New tundra horrible mpg
Discussion in '2nd Gen Tundras (2007-2013)' started by Pholt, Oct 13, 2018.
  1. Oct 14, 2018 at 4:04 PM
    #121
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    have you tried hand calculating?
    Lake.Life24 likes this.
  2. Oct 14, 2018 at 5:52 PM
    #122
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    Is that after its broken in? That's amazing
  3. Oct 14, 2018 at 6:13 PM
    #123
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I have a 13 tundra crewmax with the 5.7 flex fuel.running 305/55/20's 3/1 lift with tonneu cover.getting 13.5- 14.3 mpg. Not bad but,the day I brought the truck home I got 17.1 mpg ? I don't know what they did or what kind of gas they used but I haven't been able to do it again. I've had the truck 6 months now?
    P rod likes this.
  4. Oct 15, 2018 at 9:26 AM
    #124
    Pholt
    Pholt [OP] New Member
    Paul
    2011 tundra trd flex fuel
    6" lift 35" tires
    Okay here is part of the problem. there is something wrong with the truck. Here is my tuner reading alcohol content with pure gasoline.
  5. Oct 15, 2018 at 9:26 AM
    #125
    Pholt
    Paul
    6" lift 35" tires
  6. Oct 15, 2018 at 9:27 AM
    #126
    Pholt
    Paul
    6" lift 35" tires
    Yes
    4x4_Angel[QUOTED] likes this.
  7. Oct 15, 2018 at 9:36 AM
    #127
    Pholt
    Paul
    6" lift 35" tires
    For all of the people that said I was complaining and to live with it. here is what is wrong. ;)
    It is in the shop right now Toyota is going to do the ECM update and reset all of the fuel curve and learn parameters. But reading 72% alcohol content in gasoline that is straight gas no ethanol is a problem. This is why this truck gets horrible gas mileage. When you figure out BTU loss and put the math to it it takes about 1.8 units of ethanol to equal 1 unit of gasoline. This thing is shoving pure gas in it as fast as it can drink it and it is not using it efficiently. Also the flex-fuel trucks have a 3-speed fuel pump so they can supercram fuel into the injection system when it reads a high content of ethanol.
    We'll see how it improves once it's fixed. This truck should be able to get at least 12 miles per gallon . And if you do not see a 20% difference or so between ethanol and regular gas something is wrong with the truck. It's basic math.
    And like I said I love the truck. And it is new to me. But if this new truck cannot get better gas mileage than my 1986 Ford F150 with bigger tires then yes I will sell it as fast as I can get it put up. There is no reason a new truck that is lighter smaller cannot get better gas mileage than truck is 30 years old. There's no reason. Hopefully they get it fixed. And then I'm heading to Texas tomorrow to have d. A. P. tuning tune it. :fingerscrossed:
  8. Oct 15, 2018 at 9:41 AM
    #128
    15whtrd
    15whtrd Mr. Blonde
    Good luck I bet you it will be better once it’s updated. Please post an update after you drive around for a little bit. Fingers crossed. I bet you’re excited about that dap tune too! If you end up keeping the truck maybe re-gearing will make it even better.
    Grumpy Uncle and 4x4_Angel like this.
  9. Oct 15, 2018 at 9:45 AM
    #129
    Barbsaurus
    Barbsaurus New Member
    Columbia SC
    2018 Platinum Crewmax 4x4 Super White...Fastest Color!
    "completely flat"...more like down hill with the wind at your back...
    TunderStorm[QUOTED] likes this.
  10. Oct 15, 2018 at 9:46 AM
    #130
    Pholt
    Paul
    6" lift 35" tires
    The truck that have the old programming in it. They updated it for $75. I'm fixing to head to Texas tomorrow I will see what this computer update did as far as highway mileage pretty quick
  11. Oct 15, 2018 at 9:48 AM
    #131
    Well...that is good. Hopefully solves your mpg issue. :thumbsup:
  12. Oct 15, 2018 at 10:28 AM
    #132
    4x4_Angel
    Bree
    Funky Town, Texas
    Where in Texas are you heading?
  13. Oct 15, 2018 at 1:15 PM
    #133
    Pholt
    Paul
    6" lift 35" tires
    Houston
  14. Oct 15, 2018 at 1:17 PM
    #134
    Pholt
    Paul
    6" lift 35" tires
    Ok. I had Toyota update the computer to the newest version of software and he reset everything. He said if it was a person it wouldn't know its own name. I had ethanol in the truck I tried to run it dead empty I had about 2 gallons left. I just filled it up with fresh gas the alcohol readings are much better and I reset my average miles per gallon which I've done several times it has never read this hi. Hopefully it's better.
    Tundra Fan, Ericsopa and 15whtrd like this.
