2012 Tundra TRD offroad leveling kit
Discussion in 'Suspension' started by JPTUNDRA, Nov 11, 2018.
  1. Nov 11, 2018 at 8:40 AM
    JPTUNDRA
    JPTUNDRA [OP] New Member
    I recently bought a 2012 TRD offload and Im thinking about doing a leveling kit. Does anyone have suggestions on what kit to buy and if the truck will need an alignment after installation. Thanks for any input.
  2. Nov 11, 2018 at 2:08 PM
    Adventures' of the Loners
    Adventures' of the Loners New Member
    Jesse
    13 DCOR
    3/1 Levelled, 33" Duratracs, Leer cap
    I've got a 13 DC OR and just put a Ready Lifts block level kit (3" up front and 1" in back). Only reason I went this route is because my Bilsteins have 100K (yes Kilometers, no not miles) but still have some good life left in them. PLUS the puck kit was purchased for an 18 Tundra at a dealership and then the dealer realized they couldn't put it in the truck because of TSS-P (it was different up here in Canada)... so i got it for free.
    At the end of the day it meant I could fit 275/70R18 Duratracs without rubbing and it was CHEAP!
    As for kits: the Ready Lift is decent. No complaints, seems to be built well enough, was easy to install, came with everything needed other then the strut spacer. So I'm content so far. My only 2 cents would be to make sure it's installed properly. All the big companies make well built kits, having it installed the right way the first time makes all the difference.
    YES get an alignment after! Pretty sure everyone here is going to agree with that.
    I will be swapping this kit out when it comes time to replaced my struts and shocks. At that time I'll go with a Coil Over lift up front and an Add a leaf in the rear, same lift height without the draw backs of the puck lift. DO YOUR HOMEWORK on what it actually means to the different components when you put a spacer kit in your truck please! There are a ton of threads on here and across the world wide web on it. I'm sure someone has them at their finger tips and will link to them... I'm kind of to lazy.
    Cheers and hope you enjoy the level kit!
    JPTUNDRA[OP] likes this.
  3. Nov 11, 2018 at 2:31 PM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    I have a readylift front leveling kit I would sell cheap, msg me.
  4. Nov 11, 2018 at 3:55 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Have 2013 DC TRD20180731_193107.jpg Went with ToyTech Boss KIT Front 3" rear shackles. at 1-1/2 " . running 275/65/20 34.1" tires .Also put on SPC upper control arms. Rides great.
  5. Nov 11, 2018 at 7:01 PM
    mattyd170
    Albuquerque, NM
    Are they 275/60/20 or 275/65/20's? Thanks. And what brand tire?
  6. Nov 12, 2018 at 7:53 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    275/65/20 KUMO ROAD VENTURE
    mattyd170 likes this.
  7. Nov 12, 2018 at 7:59 AM
    mattyd170
    Albuquerque, NM
    Nice. What bumper is that too? hahahahaha
  8. Nov 12, 2018 at 10:15 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Paramont Pro Z Premium Rock Crawler , and it comes with all the lights and wiring kit. Except the light bar, it takes a 32 ". I haven't put the winch in yet, probably this weekend. Smitty Built 12000.
  9. Nov 12, 2018 at 10:27 AM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    my 12 DC TRD is pretty level but i know the previous owner did mess with the adjustable suspension
