Can i put a trd pro grille on my 2018?
Discussion in '2.5 Gen Tundras (2014-2021)' started by corytundra1997, Nov 3, 2018.
  1. Nov 3, 2018 at 1:44 PM
    corytundra1997
    corytundra1997 [OP] New Member
    Hello all, greetings from Iowa, first post here. So I have done some research and so far I have found out you can't put a trd pro grille on any 2018 tundra models because of the sensors? I know all of my sensors are in the toyota emblem on the front of the grille which kinda sucks. So yeah im just wanting to know if I can put a trd pro grille on my 2018 double cab? Hopefully you guys have some good news for me?
    Balti_J likes this.
  2. Nov 3, 2018 at 1:48 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    Nope, will cause spontaneous combustion
    Moon Puppy and Midnighttaco08 like this.
  3. Nov 3, 2018 at 1:54 PM
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    Yes you can put the Pro grill on the 2018, there is lots of discussion bout this. Try the Search function. My recommendation is to buy the Jomax Customs bracket to relocate the radar sensor. I have used that one, the Ares original bracket and the 3D printed bracket and Jomax worked the best for me.
    LVLDUP18 and 619Tundra like this.
  4. Nov 3, 2018 at 1:57 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    Yes search around plenty of info in here about that
  5. Nov 3, 2018 at 2:27 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
    GNTundra likes this.
  6. Nov 3, 2018 at 4:41 PM
    Welcome from NY.
    Yes you can but you have to relocate the sensor.
  7. Nov 3, 2018 at 4:53 PM
    ARES
    ARES ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    To avoid any warranty issues and for the best OEM design and function I would Highly recommend going with the 2019 TRD Pro grille. It is a more costly route but in my honest opinion it looks better and it has the OEM relocation for the PCS Radar. Some guys have had great success with there dealers allowing them to install it without warranty issue.
    1Sikyota, gosolo and KnuckleHD like this.
  8. Nov 3, 2018 at 5:33 PM
    Vizsla
    Vizsla 2 = 2.5
    You could but there are a few caveats. There is a company that has been booted from here watching, and changing up things in cadence with information available, so this will be simple, not interested in helping them by proxy. The sensor and round garnish(these are actually called a radome) are designed to work together like peanut butter and jelly, and is a pretty ideal scenario. The 2019 Pro sensor is a different part number, as it is different internally to work with the Pro garnish and is a more difficult scenario. Toyota spent a good bit on the Pro to make it very small, and it incorporates at least 2 visible specialized design features that make it work. The garnishes are insanely priced for a reason, a lot going on there. There is a huge flaw in putting the sensor behind the old Pro grill, and another lesser flaw as well, again not helping the ignorant. I have also seen claims the radar is just adaptive cruise, it is not and cannot be in a single camera system. Now the nasty, so whoever is selling an off road only safety system mod for brand new trucks is an idiot by default, how many off road only Tundras you know of? Now after that, you release all rights, responsibilities against the seller, and assume all risk while being informed it could be big trouble to purchase. When you install that on your vehicle and drive it, you signed off on knowing it’s for off road use only, released acknowledgment that the mod is not DOT legal and can malfunction, it’s called gross negligence on your part. Front end collision if your at fault, regardless if the modded systems fault, will get you, and the company that sold sued beyond belief. Finally you will see the claim that it needs recalibrated, and then passes a test, it will in that controlled environment, but it cannot account for the scenarios that will cause false readings. Toyota says do not touch it, no wiggle room, and they are alerting dealers not to touch any vehicle with TSS mods. This has nothing to do with @ARES , he is a very talented fabricator that hopefully pursues more viable products for our trucks. Weigh it out, talk to your dealer. If you read this whole thing thanks, the whole system is proprietary, this represents 2 years of difficult to find research.
  9. Nov 3, 2018 at 7:19 PM
    Vizsla
    Vizsla 2 = 2.5
    Mods, I am fine with insults, let them stand so the rest can see.
    Yes, 2” in front stock height in rear.
    OR18TRD[QUOTED] likes this.
  10. Nov 3, 2018 at 7:25 PM
    Vizsla
    Vizsla 2 = 2.5
    You are fine with your grill, the system can be recalibrated perfectly fine on lifted trucks. Mine is lifted and recalibrated. Works perfect.
    Darson Layne and OR18TRD[QUOTED] like this.
  11. Nov 3, 2018 at 7:38 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    First of all, welcome from San Diego. Everything mentioned above is true and great advice for anyone willing to listen. The short answer is yes you can. Should you? Well I’d recommend doing the research and making your own informed decision.
  12. Nov 3, 2018 at 8:50 PM
    Vizsla
    Vizsla 2 = 2.5
    Very well said my friend! Sometimes my inner nerd makes things confusing. Wow:bowdown:, truck looks soo nice, little :jellydance: of the mirror caps and handles, did you add those?
    KnuckleHD[QUOTED] likes this.
