Sunnier Finally Got 4x4!! Need Help Building It:
Discussion in '1st Gen Tundras (2000-2006)' started by Sunnier, Oct 30, 2018.
  1. Oct 30, 2018 at 7:23 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Welcome to "does that Tacoma have a V6?" Land!
    :bananadance::bananadead:
    For suspension, since you are in the magical land of San Diego where rust doesn't exist, I would consider Camburg or Total Chaos upper control arms with uniballs. They have some difference in geometry but I went Camburg because they were $150 cheaper. A lot of people also like the Light Racing (I think) upper arms, which use a flipped ball joint. They're a bit cheaper but I have no experience with them.
    Pair your choice with Icon extended travel coilovers, or if you want look into the ADS option that Jimmy has. I have no experience with those but am a bit worried how similar they are to Fox and I have had enough problems with Fox to not wish them on you. With 4wd I wouldn't recommend more than 2" of lift, less if possible. Look into 930 boots for the front shafts.
    For rear suspension your options are to leave it alone, or get a 3 pack (cheap and works, Wheelers has a heavy duty version) or drop several hundred on a full leaf pack (expensive and makes rear shock choice a homework assignment). Many go with Deaver, I went Alcan because I wanted some control over how high and how much weight to carry.
    For skid plates therebos no better than Skid Row. I also have an OR Fab plate but it's a pretty thoughtless design and honestly doesn't bolt up without modifications. :rolleyes:
    See if you have wheel spacers in there, unusual that stock rims and 285 tires don't rub the stock upper arm. If you have spacers in your wheels and dont fancy that starfish wheel, start considering a wheel with 3.5 to 4" of backspace.
    For tire size, stay 285/75, otherwise you'll need to do seriously invasive surgery.
    SoCal619, Rheywood456, Bob and 5 others like this.
  2. Oct 30, 2018 at 7:59 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    Long travel :thumbsup:
    Matty4wd, SoCal619, Cfincke and 2 others like this.
  3. Oct 30, 2018 at 7:59 AM
    Marty McFly
    Morty McBoonJug
    It’s CA homie, we steal our tundras round here o_O
  4. Oct 30, 2018 at 7:59 AM
    Casper421
    In the woods
    06 DC
  5. Oct 30, 2018 at 8:04 AM
    Casper421
    In the woods
    06 DC
    Here’s the suspension you need, cuz it’s what I’m planning:
    - ICON extended travel fronts/ 2.5 rear(cdcv or not)
    - Total chaos uca’s
    - Deaver leaf pack and U-bolt flip kit from Archive Garage
    Rheywood456 and Sunnier[OP] like this.
  6. Oct 30, 2018 at 8:07 AM
    Casper421
    In the woods
    06 DC
    And throw in some TC spindle and upper coil bucket gussets just because.
    Sunnier[OP] and papasmurf like this.
  7. Oct 30, 2018 at 8:21 AM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    Congrats @Sunnier !!! I've always admired you for your 2WD blazing the trails like a PRO! Since I had a 2WD as well, I always said, "If Sunnier can do it ... then 2WD is viable". LOL I look forward to the great adventures this baby will give you. Cheers to you brother!
    Sunnier[OP], Law323 and Darkness like this.
  8. Oct 30, 2018 at 9:50 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just go MT's! It's not your DD, tires are everything when you're wheeling.
  9. Oct 30, 2018 at 10:05 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Congrats on the truck :spending:
  10. Oct 30, 2018 at 11:21 AM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    Hot metal fab makes sliders for your truck. http://www.hotmetalfab.com/new-products/gen1-maxx-protection-diy-rock-sliders
  11. Oct 30, 2018 at 11:41 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Congrats brother!! Looks great and sounds like you’re well on your way to having a BA overlander!!
  12. Oct 30, 2018 at 11:53 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    boo. go blue or go home.
    :cool: :bananadance:
  13. Oct 30, 2018 at 11:55 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    i'm moving slow. i just realized what that meant. how cool would that have been?
  14. Oct 30, 2018 at 12:04 PM
    Casper421
    In the woods
    06 DC
    King only makes a front 2.5 for the 1st gens(non resi). No rear option.
    smslavin[QUOTED] likes this.
  15. Oct 30, 2018 at 12:11 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    double boo
  16. Oct 30, 2018 at 12:12 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    There isn't a lot of first hand experience with them, the top mount uses a lot of spacer and the shock travel is barely 4". They don't seem to make one for extended travel like Icon/Camburg/Fox do.
    Shelling out that much cash, I would rather go Icon and forget the reservoir.
    Casper421 likes this.
  17. Oct 30, 2018 at 12:13 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Sounds like a pirate speaking but it’s available.
