Leaf spring upgrade
Discussion in 'Suspension' started by TxBlaster74, Oct 26, 2018.
  1. Oct 26, 2018 at 8:33 AM
    TxBlaster74
    TxBlaster74 [OP] New Member
    2018 Tundra SR5
    3” lift
    I have a 2018 Tundra with a 3-1 lift. This was installed by the dealership is is great. I would like to increase the weight capacity in the rear. I carry several hundred pounds of equipment daily and occasionally pull a trailer and skidsteer. Would overload springs or helper springs fix this? Can I use that setup with the lift. Thanks from Texas
  2. Oct 26, 2018 at 8:42 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. A new leaf pack is the best way to go. If you weigh it, Deaver or Alcan can make custom springs for your weight.
    JoshuaA likes this.
  3. Oct 26, 2018 at 9:07 AM
    TxBlaster74
    2018 Tundra SR5
    3” lift
    Thank you. I will look into the two suggestions.
    831Tun likes this.
  4. Oct 26, 2018 at 9:11 AM
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
    I went with the icon spring pack option 3
    Currently I have a decked system with 600 lbs all the time
    And definitely load to capacity frequently
    Love the ride
    Only issues were the exhaust tips had to cut off under bed and an extension on brake line tab
  5. Oct 26, 2018 at 9:25 AM
    TxBlaster74
    2018 Tundra SR5
    3” lift
    I’ll look at Icon also. I like the stance with the 3-1. I wouldn’t mind a taller lift, but chose this option at the time of purchase. And having more than a 4 lift would make it more cumbersome to work out of everyday. Glad I got on this forum. I definitely have more plans for my truck.
  6. Oct 26, 2018 at 9:49 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    I'm just not understand why folks are avoiding the add a leaf.
    OBXTundra likes this.
  7. Oct 26, 2018 at 10:00 AM
    COTundraRoamer
    COTundraRoamer New Member
    Dustin
    Denver, CO
    18' Platinum CM
    Fox 2.5 DSC front, Fox 2.5 DSC rear. JBA UCA. SCS Ray10 custom powder coated on 285/75r18 Duratracs.
    From my reading and experience it's a short term solution to a long term problem.
    Mwray8909 likes this.
  8. Oct 26, 2018 at 10:07 AM
    Mwray8909
    Chino Valley
    I mean if I'm running a spring helper and an Add a leaf for a year or two for towing I'm fine but need to do a full leafpack swap in the long term.
  9. Oct 26, 2018 at 10:19 AM
  10. Oct 26, 2018 at 11:30 AM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    I have the icon rxt leaf pack! It’s awesome I have it on option 4 I used it to replace my 4in lift block! But now when I put stuff in the bed, it won’t bottom out like before! Handles weight greatly!
    Black Wolf likes this.
  11. Oct 27, 2018 at 6:28 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
