2019 Tundra TRD Pro TIRE SIZE
Discussion in 'New Member Introductions' started by Bill Cogan, Nov 2, 2018.
  1. Nov 2, 2018 at 4:26 PM
    Bill Cogan
    Bill Cogan [OP] New Member
    2019 Tundra TRD PRO
    What is largest tires i can go on this stock 2019 Tundra TRD Pro?
    What if I put a level kit up front for 1 1/2 inches and then what size could I go. Some guys telling me 34" will rub probably......... I would like at least 34 or 35.
    Thanks
  2. Nov 2, 2018 at 4:30 PM
    jstrenn
    jstrenn New Member
    2017 Toyota Tundra Double Cab 4X4 TRD Off Road
    I think the TRD Pro is already leveled from the factory. If you go any higher in the front it would be nose high.
  3. Nov 2, 2018 at 4:32 PM
    Welcome from Ohio!
  4. Nov 2, 2018 at 4:51 PM
  5. Nov 2, 2018 at 5:16 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    Welcome from Nj.
    I ran 275/70/18 on my 17 Pro with no major issues, before I changed the set up, just removed the small mud flap up front. Our trucks are already level from factory. As mentioned above, you will be very nose high if you install a shim up front without modifying the rear with something like shackles or a aftermarket leaf pack.
  6. Nov 2, 2018 at 5:16 PM
    Bill Cogan
    2019 Tundra TRD PRO
    Its not leveled from the factory.
  7. Nov 2, 2018 at 5:17 PM
    Bill Cogan
    2019 Tundra TRD PRO
    my front end is lower than the truck bed
  8. Nov 2, 2018 at 5:22 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  9. Nov 2, 2018 at 5:25 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    Pros have very slight rake, I think I have read somewhere on the fourum some have been nose high. Being it is new, the aftermarket will take a while to catch up with parts. If it is a major issue for you, you can swap the stock coil overs and rear shocks for a different system. You can reach out to the below vendor for some help. Dave helped me when I wanted to change my truck up. There is a lot of knowledge on this fourum and great vendors. Call them and they will help.
    Vendor: Ekstrom Design [​IMG] Sales & Questions: Coachbuilder1
    Tel: (801) 635-4872
  10. Nov 2, 2018 at 5:27 PM
    backinblack
    backinblack New Member
    James
    My 19 Pro came stock leveled. You might want to have yours checked out?
    I run 285/70/18 with no modifications:
  11. Nov 2, 2018 at 5:48 PM
    LTPro
    LTPro New Member
    Luis
    2015 Tundra TRD Pro
    Stock trd pro suspension on 17' Method wheels wrapped up in 315/70/17 KO2's
    I'm running 315/70/17 on my Pro, which it is a 34.4 really meaty tire. All I had to do was some minor trimming and a BMC. Suspension is all stock.
  12. Nov 2, 2018 at 8:23 PM
    ctraut5
    ctraut5 New Member
    Germantown,TN
    2019 Black TRD Pro
    I also have a 2019 Pro. The Pro trucks are about 1.5”-2.0” higher in the front than a standard Tundra. My truck may be just barely higher in the rear. I find it’s best to measure at the rocker as opposed to the fenders to see how far off you are. I am running 285/70r18 with no rubbing at all. 574BD08D-CAE2-4C8D-B938-5A1B53AF357C.jpg
  13. Nov 2, 2018 at 8:36 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Every pro I have seen is level or very close. If you add more than a half inch up front it'll definitely be nose high.
  14. Nov 2, 2018 at 8:38 PM
    TheBeast
    TheBeast The Beach
    I say 295/70/18
    OR18TRD and Watt maker like this.
  15. Nov 3, 2018 at 4:27 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  16. Nov 3, 2018 at 8:06 AM
    15whtrd
    15whtrd Mr. Blonde
    Pictures of the truck? All TRD pro‘s are pretty much level stock. If yours is not, there is either something wrong or you don’t actually have a TRD pro. You probably just have a TRD sport or off road.
