Anza Borrego Oct 12-14
Discussion in 'California' started by osidepunker, Oct 5, 2018.
  1. Oct 14, 2018 at 9:51 PM
    #61
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    What’s a great weekend with all carnage.
    I have too much fun on the Powerline road and ended up like thisA9D9E08B-AD98-492C-B6B1-64DEBD95B0F2.jpg226AFDB3-305A-4F27-A859-30EC21F7D18B.jpg
    KevinK, Marty McFly, joonbug and 5 others like this.
  2. Oct 14, 2018 at 9:58 PM
    #62
    I have no idea what that means?
    Marty McFly, Sunnier and SoCal619 like this.
  3. Oct 14, 2018 at 10:00 PM
    #63
    That looks like a man that wheels hard, but goes home in style. I like it!
  4. Oct 14, 2018 at 10:01 PM
    #64
    Lol. Yep.
    I won’t even run that trail anymore if rain is in the forecast in a 50 mile radius.
    SoCal619 likes this.
  5. Oct 14, 2018 at 10:06 PM
    #65
    The desert is no joke.
    01erionracing, papasmurf and SoCal619 like this.
  6. Oct 14, 2018 at 10:16 PM
    #66
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Damn Jimmy!
    joonbug, dcsleeper408 and ColoradoTJ like this.
  7. Oct 15, 2018 at 6:19 AM
    #67
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    It was an eventful weekend with weather, an epic stuck and a broke with a MacGyver type (@osidepunker) trail fix. So much fun.
    That spot Alex was stuck in was so deep and thick a dirt bike tried it and had to be towed out.
    Lined up under the railroad tracks.
    Trooper2, joonbug, 831Tun and 7 others like this.
  8. Oct 15, 2018 at 6:28 AM
    #68
    jc153
    San Diego
    Here a pic of the dirt bike in the same spot Alex was in.
    Trooper2, joonbug, 831Tun and 8 others like this.
  9. Oct 15, 2018 at 8:47 AM
    #69
    n2deep
    n2deep Pavement Princess
    So what exactly happened - Lost the bolt or something broke? Can't really tell in the pic other than a rod is thru the uniball and strap holding it in place
  10. Oct 15, 2018 at 9:05 AM
    #70
    osidepunker
    osidepunker [OP] OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    The collar at the top of the spindle that holds the uniball bolt snapped
    SoCal619 and 01erionracing like this.
  11. Oct 15, 2018 at 9:15 AM
    #71
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    i miss so cal....
    Sunnier likes this.
  12. Oct 15, 2018 at 9:54 AM
    #72
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Jimmy, I see you gave into Alex's peer pressure and painted your bumper RED!!
    Looks sweet
    I'd still love to see some of those Trona sunset pics if you get a chance
    01erionracing likes this.
  13. Oct 15, 2018 at 9:57 AM
    #73
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Where's the recovery video???!!!!
  14. Oct 15, 2018 at 10:05 AM
    #74
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  15. Oct 15, 2018 at 10:11 AM
    #75
    01erionracing
    Jimmy
    With @osidepunker ingenuity engineering taking the bottle jack handle, hose clamp, strap and ratchet I was able to drive my truck to the pavement.
  16. Oct 15, 2018 at 10:20 AM
    #76
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    That's insane, I had no idea it could get like that.
  17. Oct 15, 2018 at 11:07 AM
    #77
    n2deep
    Still not sure what actually broke? Looks like just the bolt is missing. Mine doesn't have a collar at the top only a bolt that goes thru the uniball to the spindle. The uniball is held in with a clip on the bottom and sits against the cup. Maybe it's different than mine- but like to know in case I need to throw something in the random box for possible trail fixes.
  18. Oct 15, 2018 at 11:15 AM
    #78
    n2deep
    [​IMG] You mean the uniball spacer that sits in the uniball broke? Maybe I need to throw one in my parts bin.
  19. Oct 15, 2018 at 11:17 AM
    #79
    01erionracing
    Jimmy
    @n2deep Please see the photo below, the highlighted piece was broke off so I removed the bolt, nut upper and lower spacer of the uniball so I can put the bottle jack handle to strap the UCA to the steering knuckle.
  20. Oct 15, 2018 at 11:17 AM
    #80
    roypark
    roypark Semi-pro High Fiver
    Roy
    Orange County
    2016 Tundra
    A little of this and a little of that. Its pretty run of the mill.
    Just put spare spindles in the random box.
    sdde4n, papasmurf and 01erionracing like this.
  21. Oct 15, 2018 at 11:25 AM
    #81
    n2deep
    Ahhh got it- the actual spindle - I was thinking something on the UCA broke since there was no bolt. Got it.
    osidepunker[OP] likes this.
  22. Oct 15, 2018 at 11:28 AM
    #82
    n2deep
    Don't you have a case to be in about now - Troll :lalala:
    papasmurf likes this.
  23. Oct 15, 2018 at 1:31 PM
    #83
    Sunnier
    Sunny
    San Diego, CA
    Crazy mo'fo genius fix right there. Jimmy, you and Alex @osidepunker got mad McGyver skillz!
  24. Oct 15, 2018 at 2:37 PM
    #84
    roypark
    Roy
    Orange County
    2016 Tundra
    Nope. I troll full time now. Hahaha.
    papasmurf and n2deep[QUOTED] like this.
  25. Oct 16, 2018 at 8:45 AM
    #85
    osidepunker
    Alex
    2013 Tundra DC 4x4
  26. Oct 16, 2018 at 9:19 AM
    #86
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    Damn, I hope we have even half that much fun this weekend. Looks like I missed a damn good time.
  27. Oct 16, 2018 at 10:59 AM
    #87
    jc153
    San Diego
    It was a really fun trip. I just remembered, to the right of us in that photo under the railroad tracks bridge there is a running stream. It was flowing pretty good. I wish I would have taken video of us going through it. The crossing was short and simple but I have never personally seen that much running water in that spot before.
