New member in Southern IN
Discussion in 'New Member Introductions' started by blackoutt, Oct 24, 2018.
  1. Oct 24, 2018 at 5:39 AM
    blackoutt
    blackoutt [OP] YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    New to me 2007 tundra double cab long bed 4x4 SR5 5.7 here in southern Indiana. I've been a member of the 4runner forums for years and gotten great information sharing through it, so I've come here to learn things about the 2nd gen tundra platform too.
    First question if anyones watching, what's this electrical connector here go to? I've found the electrical diagram pdf but it doesn't show general component location to identify connector number. This is located on the passenger side of the engine bay close to the firewall with a plastic cover over it. For some reason I have a power jumper ran across my engine bay to the pin with the black wire on the connector circled and trying to figure out why.
    weOPUNoyHbTw1dAmu_KsVuS0WYtWy3kCX8pM37Lo_bd647e0aa5064710159a16b76ad9c8a8a40ff32c.jpg
    uChbV7G3d1jHufuiJpGnkIF26cpVyXaZKdN4WuYc_a391d620bac928fe1fa77e70081cf0499918330c.jpg
    T-Rex266 likes this.
  2. Oct 24, 2018 at 5:42 AM
    Grumpy Uncle
    Pat
    CO
    Welcome from Qatar. I don't live here, I'm stuck here. I don't have any input for your question, maybe some will float some options.
    TXMiamiFan and Black Wolf like this.
  3. Oct 24, 2018 at 5:48 AM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    Welcome from East Tennessee. Someone will know.
  4. Oct 24, 2018 at 5:50 AM
    blackoutt
    NWA
    OEM+
    Thanks guys, I posted another thread in the 2nd gen forum too, guess I should show the truck in this thread huh?!?!?
  5. Oct 24, 2018 at 5:52 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!
    We all want to see your rig, even tho it may be generic, show it off! Ty
  6. Oct 24, 2018 at 6:02 AM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Welcome from Oregon!
  7. Oct 24, 2018 at 6:21 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    welcome, okay... From the Couve, WA.
  8. Oct 24, 2018 at 6:25 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Not sure on that connector; but welcome to the forum!
  9. Oct 24, 2018 at 6:26 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Welcome!
  10. Oct 24, 2018 at 6:28 AM
    Welcome from NY.
  11. Oct 24, 2018 at 6:29 AM
    Welcome from Ohio!
  12. Oct 24, 2018 at 6:31 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  13. Oct 24, 2018 at 6:50 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    where? i spent my high school years in princeton...
  14. Oct 24, 2018 at 6:53 AM
    Welcome from CO!
  15. Oct 24, 2018 at 7:06 AM
    TXRailRoadBandit73 YOTAS,RAILROADIN',RĂ–KnRĂ–LLN',BEER,MAX/GEMMA
    Welcome from Texas
  16. Oct 24, 2018 at 7:17 AM
    blackoutt
    NWA
    OEM+
    Columbus Indiana, home of the big red C if you know what I mean.
    smslavin[QUOTED] likes this.
  17. Oct 24, 2018 at 7:30 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from Ca.
  18. Oct 24, 2018 at 7:37 AM
    Welcome
  19. Oct 24, 2018 at 7:37 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  20. Oct 24, 2018 at 7:45 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
  21. Oct 24, 2018 at 8:12 AM
    Tundrablue
    Dave
    Ohio
    Welcome from Ohio
  22. Oct 24, 2018 at 1:21 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  23. Oct 25, 2018 at 5:22 AM
    blackoutt
    NWA
    OEM+
    Very welcoming crew here! No answer to my electrical question found yet but last night I started in on the deep detail of this "clean one owner" truck! I did make $5 in change, mostly from inside the passenger rear footwell vent ducting.
    Cabin air filter was straight up missing, so I added one of those. Also found it has a K&N filter already while I did carbon filter delete and started swapping in some spare interior LED's I had laying around but ran out. Floor liners and window vents show up today. Still need to install dash ram mount. AIP bypass and 2018 take off suspension show up Friday. Then diff and oil change and she's done!
    Black Wolf likes this.
  24. Oct 25, 2018 at 5:43 AM
    A lot of work but it's going to be pretty spiffy!
  25. Oct 25, 2018 at 6:04 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    On that wire issue, I'd get out a 12 volt light circuit tester, hook the clip end to ground and probe that wire. See if that wire is hot with ignition key switch on/ off. Hot with battery only, key off. ? Mabey look for something aftermarket installed on the truck? Follow the wire / wires, tract it down to see where it/they goes. That plug, next to the tie rap, looks like some wire was there? Typically if its a blank you wont see something in that hole. Did the wire next to it brake off and the old owner did what he needed to make things work. Contact the old owner and ask questions if he knew anything about it.? Aftermarket lights, trailer brake module installed? I'm just guessing at this point. Good luck. Welcome aboard too.
  26. Oct 27, 2018 at 7:57 PM
    pitts101
    pitts101 New Member
    2016 TRD Pro
    Welcome from Michigan
