Advice on bigger tires please
Discussion in 'Wheels & Tires' started by Itsjustmelfg1964, Jun 28, 2016.
  1. Jun 28, 2016 at 5:39 PM
    Itsjustmelfg1964
    Itsjustmelfg1964 [OP] New Member
    Lisa
    Parkland, Fl
    2022 Limited CrewMax
    2014 Crewmax has stock Bridgestone Dueller 275/55/20 tires and I would like to go a bit taller without the tires hitting anything when I turn. I dont have any modifications aside from the K&N cold air intake that I put on. Does anybody know the biggest size I can put on. I do not want those big chunky man looking tires. I am thinking about Michelins. Any advice would be greatly appreciated.
  2. Jun 28, 2016 at 6:25 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I don't know how big you can go with keeping everything stock and not trimming anything.
    On my previous truck, which was a Tacoma, I went up to the next size and didn't have any rubbing issues. The tires were a bit wider and a bit taller, not by much though. I think they looked a bit better and I could care less but they probably hurt my MPG's a bit.
    What is the reason you are looking for a taller tire?
    A small lift and wheel spacers or wheels with a different offset would help if you want to go bigger, but you may have to do some trimming.
  3. Jun 29, 2016 at 4:55 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    I run 275/60R20 on my stock suspension and limited wheels (+60 offset) Pretty sure that's as big as you can go.
    CaptTyler and MotoTundra like this.
  4. Jun 29, 2016 at 9:36 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    275/60/20 or 285/55/20.
    MotoTundra likes this.
  5. Jun 30, 2016 at 8:14 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
