Would I be maxed out?
Discussion in 'Towing & Hauling' started by zeke7681, Oct 30, 2018.
  1. Oct 30, 2018 at 4:36 PM
    zeke7681
    zeke7681 [OP] New Member
    Zeke
    PA
    2018 Black TRD Sport CM
    We were looking at getting this new Jayco TT but I wasn't sure if a hitch weight of 721lbs would max me out. I own a 2018 Crewmax and here are the TT specs.......
    2019 Jayco Jay Flight SLX 284BHS
    Hitch Weight 721 lbs
    Gross Weight 7500 lbs
    Dry Weight 6160 lbs
    Cargo Weight 1340 lbs
    If that's to heavy we were also considering the 2019 Jayco Jay Flight 267BHS which has a hitch weight of 670lbs.
    2019 Jayco Jay Flight SLX 267BHS
    Unloaded Vehicle Weight (lbs) 5690
    Dry Hitch Weight (lbs) 670
    Gross Vehicle Weight Rating (lbs) 7000
    Cargo Carrying Capacity (lbs) 1310
  2. Oct 30, 2018 at 6:10 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    Check your payload rating on drivers side door jam (B pillar). Take that number and subtract the tongue weight; the difference is what you having remaining for passengers and cargo. A weight distribution hitch will change the tongue weight just slightly.
    OR18TRD likes this.
  3. Oct 30, 2018 at 6:38 PM
    Blueknights75
    Ron
    Clayton, NC
  4. Oct 31, 2018 at 12:49 AM
    zeke7681
    Zeke
    PA
  5. Oct 31, 2018 at 2:47 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    You should be good. After people and gear inside the truck you will be close to max. I would make sure I had a good weight distribution hitch and take the time to make sure everything looks level.
    Personally, I would go with the 2nd option. Just for piece of mind.
  6. Oct 31, 2018 at 2:51 AM
    zeke7681
    Zeke
    PA
    Thanks I was definitely pushing for the 26' but the wife wants the 28' because of the outside kitchen:notsure:
  7. Oct 31, 2018 at 3:21 AM
    1265-750 or more(after camper loaded)=515 lbs left on capacity.
    Subtract your family weight, 75 lbs for LDH, and anything in the bed of truck.
  8. Oct 31, 2018 at 4:53 AM
    zeke7681
    Zeke
    PA
    lol, I figure we're pushing 500-550lbs between me, my wife, and 2 kids
    OR18TRD[QUOTED] likes this.
  9. Oct 31, 2018 at 5:00 AM
    Lake.Life24
    Shawn
    Upstate, NY
    I dont recommend this but if the wife is set on the 28' you could get a heavy duty leaf pack. Obviously this doesnt increase your legal towing capacity but it will help the truck handle the extra weight
    OR18TRD likes this.
  10. Oct 31, 2018 at 5:10 AM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    In addition to everything already mentioned I'd upgrade your tire package to something E Rated. Be sure when you're hauling either of these suckers that you're inflated to near max. 10ply tires with a stiffer sidewall and higher psi will help that truck not only handle the weight but keep your heat down. Much safer.
    OR18TRD likes this.
  11. Oct 31, 2018 at 5:34 AM
    Lake.Life24
    Shawn
    Upstate, NY
    Good call on the tires
    OR18TRD likes this.
  12. Oct 31, 2018 at 7:55 AM
    zeke7681
    Zeke
    PA
    I have 275/70/18 Nitto Ridge Grapplers
    15whtrd likes this.
  13. Nov 1, 2018 at 2:51 PM
    woodywoodward
    woodywoodward New Member
    Josh
    2018 TRD OFF Road Tundra
    bone stock
