2018 cargo light wire
Discussion in 'Lighting' started by Squatchtundra, Feb 5, 2018.
  1. Feb 5, 2018 at 6:34 PM
    Squatchtundra
    Squatchtundra [OP] Hammer Down
    Olympic Peninsula
    2018 limited cm MGM
    Kings and Total Chaos UCA with ko2's
    Just in case anyone is wonder8ng how to tap into the cargo light wire on a 2018 CM Limited, I have found it. It has been either a brown wire or grayish purple on previous threads but turns out mine was the pink 18 gauge wire in the driver's side rear door seal. Hope this help for people trying to hook up bed lights or something.:):)
  2. Feb 6, 2018 at 3:49 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    There are also the actual Toyota bed light instructions for the 2018 Tundra posted in another thread. They address the correct wiring.
  3. Apr 20, 2018 at 1:12 AM
    Tundrax
    Tundrax New Member
    2018 SR5 CM Inferno
    TRD Rear Sway Bar, X-15 Tonneau, Weathertech, Bedmat, Bed Step, Bed LEDs...
    Thanks!! That helped a lot - after the black, brown, and greyish wires did not deliver any current I was about to check them all - your 18 GA pink wire (the larger of the two pinks) clue saved the evening - or at least 30 minutes and frustration!
    Bed lights done and they work great! Horns next... I took the red horns apart and painted the grates/cages/grills (whatever those are called) orange to match my inferno - they will be seen a bit behind the grill. Thanks again!!
  4. Sep 27, 2018 at 8:11 AM
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    can anyone update this with the correct wire color for a 2016?
    831Tun likes this.
  5. Sep 27, 2018 at 9:09 AM
    pmcgeorge1964
    pmcgeorge1964 New Member
    Paul
    2018 Tundra TRD Quicksand
  6. Oct 17, 2018 at 6:22 PM
    Lynch
    Lynch New Member
    2018 Tundra Limited CM
    New guy here, looking to wire bed lights into cargo switch. Would anyone have pics for the process? More of a visual learner. Have a 2018 CM limited.
  7. Oct 17, 2018 at 6:24 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    It's a small brown wire in my '16
    dcsleeper408 likes this.
  8. Oct 17, 2018 at 6:26 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Just pull up the driver side, plastic sill. Below it you'll find a bunch of wires. Above it says it's the larger of the 2 pink wires for an '18
  9. Oct 17, 2018 at 6:31 PM
    Lynch
    Lynch New Member
    831TUN
    Thank you, need all the help I can get. Not completely incompetent just unsure. The pink is where the pos wire ties in, what of the other?
    831Tun likes this.
  10. Oct 17, 2018 at 6:42 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The other, for your lights should be black and goes to ground. There's a cover, down low in front of the driver door and just below the dash. It's held in by 1 plastic nut close to the firewall. The cover slides aft when removing. Behind this cover is a great place to connect the ground. You'll see a bolt that already has several grounds connected.
  11. Oct 17, 2018 at 6:45 PM
    Lynch
    Lynch New Member
    Thank you. A life saver.
  12. Nov 11, 2018 at 4:39 PM
    510Krish
    510Krish New Member
    2018 Toyota Tundra Platinum 4x4
    Just to make sure guys, is it the wire on the left side? Above the tape.
  13. Nov 12, 2018 at 7:41 PM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    Hi, sorry but I had the hardest time trying to find that "pink" wire in the driver side door seal. Can you or someone take a photo of your actual wire connected? I have all my wires ready to go but couldn't find it and didn't want to play trial and error. Thanks in advance.
  14. Nov 12, 2018 at 8:25 PM
    510Krish
    510Krish New Member
    I have the strongest belief that it is the wire on the left side. Look at the attached picture. The bigger wire of the Two pink
  15. Nov 12, 2018 at 9:00 PM
    phabej
    phabej New Member
    That's right by the sill driver door area? I'll try that tomorrow , thanks
  16. Nov 12, 2018 at 9:07 PM
    510Krish
    510Krish New Member
    Yes, it is behind the driver door. So the rear door behind the passager. You will have to cut some tape and get inside the wire loom
  17. Nov 13, 2018 at 5:30 PM
    phabej
    phabej New Member
    Completed. Thanks for the help. It was the pinkest wire.
    Samurai and KnuckleHD like this.
  18. Nov 13, 2018 at 5:34 PM
    510Krish
    510Krish New Member
    Ok, now that I helped you. How the hell did you get the wires from back there into the car???
  19. Nov 13, 2018 at 5:50 PM
    phabej
    phabej New Member
    Ran the wire through the hole that was already exiting in the bed. I ran the wire in a wire loom underneath the truck and came out through the front passenger grommet.
    SiberianTundra likes this.
  20. Nov 13, 2018 at 5:53 PM
    phabej
    phabej New Member
  21. Oct 18, 2019 at 8:55 PM
    Samurai
    Samurai 2018 tundra crew max sr5
    Can I use pink wire ? Do I need a fuse holder ? Thank you!
  22. Nov 10, 2019 at 10:30 AM
    Samurai
    Hey does anyone know the location for the pink wire for the cargo light. The top circle of bottom circle? Thanks for the help
  23. Nov 10, 2019 at 6:58 PM
    phabej
    phabej New Member
    its up to you. I didn't.
    Samurai[QUOTED] likes this.
  24. Nov 12, 2019 at 6:24 AM
    Samurai
    Thanks for the reply. I can’t find the wire for the cargo light. I tried the all pink wire
  25. Apr 21, 2020 at 7:27 AM
    pv355
    pv355 New Member
    Peter
    2018 CM SR5 5.7L 4x4 in Gray
    Installed: TRD Rear sway bar HIKARI Ultra LED H4 & HIKARI LED H11 Power tailgate lock JBL Stadium 5 + JBL GTO609c Kicker 43TCWRT102 in passive radiator box Waiting on install: Wishlist: Component speakers Leather seats + vented/heated Puddle lights Illuminated ignition ring ESP Rear seat storage Chrome grille delete Parking sensors
    Hey Samurai,
    did you figure it out? i am trying to install puddle lights in my 2018 CW SR5 and i tried all the pink wires too.
    Thanks!
    Toptalktoyota likes this.
  26. Apr 21, 2020 at 9:41 AM
    pv355
    pv355 New Member
    Peter
  27. Aug 21, 2020 at 3:36 PM
    Samurai
    Hey Peter.
    Which wire is for the cargo light ? Do you have pictures or videos how to install the puddle light side mirror?
  28. Apr 18, 2023 at 7:27 AM
    kramynke
    kramynke New Member
    2021 TRD PRO
    Was it the larger of the two pink ones?
