Low Beams Are Out!!!
Discussion in 'Lighting' started by JAC53, Oct 26, 2018.
  1. Oct 26, 2018 at 2:12 PM
    JAC53
    JAC53 [OP] New Member
    Jordan
    2008 Tundra Base Double Cab 4x4 5.7
    The other morning, I started my truck up and when I turned the headlights on, the both immediately shut off. This happened a couple months ago to, so I bought new ones, replaced them and they worked fine even though I thought it was weird that they would both burn out at the same time. Also while driving to work, all the lights on my dash light up at once, then my truck sounded like it wanted to stall out. Don't know what the deal is, but my fuses are good, battery is good and like I said, the headlights are just a few months old. Help please!
  2. Oct 26, 2018 at 2:14 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    Not an issue im familiar with but you are in the right spot. Someone will chome in shortly
  3. Oct 26, 2018 at 2:20 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Welcome from SE VA...;)
  4. Oct 26, 2018 at 2:22 PM
    15whtrd
    15whtrd Mr. Blonde
    I had a similar issue on a previous vehicle. It’s unlikely for them both to go out at the same time unless there’s a short somewhere. The problem I found on my previous vehicle was the headlight relay was bad. I tested this theory by swapping it with another relay (same PN) that I knew was working from the fuse box.
    JAC53[OP], T-Rex266 and MotoTundra like this.
  5. Oct 26, 2018 at 2:24 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I am not a tech but I would guess it's a relay.
    JAC53[OP] and 15whtrd like this.
