Am I doing the math right?
Discussion in 'General Tundra Discussion' started by InfernoPro15, Nov 11, 2018.
  1. Nov 11, 2018 at 3:07 PM
    InfernoPro15
    InfernoPro15 [OP] New Member
    So I have a 2015 crewmax Pro (26 gallon tank) and I am tying to figure out my average fuel range on a full tank. I just need someone to double check my math.
    I reset a trip meter at full tank and was able to get 240 miles before gas gauge was resting on E (80% city driving).
    I did go up in tire size, stock 275/65r18 now 295/70r18. Speedo was not calibrated so it's off by 6.38%.
    Would be correct in saying that the actual milage on full tank was 240 + 6.38% ? That would result in 255 miles.
    I assume same would go in MPG calculation, truck is showing me a consistent 11.8mpg but in reality add 6.38% and we end up 12.55mpg.
    Am I correct in this way of thinking?
    I just like to have an idea since estimated range displayed at fill up is way off and tank is small enough too be a concern when planning trips etc. After refueling I was only able to squeeze in 19.9 gallons which means at E there is still 6 gallons in reserve....I know there are multiple threads on this but I find that part absurd.
  2. Nov 11, 2018 at 4:04 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Looks good to me. If the 6.3% figure is accurate. Your range is about 325 +- depending on a bunch of factors. Personally I am conservative When planning when to fuel up. The truck fuel gauge indicators on these trucks seem to keep a lot of fuel in reserve vs what they indicate. I have the large tank and, even with the gauge showing low there is a 6-8 gallon reserve when I fill up. That being said, the psychology of driving with the needle and computer showing low fuel is gnawing. Not fun.
    InfernoPro15[OP] likes this.