  15. Oct 15, 2018 at 2:41 PM
    #135
    4x4_Angel
    Bree
    Funky Town, Texas
    Hope everything works out for you!
    Pholt[QUOTED][OP] likes this.
  16. Oct 15, 2018 at 3:49 PM
    #136
    Pholt
    Paul
    6" lift 35" tires
    I'm going to tell you guys right now I do not recommend d a p tuning at this point. I was going to drive 400 miles out of my way to have them tune this truck at the tune of $400 to $700. I was going to fly to Houston instead I decided to drive and just take the tundra
    by there and have it tuned. Per their operating business hours. I called somebody last week and it said it only takes about 15 minutes.
    Talk to one of the guys at the shop today that knows nothing about it. Supposed to have the owner call me back or someone that knew something about tuning a tundra. Couldn't get a return phone call. I have been self-employed since 1997 and I have owned many retail businesses. If a customer is coming 400 miles to my business I think I would definitely call them back. He said the owner was pretty busy but, I've seen their building. They ain't too big to return a phone call. I have renntech in Florida tune all of my Mercedes amg cars and they are Huge. I can get a call back in a few minutes. And I have to ship my cars there to have them tuned.
    Bad business, I will ship it to vivid racing in Arizona before I use these guys. I now have to drive to Houston instead of fly for no reason. pretty pissed off.
  17. Oct 15, 2018 at 4:04 PM
    #137
    Nick T
    Nick T New Member
    2 gals e85 + 24 gals e10 would be around e15 you are still reading 31% instead of 15%. I suggest you get techstream (do a search) and reset the sensor yourself.
    Good luck
  18. Oct 15, 2018 at 6:11 PM
    #138
    Pholt
    Paul
    6" lift 35" tires
  19. Oct 15, 2018 at 6:13 PM
    #139
    Pholt
    Paul
    6" lift 35" tires
    I know what techstream is and the Lite version I think is $1,200 I think I'll pass.
  20. Oct 15, 2018 at 6:14 PM
    #140
    Pholt
    Paul
    6" lift 35" tires
    I'm going to run a few tanks through it and see what it does
    4x4_Angel likes this.
  21. Oct 15, 2018 at 6:16 PM
    #141
    Pholt
    Paul
    6" lift 35" tires
    I just tested the alcohol content again and it's dropped 23%. I bet I might have to get all that E85 out of there. Then we'll see what it does
    4x4_Angel and 15whtrd like this.
  22. Oct 15, 2018 at 6:42 PM
    #142
    BassRunner
    BassRunner New Member
    Kenny
    Lexington. South Carolina
    2018 Limited
    If you buy a Trunda for MPG your in the wrong truck on my 4th one and I didn't buy them for gas mileage. I bought them because I love it and it's a Trundra! Use to be a hard core Chevy guy even had a lab named Chevy.
    Mikekoot likes this.
  23. Oct 15, 2018 at 6:43 PM
    #143
    15whtrd
    15whtrd Mr. Blonde
    Go back and read everything and you’ll understand.
    Atlas415, Newm and Tundra Fan like this.
  24. Oct 17, 2018 at 10:46 AM
    #144
    Mikekoot
    Mikekoot New Member
    Canadia
    Then why reply? First gen was designed by a Japanese team. 2 and 3rd gen by an american team.
    JoshuaA likes this.
  25. Oct 17, 2018 at 2:21 PM
    #145
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    Meh....
    I just drove 1100 miles. New 1794 stock 5.7 (no ffv) engine, tonneau cover, no load, Bilstein level, Ridge Grappler 33’s, 87 octane, 95% highway miles @ 75mph: Averaged 15.4 mpg hand calc.
    Did the same drive with my 2010 F150 and was getting about 18-19 6 months ago.
  26. Oct 17, 2018 at 4:24 PM
    #146
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    That should be added in the thread title. People see these threads and don't even read them, then make comments like that.
    pholt, thank you for updating us on the outcome, it sounds like everything is getting back to "normal" with your truck. Stick around, this is actually a really good forum.
  27. Oct 18, 2018 at 7:01 AM
    #147
    BassRunner
    Kenny
    2018 Limited
    I did and I'm sorry I misspoke I heard people complain gas mileage for year's
    4x4_Angel, KMG, Grumpy Uncle and 2 others like this.
  28. Oct 18, 2018 at 7:55 AM
    #148
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You can pick up the cable and software for like $20.
    GNTundra likes this.
  29. Oct 18, 2018 at 9:37 AM
    #149
    Pholt
    Paul
    6" lift 35" tires
    I did not buy it I traded for it it was a mistake.
  30. Oct 18, 2018 at 9:39 AM
    #150
    Pholt
    Paul
    6" lift 35" tires
    Show me where please
