3MXDIVR slow steady OVERLANDER progress....
Discussion in '2.5 Gen Builds (2014-2021)' started by 3mxdivr, Nov 3, 2018.
  1. Nov 3, 2018 at 10:13 AM
    3mxdivr
    3mxdivr [OP] New Member
    NorCal
    2018 Limited Crewmax TRD Off Road
    Hey guys. Progessing slowly but surely .....
    First step slowly de-chroming the Limited parts & adding a 2019 pro grille and Rigid 30” light bar.
    Ceramic powdercoated tips and exhaust.
    Powdercoated bumper ends, since I want them to remain steel.
    SSO slimline bumper and winch in transit so have to install that before these guys + had to change garage door first to accomodate the planned lift.
    Oh and the RCI skids on the way from the group buy.
    Going to wait for Black Friday to see what deals are for wheels and tires.
    SCS Ray10s + 35s
    Thanks & forum is a wealth of knowledge and fun!
  2. Nov 3, 2018 at 10:16 AM
    I'm liking this so far!!
    Rica25 likes this.
  3. Nov 3, 2018 at 10:21 AM
    3mxdivr
    NorCal
    Rica25 and Black Wolf like this.
  4. Nov 3, 2018 at 11:27 AM
    Rica25 and T-Rex266 like this.
  5. Nov 3, 2018 at 12:29 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    That's commitment, changing garage doors so you can lift it. Nice truck, it deserves a place to stay inside
    Rica25 and TheBeast like this.
  6. Nov 3, 2018 at 4:31 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    I like what you did with the exhaust. Did you just take them off and take them to a local shop ? How much did the cost ?
    Good luck with your build, really nice truck.
    Rica25 likes this.
  7. Nov 3, 2018 at 5:35 PM
    3mxdivr
    NorCal
    @NjPro yup just undid the bolts and brought it to the shop. Cost about $200 to ceramic powdercoat both tailpipes.
    Thanks for the compliment. Slowly but surely brother!
  8. Nov 3, 2018 at 6:37 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    How long did it take to get you tail pipes back ? I have been doing research and I found a well reviewed shop 15 minutes away from me, going to call on Monday to get a quote.
  9. Nov 3, 2018 at 6:52 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Looking good so far!
    :popcorn:
    Rica25 likes this.
  10. Nov 3, 2018 at 6:57 PM
    3mxdivr
    NorCal
    Dropped it off in the morning and picked it up at the end of the day. Really depends if the shop has other ceramic jobs lined up I think @NjPro. Good luck!
    Rica25 likes this.
  11. Nov 3, 2018 at 6:58 PM
    3mxdivr
    NorCal
    Thank you sir!
  12. Nov 13, 2018 at 5:17 PM
    3mxdivr
    NorCal
    I think it is safe for me to say that I won’t be making my tee time this Saturday!
  13. Nov 13, 2018 at 6:21 PM
    Squatting Pigeon
    Holden
    North Texas
    Swinging wrenches > swinging golf clubs
    (When truck parts show up)
    :D
    Rica25 and Erichudgins like this.
  14. Nov 19, 2018 at 7:48 PM
    3mxdivr
    NorCal
    Was able to install SSO slimline bumper and winch over the weekend.....
    Did my best to take pics, weigh part taken off, and parts added to get an almost exact total of total weight added as well.
    So first, you need to cut off the center piece of the bumper valance.
    Next remove all necessary parts.
    Unbolt aluminum crash bar from side extension and bumper valance. We do not use the aluminum bumper, so subtract (23lbs).
    Since I chose not to have the bull bars with the new bumper, I was able to mount it on the truck empty. Meaning i could assemble the light, assemble the winch and it’s relocation bracket while the bumper is on the truck. Makes it a little easier.
    If you selected the bumper with the bull bars, you would have to zip tie the bumper valance on to the truck and assemble the winch to the bumper while it is off the truck.
    Bumper + Relocation Winch Bracket = 65lbs
    Winch + Relocation wires/hardware = 66lbs
    Baja Designs 30” S8 = 9lbs
    Next step I did was i spooled in the spydura rope to the winch.
    Spydura Rope + Hawse Fairlead= 10lbs
    Power steering cooler was too close after spooling in the Spydura, so I had to bend the brackets a little bit closer to the radiator. Without bending it, distance to rope fully spooled in is about 3/8”. Like this....