    Pics or
  17. Nov 5, 2018 at 8:37 AM
    Bill Cogan
    2019 Tundra TRD PRO
    I'm no truck specialist but aren't the beds of all trucks slightly higher than the front end? Thats all I'm saying. I took it to four wheel parts and they said they would put a level kit on it and raise just the front about 1 1/2 inches and it would be good. I have a 2019 Tundra TRD PRO
    Tacoma-Tundra likes this.
  18. Nov 5, 2018 at 8:59 AM
    15whtrd
    15whtrd Mr. Blonde
    If you add an inch and a half to what you already have it’s going to be nose high. You’ll need to address the rear after that. Be careful adding a spacer on top of your current suspension you going to need upper control arms most likely as well as extending your bump stops.
    757TUNDRA and NjPro like this.
  19. Nov 5, 2018 at 9:05 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    You do not want to put a 1.5” level kit on the front of your truck. You will be running way nose high and there are so many other reasons that you don’t want to do that because of ride quality and possible equipment failure. Other members will provide lot of details why this is not a good idea. ***Just looking out***
  20. Nov 6, 2018 at 10:24 AM
    jstrenn
    jstrenn New Member
    If this is a photo of your truck Bill Cohan, it doesn’t look like it’s a TRD Pro. The TRD Pro has that stamped into the side of the truck bed. I’m not seeing that when I zoom in on your photo.
    GODZILLA and 15whtrd like this.
  21. Nov 6, 2018 at 11:41 AM
    backinblack
    James
    It appears that what you have there is a TRD Sport rather than a TRD Pro. The TRD Sport is missing the bed stamp (see my picture above) and is not leveled.
    EDIT: Although...I can't see your wheels in the lighting, they do not look like the stock TRD Sport wheels?
    GODZILLA and OR18TRD like this.
  22. Nov 6, 2018 at 11:52 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Without the bed stamp, that’s a TRD Sport with a 2019 TRD Pro grille. It’ll have factory rake. Rigid fogs?
    OR18TRD likes this.
  23. Nov 6, 2018 at 12:41 PM
    Notachickmagnet
    Notachickmagnet New Member
    Welcome !
    15whtrd likes this.
  24. Nov 9, 2018 at 7:57 AM
    Welcome from Texas
  25. Nov 9, 2018 at 8:47 AM
    jstrenn
    jstrenn New Member
    I'm wondering what the outcome of this thread is. The OP hasn't posted anything else. Do you have a TRD Pro or not? Is the front really lower than the rear? Did you get a level kit installed? So many questions and no answers.
    15whtrd likes this.
  26. Nov 9, 2018 at 8:54 AM
    15whtrd
    15whtrd Mr. Blonde
    No shit! I want to see a close-up picture of the bed stamp. A picture of the coil overs would be great too.
    Rica25 likes this.
  27. Nov 9, 2018 at 9:02 AM
    backinblack
    James
    Rica25 likes this.
  28. Sep 25, 2019 at 10:03 PM
    DUGIE FRESH
    DUGIE FRESH New Member
    Ventura
    2016 Crewmax TRD 4WD SR5 5.7 White
    Rough Country floor mats, lumin X fog lights, amber fog light bulbs, LED headlights, 3” Eibach front lift, 35” Hercules Terra Trac AT2 tires, 1.5” front wheel spacers, Line X Bedliner...
    Not a TRD PRO but 35” tires Eibach front 2.5” lift shocks/coils and 1.5” front wheel spacers. Trimmed? Yes, no rubbing at all, rides excellent, running stock 18” wheels.B9190791-9F07-4173-989C-EBD91CD9786F.jpg
  29. Oct 1, 2019 at 6:48 PM
    T4r4tr
    T4r4tr New Member
    2020 Army Green TRD Pro
  30. Oct 17, 2019 at 9:13 PM
    freedomoftime
    freedomoftime Real Estate Advisor
    Buddy
    Washington State
    2020 Tundra TRD PRO Army Green
    AMP Power Step Running Boards - 10.23.19 Tinted front windows to match back - 10.20.19 Tinted windshield (70) - 10.20.19 Flag Decals on front quarter panels (matte black) - 10.23.19 Tailgate insert with USA flag - 10.23.19 Nitto Grappler G2s 285/65/18 - 10.20.19 Toyota factory Tri-Fold Tonneau Cover - 10.20.19
    What size tires do you have? Is the PRO stock?
