2014 Limited Service Overdue
Discussion in '2.5 Gen Tundras (2014-2021)' started by BC.Austex, Nov 12, 2018.
  1. Nov 12, 2018 at 12:12 PM
    BC.Austex
    BC.Austex [OP] New Member
    2014 Tundra Limited - Texas Edition
    Hey y'all,
    I have 125k miles, I use to tow and go off-road, not so much any more - just a road warrior. And have recently realized I have not yet done the list of service below. Being that I won't get it done all at once, and some will be done at a shop, what order should these be prioritized?
    Transfer case fluid change
    Rear differential service
    Water pump/timing belt
    Transmission fluid change
    Anything I missed that should be on here?
    Also, once I get this done - considering installing a TRD sway bar for road driving.
    Thank You!
    Y0TA PR0 likes this.
  2. Nov 12, 2018 at 12:17 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    I would change it all at same time if they are overdue! That’s just me though with the front diff.
    Water pump I’m sure you can wait a bit longer but I could be wrong. You don’t have a timing belt you have chains.
    T-Rex266 likes this.
  3. Nov 12, 2018 at 12:28 PM
    BC.Austex
    In that case, that engine & chain can go 300k+ with little to worry about, and can push out the water pump a bit while I do the other service. My thought is the front diff service isn't needed as much if I'm not towing...?
  4. Nov 12, 2018 at 12:28 PM
    Change both diffs. Just because u aren’t towing doesn’t mean it shouldn’t be done.
  5. Nov 12, 2018 at 12:31 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    ^this
    BC.Austex[OP] likes this.
  6. Nov 12, 2018 at 1:47 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Ao you have 125k on the truck and haven't done any of those services you listed, do i read that correct?
    The diffs and t-case get done every 30k....
  7. Nov 12, 2018 at 2:05 PM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
  8. Nov 12, 2018 at 2:08 PM
    14burrito
    2014 SR5 CM 4x4 5.7
  9. Nov 12, 2018 at 2:15 PM
    BC.Austex
    14burrito, I already know it’s overdue. That’s in the title of the thread...if you have additional comments that would help me out, I’d like to hear those instead. Thanks.
  10. Nov 12, 2018 at 2:17 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Just asking if they have even ever been done....because 95k over isnt just "overdue" its a lack of respect for the truck lol
    In any case, cheers
  11. Nov 12, 2018 at 2:23 PM
    B737
    Jersey Shore
    I interpreted that as the vehicle is primarily used on the road. I definitely wouldn’t be losing any sleep over it. Just knock them out at while you have it up. I would also pass on the water pump until it becomes suspect.
    BC.Austex[QUOTED][OP] likes this.
  12. Nov 12, 2018 at 2:40 PM
    BC.Austex
    Actually the rear diff was done earlier this year, about 20k miles ago. I still need to do the front diff & transfer case, and change fluid in radiator (I'll do that one myself)
  13. Nov 12, 2018 at 4:11 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Spark Plugs?
    Spin (test) your breathers. Lube prop shaft.