    So bend the bracket a little bit and you will get about 3/4 inch further from the spooled in rope.
    Next, put valance on the slimline bumper and line up. This is TEDIOUS and i actually had to grind 3 places from the thin aluminum cross member that holds the valance and the bumper end caps.
    These are the 3 locations that rub on the valance crossmember. So you have to geind/dremel of metal on the steel crossmember.
    Once Chopped off, it is easier to line bumper.
    Then the home stretch, just reattach the grill and inner fender liner.
    So added weight = 127lbs
    Winch = 76lbs
    Bumper = 65lbs - Old Bumper = 23lbs
    Light = 9lbs
    ______________ ________________
    150lbs - 23lbs
    = 127lbs
    * installed it myself and it can be done. Would be easier if you have help and have a few beers in between. ☺️
    Finished Sunday, next install would be the RCI skids! Then the suspension this coming weekend.
    TXMiamiFan, joonbug and dcsleeper408 like this.
  15. Nov 19, 2018 at 8:04 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Very nice start!
    is the trans cooler behind the winch?
    joonbug likes this.
  16. Nov 19, 2018 at 8:08 PM
    3mxdivr
    NorCal
    Power steering cooler is the one right behind the winch. Thanks bro!
    dcsleeper408[QUOTED] likes this.
  17. Nov 19, 2018 at 8:12 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    what part or nor cal you from?
  18. Nov 19, 2018 at 8:16 PM
    3mxdivr
    NorCal
    dcsleeper408 likes this.
  19. Nov 19, 2018 at 8:18 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Nice! We have a good amount of folks in that area! :thumbsup:
  20. Nov 19, 2018 at 8:20 PM
    3mxdivr
    NorCal
  21. Nov 19, 2018 at 8:21 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yeah, it's a Tepui Kukenam 3p
    3mxdivr[QUOTED][OP] likes this.
  22. Nov 19, 2018 at 8:23 PM
    3mxdivr
    NorCal
    Awesome..... I think I got the approval for an Autana this BF from the wife. We camp and backpack a lot, and she finally caved in!
  23. Nov 19, 2018 at 8:31 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Awesome build. Looking really good.
  24. Nov 19, 2018 at 8:32 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Great quality tents!
    My mistake I have the Autana myself. 3p, decent size for my small family.
  25. Nov 19, 2018 at 8:37 PM
    3mxdivr
    NorCal
    Just have to figure out how to load it on the truck with very little effort. I figure i can use same pulley system we use for our kayaks. But the problem would be loading it on the truck. Since my garage door is about 84" and if i put the tent on the rack while inside the garage i wouldn't be able to get out w/o hitting the garage door.
    What rack do you have? Was thinking of going RCI or some other low profile one. Any suggestions?
  26. Nov 19, 2018 at 8:40 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I have the BAMF low pro? @jlee has a nice 25% black friday deal going. Or just go with some bed bars from @RelentlessFabrication . Only thing is the low pro rack wont work with the kayaks.
    csuviper likes this.
  27. Nov 19, 2018 at 8:43 PM
    3mxdivr
    NorCal
    I have the track from rhino up in the roof ditches installed, so i can use our current yakima bars and kayak holders. If i get a low pro rack + the 15.5" tent height folded, i should be able to put the kayaks on as well. The tent is 15.5" folded right? inclusive of the ladder
  28. Nov 19, 2018 at 8:48 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    That sounds about right. The ladder adds a inch-ish. I can see the low pro rack with the tent working with the roof rack for the kayaks. Would you just strap them down? If you get the universal mounts on the low pro rack from BAMF you should be able to hook some ratchet straps all the way across. Not sure if that's safe though.
    GodlessPro likes this.
  29. Nov 19, 2018 at 8:52 PM
    3mxdivr
    NorCal
    @dcsleeper408 I think that would be safe since i ratchet strap both fronts and rears. Just looking at the BAMF site and looks awesome. The only thing with the RCI rack is that i can disassemble it if it is not being used. I think the BAMF low pro comes welded. Just have to find a way to store it.
    Rica25 and dcsleeper408 like this.
  30. Nov 19, 2018 at 8:58 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    They are really nice racks. Storage does suck if you don't have the space. I am lucky to be able to store it in my warehouse at work or at my boss's personal shop. The RCI rack is nice. @GodlessPro just put together his setup. Very very clean setup!!