  18. Oct 30, 2018 at 2:24 PM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    Nice pick-up! pun intended lol
    Cant wait for the next SoCal trip! maybe i'll get to see "the hulk" in person.. (my suggestion for the name of your new rig)
    joonbug likes this.
  19. Oct 30, 2018 at 2:49 PM
    Sunnier
    Sunnier [OP] Pity the warrior that slays all his foes
    Sunny
    San Diego, CA
    Hi, Guys! Got some decent sleep today and am thrilled to find all this good stuff to catch up on. I'll be sneak-reading to catch up as time permits today/ tonight. Thanks everyone who chimed in. :fistbump:
    Darkness likes this.
  20. Oct 30, 2018 at 2:55 PM
    #50
    Sunnier
    Sunny
    San Diego, CA
    Hahaha! Not broken. That's my poor use of the mark-up tool to conceal a face in the photograph. I was excited to post up and realized if only takenbthe one pic. o_O
    Hahaha! I bought it but Ima drive it like its stolen!! :D
  21. Oct 30, 2018 at 2:55 PM
    #51
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    ….or Shrek
    OR18TRD, blue16, Darkness and 7 others like this.
  22. Oct 30, 2018 at 3:03 PM
    #52
    Sunnier
    Sunny
    San Diego, CA
    Thanks for the specific info, ideas, and opinions. I want to tag along as much as I can with you 1st gen guys, and hope to learn what you've learned by listening and watching-- and avoid a bunch of interim mods on the way to a set-up that works.
    And thanks as well for the PM link to that awesome Tundras Solutions thread. That has info to help me better understand stuff I've been learning in snippets on here, because the author just defines stuff and explains how its works, doesn't weigh in with his preferences. I love opinions, but when they're opposite, it'll be nice to have this reference I can turn to understand what's actually being compared. Thank you, Luis!
    Darkness[QUOTED] likes this.
  23. Oct 30, 2018 at 3:08 PM
    #53
    Sunnier
    Sunny
    San Diego, CA
    Hahaha! This "Hulk" think is catching on. Maybe I could call it "Bruce" when it's not in Full-Beast mode.... :rolleyes:
  24. Oct 30, 2018 at 3:09 PM
    #54
    Sunnier
    Sunny
    San Diego, CA
    Dang it, not caught up but I gotta get the kid and get to work. I'll check back soon.
    Marty McFly likes this.
  25. Oct 30, 2018 at 3:38 PM
    #55
    Professional Hand Model
    Fred
    Hand Protectors
    I think you’d be amazed at how well these 1st Gens do when kept in stock mode. Those MT tires look sufficient for off road. Maybe get a second set of rims with ATs and swap as needed depending on your mode. Darkness and Casper are pretty dialed in on the off road stuff due to trial and error.
    My 02’ is a TRD as well. She has been kept stock and done some towing and hauling as well as some off road stuff years ago. From my readings on these 1st Gens, once you start getting jiggy with suspension mods its a never ending tail chase fixing things. Also, not many options available out there.
    Those tires are similiar in size to mine and really like the feel compared to the smaller original factory size. Any bigger and the engine would be overwelmed unless you regear both diffs higher. I can barely make it over a parking stop at the mall with 3.91 OEM gears.
    The rear leafs are still firm after all these years. Don’t see a need to mess with them. Did re-build the front suspension in all OEM due to the heaviness up there.
    Sunnier[OP] likes this.
  26. Oct 30, 2018 at 3:57 PM
    #56
    Sunnier
    Sunny
    San Diego, CA
    So.... for fun... would there be long travel shocks I could fit on without cutting the bed right away, start with the right components but do it in stages? Or is there no point. I did see LT 1st gens on a TC site, I think it was Mark sent me.
    Hmmn, maybe I need to take Bruce @papasmurf whatever he drinks, to check out his just done LT 2nd gen and hear him talk.
    papasmurf likes this.
  27. Oct 30, 2018 at 4:01 PM
    #57
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    dude... come over for a beer/wine/whiskey and we can chat
  28. Oct 30, 2018 at 4:06 PM
    #58
    Sunnier
    Sunny
    San Diego, CA
    I'll start researching this stuff. Icons are at the top of my list right now. Well, Icon or ADS. CRCV "clickers", yes. As for the resi's, I don't *need* them, but I might later. :cool:
  29. Oct 30, 2018 at 4:08 PM
    #59
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    @01erionracing he knows some stuff about 1st gens... so does @Rheywood456
    but since neither of them are local i can help you out with fab and build stuff.
    shoot me a PM with your number
  30. Oct 30, 2018 at 4:46 PM
    #60
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    @Sunnier Congrats and welcome to gen 1 club!
