18, 2018 at 8:05 PM
    #291
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Yeah I want to know the answer to this magical question too. The research I've done here shows you can do it without needing the CMC or new UCA's.
  22. Nov 18, 2018 at 10:12 PM
    #292
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  23. Nov 18, 2018 at 10:24 PM
    #293
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    What's the setup?
  24. Nov 18, 2018 at 10:41 PM
    #294
    csuviper
    Broomfield, CO
    3/1 Toytec Radflo 2.5” front Coilovers and rear Toytec Boss 2.0 with resi with 1” block. 35x12.5R17 Nitto Ridge Grapplers
    Pjholt, Big J, equin and 2 others like this.
  25. Jan 7, 2019 at 2:00 PM
    #295
    InfernoPRO
    Scott
    Sacramento
    Anyone running the @Coachbuilder1 steering kit (tie rods) with their Icons? I heard a rumor that with the +25 offset they will rub on the beefier tie rods. Looking for someone to confirm they have tried this combo.
  26. Jan 13, 2019 at 6:17 PM
    #296
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Yes I am also wondering this as well and need to know. I spoke to Dave again yesterday and got a little different info than 1st time. Now my head is really spinning. I'm going to be trying a stock rock warrior wheel with 1.25 spacer sometime next week. Keep an eye out if your curious if that will clear cb steer kit. Will probably give more insight into our above question as well.
  27. Jan 13, 2019 at 6:23 PM
    #297
    mgm16trdpro
    Northern NJ
    He told me a 17x9 with +18 was able to clear steer kit, soooooo.
  28. Jan 13, 2019 at 8:17 PM
    #298
    InfernoPRO
    Scott
    Sacramento
    I think you were the one who told me the Icons might not work with the CB steering kit. I was hoping someone has tried it and could give us some first hand feedback. Otherwise I might have to go with Methods
    mgm16trdpro[QUOTED] likes this.
  29. Jan 13, 2019 at 8:33 PM
    #299
    mgm16trdpro
    Northern NJ
    Yup it was me. 1st he told me +12 or more negative offset. But after speaking again last night might have changed. The problem is theres so many variables with each setup. He did say a 17x9 with +18 cleared. Also a 18x9 +18 cleared. A member here is going to drop off a 17x8 rock warrior wheel for me this Friday. I'm going to give it a try with my 1.25 spacer and see if it fits.
    Right now my stock pro 18x9 wheels and 1.25 spacer I'm fine with +28.75. With rw wheel 17x8 and spacer would be +18.25, if that fits I'm guessing a 17x8.5 icon w/+25 offset should fit too.
    Just wish there was 1 other person out there that had a cb steer kit and could confirm for sure. I really don't want to spend a grand in rims not knowing for sure. I'm already playing with fire with these big ass 35x12.5r17 pitbull rocker tires, getting them to fit. That should be enough stress, now I got to worry about this god damn steer kit too. If it wasn't for that I'd just get a 17x8.5 or 17x9 with around +18 to +25 offset and call it a day.
    Keep me posted if you find out and I'll do same.
    InfernoPRO[QUOTED] likes this.
  30. Jan 13, 2019 at 9:03 PM
    #300
    InfernoPRO
    Scott
    Sacramento
    Will do ;)
