Steering wheel shake in reverse
Discussion in '2.5 Gen Builds (2014-2021)' started by iamsmokey, Oct 27, 2018.
  1. Oct 27, 2018 at 1:17 PM
    iamsmokey
    iamsmokey [OP] Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    Tundra gurus,
    Post-lift, rims, and tires, I did the CMC and am welding the plates on today however at full lock in reverse, there is some feeling in the steering wheel that makes it feel like I am rubbing somewhere. I had someone reverse it in all directions while I watched and listened and I am 99% sure I am not rubbing anywhere. I've checked the common places such as the CMC, fender liners, and skid plate but didn't see anything. Any ideas what might be going on?
    I've driven in all other directions going forward and it is fine but in reverse at full lock it feels like there is something going on. I have a little over 6,000 miles on the truck.
  2. Nov 4, 2018 at 11:03 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Did you get an alignment?
    OR18TRD likes this.
  3. Nov 5, 2018 at 2:12 AM
    Grumpy Uncle
    Pat
    CO
    We had the same problem with my boys 4Runner, on certain turns in reverse. It ended up being the side lugs rubbing his UCAs. Down hill in reverse with sharp turns and uneven ground. that would be a place to check.
  4. Nov 8, 2018 at 5:50 PM
    iamsmokey
    Oahu, HI
    I am thinking it might just be the new tires I went from the stock Michelins to Ridge Grapplers. Maybe it is just my OCD kicking in...
    OR18TRD[QUOTED] likes this.
