Bad shock?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by InfernoPro15, Oct 17, 2018.
  1. Oct 17, 2018 at 2:19 PM
    InfernoPro15
    InfernoPro15 [OP] New Member
    So I recently bought my pro and I'm noticing that if I hit a good size bump or a dip on the road I feel thud and stop of travel in the front suspension (sounds like only driver side), sounds like a bump stop but we are talking regular day driving not baja blasting. Bad shock? Or is it normal? Don't see any leaking.
    Watt maker likes this.
  2. Oct 17, 2018 at 2:24 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Those aren't stock size tires are they.
  3. Oct 17, 2018 at 2:25 PM
    InfernoPro15
    they are not, threw those on a few days ago, the issue im describing was with it completely stock and now
  4. Oct 17, 2018 at 2:27 PM
    Does it happen during slow speeds over bumps too?
  5. Oct 17, 2018 at 2:32 PM
    InfernoPro15
    theres a dip on the road around a sewer drain at work parking lot maybe half a foot deep, i can hit it 10mph and its a very distinctive thud
  6. Oct 17, 2018 at 2:34 PM
    InfernoPro15
    If it was normal everyone with a Pro would know exactly what i'm talking about because its pretty distinctive and not hard to replicate. Looks like i have a bad shock on my hands.
  7. Oct 17, 2018 at 2:40 PM
    I had this issue on my first set of SPC UCA’s that ended up being a bad UBJ.
  8. Oct 17, 2018 at 2:44 PM
    InfernoPro15
    hmmm that would def be cheaper to replace, thanks for the idea.
  9. Oct 17, 2018 at 3:47 PM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    Before you go and change suspension, you might want to check the pro skid plate. I (and many other pros) had a clunk. I heard it most when pulling into the little dip of a driveway. I took it to deer and the skid plate was installed wrong.
    15whtrd and TheBeast like this.
  10. Oct 17, 2018 at 4:35 PM
    TheBeast
    TheBeast The Beach
    I was gonna say..check the TRD pro skid plate too.
  11. Oct 17, 2018 at 4:59 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    I think know what you're talking about. When I go over a drain or dip in the road too fast its like the front hits the bump stops real quick with not much up travel in the suspension. Does that sound like what you are feeling?
  12. Oct 17, 2018 at 5:03 PM
    InfernoPro15
    sounds spot on
  13. Oct 17, 2018 at 5:07 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    I think it's normal maybe we're just going over bumps too quickly? If not, we both have a bad shock haha
    InfernoPro15[OP] likes this.
  14. Oct 17, 2018 at 5:09 PM
    InfernoPro15
    lol it could be normal i just find it ironic that i can hit worse bumps and dips with my tacoma all it has is 5100s and takes it like a champ and here we have a $40k+ pro that sounds like its bottoming out. Maybe extra weight is a factor, not sure.
  15. Oct 17, 2018 at 5:12 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    Agreed, I came from a Tacoma and never had an issue when I hit dips, but this thing BA-BOOM!
  16. Oct 17, 2018 at 6:33 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Check the skid plate, if you see the sway bar there, toss it to the trash. It shouldn’t be on the pro anyways
