Cheap way to level your tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mikekoot, Nov 5, 2018.
  1. Nov 5, 2018 at 5:11 PM
    Mikekoot
    Mikekoot [OP] New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
  2. Nov 5, 2018 at 5:25 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    I did that last week. 2000lbs of sod does it too!
  3. Nov 5, 2018 at 6:18 PM
    Mikekoot
    Canadia
    I ordered 5100's for the front. Maybe i should go add a leaf in the near future :s
  4. Nov 6, 2018 at 7:01 AM
    Boxer310
    Boxer310 New Member
    2018 white tundra crewmax sr5
    Damn thats one way to scratch the bed lol
  5. Nov 6, 2018 at 7:06 AM
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    I would go with the Firestone air bags.
  6. Nov 6, 2018 at 7:25 AM
    Mikekoot
    Canadia
    I have plywood down on the bed. Im going to eventually do a spray in liner so I'm not too concerned about scratches. Also, it is a truck ;)
  7. Nov 6, 2018 at 7:25 AM
    Mikekoot
    Canadia
    That's a great idea! Which system did you go with?
  8. Nov 6, 2018 at 9:54 AM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Dang is that over payload? How did she handle it?
  9. Nov 6, 2018 at 11:20 AM
    lionix
    Did it twice, handled great, just leaned a whole bunch. Truck payload rating is 1700. I had full bed of sod and my dad and buddy with me.
    Mikekoot[OP] likes this.
  10. Nov 6, 2018 at 11:29 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    1700? 2017 Tundra Pro CrewMax. More like 1440-1560 lbs. 2000 lbs in the bed plus 3 passengers = 2500+ lbs. Only about 1000 lbs overweight. o_O Way to go. :facepalm:
  11. Nov 6, 2018 at 11:45 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I’m thinking that too. Just curious what kind of things would get damaged first? Bent leafs?
    OR18TRD likes this.
  12. Nov 6, 2018 at 11:59 AM
    TacoWuzzaTurd
    Scottsdale AZ
    Do leafs get bent? Isnt that their job? :confused::D
    lionix, Black Wolf and OR18TRD like this.
  13. Nov 6, 2018 at 12:15 PM
    Depends on road conditions.
    Usually the things that get damaged first:
    -Rear axle bearings. These are light duty semi floating axles. Weight rides on axle shaft that has a bearing pressed on. This usually doesn’t show up until later on when the axle starts puking gear oil everywhere.
    -Springs can go flat and lose arch. Most have seen this from pictures on here with rear block lifts. The rear spring pack looks wavy.
    -Frame damage. This usually happens when suspension has no more shock load capacity. I can’t remember what Titan XD forum I linked a thread on here, but the guy bent his frame with to much tongue weight from his camper. He hit a pothole and the downforce bent his frame. Nissan covered the frame replacement. He had 1400 lbs in tongue weight.
  14. Nov 6, 2018 at 12:22 PM
    Even the factory p metric tires come with a load index 116 if I remember correctly. That means each rear tire can carry 2750 lbs per tire, which is quite a bit more than the load limit of the truck.
    JoshuaA likes this.
  15. Nov 6, 2018 at 12:48 PM
    Atomic City Tundra
    Devin
    New Mexico
    It is their job. But, they should remain in the elastic regime while doing that job. Deflection without any permanent (plastic) deformation. But as others have stated, I imagine that other things might have issues first. There are just too many variables and loading conditions to pinpoint what is going to have problems first. But, my biggest concern is handling of a vehicle when it is loaded beyond the capability of the vehicle. Things act quite a bit differently when loaded beyond original design intent.
  16. Nov 6, 2018 at 12:50 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I meant lost arch lol
    Easy way to tell is if you had a pre-measurement from ground to top of rear wheel well.
  17. Nov 6, 2018 at 12:53 PM
    We know what you meant Bon Jovi. :D
  18. Nov 6, 2018 at 12:59 PM
    I remember that XD pic....yowser...
  19. Nov 6, 2018 at 1:04 PM
    15whtrd
    15whtrd Mr. Blonde
    Why do blocks cause the spring to get wavy? Isn’t the axle in relation to the frame the same distance? I would think shackles would cause a premature S wave being that the springs can now reverse arch easier.
  20. Nov 6, 2018 at 1:16 PM
    Axle wrap.
    15whtrd[QUOTED] likes this.
  21. Nov 6, 2018 at 1:17 PM
    15whtrd
    15whtrd Mr. Blonde
    OK. Do you think shackles are bad for the Springs if you don’t extend the bump stops?
  22. Nov 6, 2018 at 1:36 PM
  23. Nov 6, 2018 at 1:49 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s a pretty good little article. Kind of funny too! I liked his explanation of sway bars as well. Thanks Chris
  24. Nov 6, 2018 at 3:02 PM
    Yes sir. Some good information in there....and a laugh or two.
  25. Nov 6, 2018 at 3:18 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Tyres, barbed wire arm tats, and bad mullets from the 90’s. Hoot!
    ColoradoTJ and 15whtrd[QUOTED] like this.
  26. Nov 6, 2018 at 5:25 PM
    lionix
    I still had plenty of suspension travel. Albeit not much. But she was a ton saggy. 20180625_210348.jpg
    OR18TRD likes this.
