Driver's Side Firewall Grommet For A/V Cable Into Cab
Discussion in '2.5 Gen Tundras (2014-2021)' started by plumber802, Oct 29, 2018.
  1. Oct 29, 2018 at 2:48 AM
    plumber802
    plumber802 [OP] New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    I need to run a small AV cable from the engine compartment into driver's side footwell area.There is lots of info on using the passenger side grommet but not much regarding the one on the driver's side.There is no "nipple" available like on the passenger side.Can I make a small cut in the grommet and pull the cable through with a metal coat hanger for instance?Thanks for any advice.
    dcsleeper408 likes this.
  2. Oct 29, 2018 at 2:51 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Yeah you will be fine running it through there. Just don’t poke or cut any of the wires on the harness.
    831Tun likes this.
  3. Oct 29, 2018 at 3:37 AM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
  4. Oct 29, 2018 at 9:46 AM
    plumber802
    Andy
    Florida/Vermont
  5. Oct 29, 2018 at 3:44 PM
    ZPMAN
    Minnesota
    Did you get a 2nd gen Phoenix HU?
  6. Oct 29, 2018 at 6:28 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    There is a nipple. But it’s at the bottom, not like the passenger side which is at the top and visible. Driver side is under the main harness going into the cab.
  7. Oct 29, 2018 at 6:58 PM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
  8. Oct 30, 2018 at 2:34 AM
    plumber802
    Andy
    Florida/Vermont
