Blown rear end?
Discussion in '1st Gen Tundras (2000-2006)' started by The tundy, Oct 16, 2018.
  1. Oct 16, 2018 at 6:43 AM
    The tundy
    The tundy [OP] New Member
    2001 tundra limited
    My 2001 tundra has been having a problem for the past couple months where when I put it in reverse there’s a jolt and clunking noise when I put it in reverse. Just last night while driving on the highway doing about 65 mph I took my foot off the gas pedal and there was this horrible sound. Kinda like metal hitting metal. From what I found driving it home was it only does this if I hit the brakes hard or immediately take my foot off the gas. What I’m wondering is if The entire rear end is trashed and if so just as a thought would swapping it with the heavier duty axle used in the second and third gen tundras be worth it?
  2. Oct 16, 2018 at 7:05 AM
    15whtrd
    15whtrd Mr. Blonde
    Check your Ujoints and center carrier bearing.
    Festerw, Mwray8909 and lsaami like this.
  3. Oct 16, 2018 at 7:55 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    take a look. Like 15whtrd said, check out your drive shaft, u-joints and center support bearing. If those are all fine, drain your rear end fluid to look for metal shavings.
    15whtrd likes this.
  4. Oct 16, 2018 at 8:26 AM
    15whtrd
    15whtrd Mr. Blonde
    Exactly. There will be a small amount of metal shavings but if there is chunks and a lot of fine material you may have an issue.
    lsaami[QUOTED] likes this.
  5. Oct 16, 2018 at 8:30 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    @15whtrd is probably right on the money with the ujoints....
    15whtrd likes this.
  6. Oct 16, 2018 at 9:05 AM
    Marty McFly
    Morty McBoonJug
    Seeing the title I thought this thread was going to be different :anonymous:
    Pinay, Tacotundra, bmf4069 and 4 others like this.
  7. Oct 16, 2018 at 9:10 AM
    Usually the thread starts out like “I have a noise coming from my rear end” and goes downhill from there.
    Pinay, bmf4069, Coolhardy and 4 others like this.
  8. Oct 16, 2018 at 9:13 AM
    Marty McFly
    Morty McBoonJug
    All I’m going to say is don’t google “blown rear end” :anonymous:
    Pinay and Darkness like this.
  9. Oct 16, 2018 at 9:14 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    or, worse still... "I drained the fluid from my rear end...."
  10. Oct 16, 2018 at 9:20 AM
    Marty McFly
    Morty McBoonJug
    Maybe it should be “I have shards of metal in my rear end” :anonymous:
    bmf4069, tomsinamerica and Darkness like this.
  11. Oct 16, 2018 at 9:26 AM
    Mwray8909
    Chino Valley
    "Will someone check into my rear end?"
  12. Oct 16, 2018 at 11:56 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    That and check that the slip joint is moving freely.
  13. Oct 16, 2018 at 12:17 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've been there. Sounds like it's on it's way out from my experience.
    When mine started acting up it made noises that sounded like empty beer cans bouncing around on hard deceleration or when I lifted off the gas at highway speed. Eventually it locked up on me during street driving a few times, often feeling like the rear brakes locked up but twice it jumped as if I hit an invisible speed bump.
    The way I checked was I put my rear axle up on jack stands, kicked and rocked my truck trying to make it fall off and when it didn't I knew I could do a dangerous test. I put it in drive and let it idle with my buddy in the driver seat just in case. Then crawled under the rear bumper and listened. I extended a copper pipe (had some in the bed, hose or screw driver works too) against the rear end and put the other end to my ear, I heard very clear clunkity-clunk as the wheels spun.
    I took the opportunity to buy 4.56 Nitro gears and a Kazuma LSD. Had a shop do the install for $400 flat.
  14. Oct 16, 2018 at 3:55 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Try greasing the zerks on prop shaft? Sounds like maybe bad carrier bearing?
    How many miles did your guys’ rear ends go out? Serious question.
    My next Prevent Maintanence job is going to be all new u-joints on the rear prop and also a new carrier bearing since its all connected.
    I see Toyota sells an OEM dust cover for the slip joint for $12. Can’t remember if mine came with it new?2002 Tundra SR5 V8 4wd. I know when I grease the rear zerks it squeezes out the slip joint. Never knew they sold a cover for it.
    Also, there are spider joint kits for different models. Each year is slightly different even within each year they are diferent depending on 4wd or the 6 cyl vs 8 cyl models.
    I’ll post up pics of the parts later, but found this online dealer site with good OEM prices vs. my local stealership. https://www.toyotapartsdeal.com/
  15. Oct 16, 2018 at 7:42 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Mine was around 130k. On the open diff carrier theres a main pin held in place by a clip. The clip snapped and the pin was sliding out of its hole. When it slid out it was dragging across the ring gear, when it went out far enough it locked, I assume getting between ring and pinion. I looked over the remains, I was surprised I drove on it about 600 miles thtlat way.
    Mine was either bad luck or a result of duck walking off road. I had taken an off road detour on my way home from work for a few months before it happened.
  16. Oct 17, 2018 at 7:30 PM
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    I googled it, it was actually blown rear diff gears that popped up not anything else
    Marty McFly[QUOTED] and Darkness like this.
  17. Oct 17, 2018 at 8:18 PM
    Marty McFly
    Morty McBoonJug
    Maybe that’s because I google rear ends a lot o_O
    15whtrd likes this.
  18. Oct 17, 2018 at 8:26 PM
    15whtrd
    15whtrd Mr. Blonde
    On Pornhub ;)
    Marty McFly[QUOTED] likes this.
  19. Oct 17, 2018 at 8:39 PM
    Marty McFly
    Morty McBoonJug
    No comment sir LOL :anonymous:
    15whtrd[QUOTED] likes this.
  20. Oct 17, 2018 at 8:39 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Here’s the most famous blown rear end in history...
    1UPPER, Marty McFly and 15whtrd like this.
  21. Oct 23, 2018 at 10:14 AM
    Need to know stuff
    That rear end is definitely getting blown.
    gosolo[QUOTED] and 15whtrd like this.
  22. Oct 23, 2018 at 10:39 AM
    15whtrd
    15whtrd Mr. Blonde
    Mmmmm
  23. Oct 23, 2018 at 2:48 PM
    Fred
    Hand Protectors
    Thats how I feel after doing work on my Tundra.