  13. Nov 4, 2018 at 7:01 AM
    Heatonrx
    Heatonrx New Member
    Didn't need a relocation bracket or recalibration of the sensor. Not one error and I love the look. Good luck. Do it!
  14. Nov 4, 2018 at 7:11 AM
    TunderStorm
    TunderStorm New Member
    Michael
    2018 TRD SR5 CM MGM +
    - Toytec/Eibach 3/1.5 + TC UCAs - Fuel Vapor 18x9+20 w/BFG KO2 35’s - TRD sway bar - Go Rhino nerf bars - badge delete - Bakflip MX4 - ESP storage - Rockford Fosgate 10’s +++ - TRD shift knob - Weathertech front mats - Escort 360 hardwired - Window tint Future mods: N-Fab M-RDS front bumper w/40” Black Series RC Lightbar
    That looks awesome.
    OP, as you can see, people are doing it.
    Have you considered paint matching your front end? That’s what I did and it looks a ton better. Haven’t done the bumper yet. I think the 2018 honeycomb is BA looking so just kept it
  15. Nov 4, 2018 at 9:15 AM
    Phishindude
    Phishindude New Member
    That looks sweet!
  16. Nov 4, 2018 at 4:11 PM
    heywaitfourme
    heywaitfourme New Member
    Chesapeake, VA
    I have ZERO issues with mine. Over 10k miles with bumper, over 5k with grill. All of the TSS crap still works as it did day one.
    Blueknights75 likes this.
  17. Nov 4, 2018 at 4:13 PM
    Blueknights75
    Ron
    Clayton, NC
    What did you use to relocate the sensor?
  18. Nov 4, 2018 at 4:15 PM
    heywaitfourme
    Chesapeake, VA
    Made my own bracket and relocated it to the lower colored portion below Toyota just off the center towards the drivers side. It’s mounted to the core support that runs directly behind. It’s roughly 1/4-1/2 inch behind the surround as it sits.
  19. Nov 4, 2018 at 5:22 PM
    KnuckleHD
    I don’t think your post was confusing at all. The safety systems in these trucks are anything but simple. It’s good for people to know what all goes into the R&D. So thank you for sharing your knowledge! Poor OP didn’t know he was opening a can of worms with his first post haha.
    As for the truck, I’m pretty happy with how it’s coming along. I added the color matched handles and mirror caps, I was torn between that or black but really like the way it turned out. I’ll be adding some more black in other places so I think it’ll balance out. Painted end caps courtesy of you, thank you again!
    I was actually looking at your build page the other day, might have to take a page from your book with that suspension set up...
    Vizsla[QUOTED] likes this.
  20. Nov 5, 2018 at 4:43 PM
    corytundra1997
    Thanks for all the responses fellas! I'm definitely better informed now.
  21. Nov 27, 2018 at 5:16 PM
    an-tron
    an-tron New Member
    Ant
    So all you did was leave the sensor as is and put the new grill on?
  22. Nov 27, 2018 at 6:02 PM
    Heatonrx
    Heatonrx New Member
    Yes, it goes on with the two screws you remove from the original grill.
  23. Nov 27, 2018 at 6:08 PM
    an-tron
    an-tron New Member
    Ant
    Interesting... gonna give this a try thanks!
  24. Nov 27, 2018 at 7:13 PM
    deedubb
    deedubb New Member
    2018 Tundra SR5
    Does the 2019 insert fit inside the 2018 surround? Or do you have to use the 2019 surround and have it painted to match?
  25. Dec 2, 2018 at 9:25 AM
    silverhack
    Sacramento, CA
    They are the same size/shape and are interchangeable.
    deedubb[QUOTED] likes this.
  26. Feb 27, 2022 at 3:05 PM
    Wakekid686
    Wakekid686 New Member
    GREAT info in this forum gents....
    Does anyone have a recommendation on where to purchase JUST the PRO honeycomb (grill insert) and Garnish? Everything I seem to find online includes the shroud and sometimes the buldge.....both mine are color matched (pictures attached) and I'm wanting to simply change from the split honeycomb with circle toyota logo, to the solid honeycomb and "Tundra" lettering like that of the PRO grills.
    Mine is a 2018.
    Any and ALL advice is welcome especially if you know where I can sell mine & purchase the PRO honeycomb& garnish. Thanks20220206_104625.jpg 20220222_125504.jpg
  27. Feb 27, 2022 at 3:32 PM
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    Nice ride. Let me see those pics after the change. I’ve thought about changing to the TRD grille but somehow the sport grille is attractive too.
    Wakekid686[QUOTED] likes this.
  28. Feb 27, 2022 at 5:07 PM
    Wakekid686
    Well if I can find JUST the honeycomb grill portion and the garnish needed for the TSS sensor for a good deal I'll snag it and post pics for sure.
  29. Feb 27, 2022 at 5:09 PM
    Where are you located?
  30. Feb 27, 2022 at 7:40 PM
    Wakekid686
    Portland or area
