Noticeable MPG improvement at 50 PSI
Discussion in 'General Tundra Discussion' started by Stumpjumper, Nov 1, 2018.
  1. Nov 1, 2018 at 10:52 AM
    Stumpjumper
    Stumpjumper [OP] Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    First cold snap and TPMS light comes on. I start to cuss dealer because the one use is notorious for not putting enough air in. I get the gauge out and sure enough 42-46 lbs. I aired them all up to 50 and my MPGs jumped about 4%. Not huge but over $100/year savings.
    OR18TRD, Black Wolf and lsaami like this.
  2. Nov 1, 2018 at 10:56 AM
    15whtrd
    15whtrd Mr. Blonde
    Isn’t the ride rough? Sounds like it would feel like rolling around on wagon wheels.
    jewsNbrews, TheBeast, OR18TRD and 2 others like this.
  3. Nov 1, 2018 at 10:57 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    When I bought my truck the dealer delivered it to me with 28 psi. Nice cushy ride but I took it up to 38 which is a good pressure for me.
    Anyways, you can reset the TPMS at any pressure you want. There is small button under the dash on the right side of the steering wheel. Yours is likely originally set at 50 so when it fell below that the light came on. It sounds like you are happy with the MPG gains, but if the ride is too hard you can deflate to a comfortable psi and then reset the TPMS.
    1UPPER, Sunnier and 15whtrd like this.
  4. Nov 1, 2018 at 11:37 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Is that $100 a year going to actually save you money when the tires wear prematurely?
  5. Nov 1, 2018 at 11:40 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Higher PSI will make the tires firmer, so there is less rolling resistance. But will your tires thank you, definitely not. These trucks empty should be between 32-35 psi for proper inflation. Higher pressures are to accommodate heavier loads in the truck.
    jewsNbrews, landphil and 14burrito like this.
  6. Nov 1, 2018 at 12:08 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    interesting but
    this
    and this
    and besides, the term "gas mileage" is reserved for Prius forums ONLY. getouttahere :burnrubber::mudding:
  7. Nov 1, 2018 at 1:25 PM
    greengs
    greengs New Member
    I think the TPMS came on because you had more than a 3PSI discrepancy between the tires. 42-46 is way overinflated, 50 psi is close to max tires are designed for and you will wear them out really fast this way. Unless you have non OEM tires?
    landphil likes this.
  8. Nov 1, 2018 at 2:46 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Overinflation also adversely affects traction. Which = increased safety risk.
  9. Nov 1, 2018 at 3:22 PM
    Yep, depends on the tire rating.. Example, my max psi with ST Maxx is 80 and with all the weight up front with winch bumper 50ish up front just happens to be the sweet spot with 45 in the rear for highway. Rides just fine and tread is wearing even after one year and two rotations. On my STT Pro M/T's I run 40 up front and 36 out back. Each tire mfr provides individual specific tire pressure charts based upon "no load" conditions. With "load" conditions then adjust pressure accordingly for best ride/tread wear.
    jewsNbrews, Sunnier and OR18TRD like this.
  10. Nov 1, 2018 at 3:28 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Was near 50 but deflated back to 42, Ridge Grapplers. Could feel the bumps more, less rain traction and premature wear. Getting back the opposite trumped mileage gains for me.
    landphil, OR18TRD and Black Wolf like this.
  11. Nov 1, 2018 at 3:36 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Damn 50 psi that a firm ride literally. I run 35 psi all around, ride is nice traction is better.
    14burrito and OR18TRD like this.
  12. Nov 1, 2018 at 3:43 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Did a trial test for a week at 60psi (tires will go to 65psi). Had to go to the dentist for chipped rear molars (ate my fuel savings on teeth repair).
    Decided that 32psi was not so bad after all. 32 is the sweet spot.
    14burrito, landphil and OR18TRD like this.
  13. Nov 1, 2018 at 3:56 PM
    15whtrd
    15whtrd Mr. Blonde
    :rofl::rofl::rofl:
  14. Nov 1, 2018 at 3:56 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    iirc, Nitto said 42 for mine, your aftermarkets may vary, and stock is 32 per door sticker.
