Backup camera at dark
Discussion in 'General Tundra Discussion' started by Zum, Oct 27, 2018.
  1. Oct 27, 2018 at 3:37 PM
    Zum
    Zum [OP] New Member
    NS Canada
    My first vehicle with a backup camera, never thought I'd use the camera much but starting to use it more and more. My issue is at dark, I still like to use my mirrors and I find the screen messes me up a little when looking towards the passenger side(to bright in the cab).The camera itself at dark is not the clearest, I've messed with the brightness and contrast with little success. I've seen where mybe LED bulbs may help? Where do you have your bright and contrast settings at? Im now one notch over half with each.
    trdprobped17 likes this.
  2. Oct 27, 2018 at 3:42 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    The issue is light. If you increase lumens from reverse and license plate bulbs you may get better results. LEDs should help. The camera is just limited from daylite vs. night.
  3. Oct 27, 2018 at 4:48 PM
    trdprobped17
    trdprobped17 New Member
    I agree. More light at night will give you a better visibility. I installed a plug and play led tow hitch light bar and it works very well for me. You can also upgrade your factory backup camera to one that has more led lights for darkness.
    Trooper2 likes this.
  4. Oct 27, 2018 at 8:07 PM
    pitts101
    pitts101 New Member
    2016 TRD Pro
    I’m actually really surprised how much light my stock setup throws out. But add a rigid light or two back there if you want.
  5. Oct 27, 2018 at 8:26 PM
    MotoTundra
    MotoTundra The Ocho
    Don
