2014 auto head lights?
Discussion in '2.5 Gen Tundras (2014-2021)' started by rummy727, Oct 14, 2018.
  1. Oct 14, 2018 at 7:43 AM
    rummy727
    rummy727 [OP] New Member
    I've got a 14 SR5 crewmax, do they auto head lights? If so, I can't figure it out!
  2. Oct 14, 2018 at 7:48 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Nope. I wish they did.
  3. Oct 14, 2018 at 8:02 AM
    rummy727
    Man, that's crazy!! My 03 S-10 has them! . Thanks
  4. Oct 14, 2018 at 8:12 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    That's one thing I missed coming from gm. Everything I've had since 1999 had them.
    That said, all you need is a sensor and a new switch stalk. I put the sensor in the center speaker grill, had a mechanic pull the steering wheel and replace the stalk. I didnt want to mess with the airbag.
    One of the best mods I've done .
  5. Oct 14, 2018 at 8:18 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Dumb question, my 04 you can just leave the lights on and they automatically turn on with the ignition and off when you shut down and open the drivers door. Do the newer trucks not do that?
    I understand that's not automatic but it's cheaper than changing parts.
  6. Oct 14, 2018 at 8:19 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Current gens do that as well, but you'd have your lights on day and night.
  7. Oct 14, 2018 at 8:41 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    That's awesome!
    I agree OP, it's quite pathetic.
  8. Oct 14, 2018 at 9:25 AM
    rummy727
    My 14, if I leave the lights on and kill the ignition and remove the key, a beep goes of continuously until I turn them off.
    Rocko9999 likes this.
  9. Oct 14, 2018 at 10:02 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Limited or better trims come with auto headlights.
    You can always leave them on then when you get out of your truck press the lock button on the remote 2 times. The 2nd lock will turn the headlights off.
    kparrow and dandailey like this.
  10. Oct 14, 2018 at 10:05 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I forgot to mention, mine was prewired for the sensor. It's all plug and play. Check under your center speaker grill for wiring to the "dummy" sensor.
  11. Oct 14, 2018 at 11:15 AM
    binaryhansolo
    binaryhansolo New Member
    2015 Toyota Tundra SR5 Double Cab
    None, yet.
    It's probably an SR5 thing, I have a 2015 and no auto headlights. I was quite surprised also. Seems like Toyota needs some catching up to do, not that anyone else recognizes that ;)
    Hondoman likes this.
  12. Oct 14, 2018 at 11:18 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    How about if you open the drivers door after the key is removed?
  13. Oct 14, 2018 at 11:22 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    Wow. You just learned me something new :hattip:
  14. Oct 14, 2018 at 11:54 AM
    binaryhansolo
    None, yet.
    The headlights stay on regardless. Even after shutting and locking the doors (to include hitting the button twice).
    Edit: (to include hitting the button twice).
  15. Oct 14, 2018 at 3:14 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    This drove me crazy too, until I figured it out. There is a setting in the headunit that sets how long lights stay on after you turn off the ignition. Set that to 0 seconds and the lights will turn off the second you open the door and no more beeping. Default I think is 30 seconds or something and it will beep when you open the door until 30 seconds passes or you shut the lights off.
    I keep my headlights always on, safer that way.
  16. Oct 15, 2018 at 6:44 AM
    rummy727
    In the head unit? Is that a setting on the steering wheel?
  17. Oct 15, 2018 at 8:51 AM
    ChrisTRDPro
    MT
    No, it's in the radio. It's in settings>vehicle>customization>light settings
    Then turn "headlamps auto-off timer" from 30s to off.
    rummy727[QUOTED][OP] likes this.
