2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Oct 10, 2018 at 3:43 AM
    #991
    4x4_Angel likes this.
  2. Oct 12, 2018 at 10:44 PM
    #992
    soobahru
    soobahru New Member
    2015 tundra 5.7L double cab 6.5ft 2019 tundra 5.7L limited crewmax
    Awesome thanks. I haven't ordered it yet. I wanted to see if it was something I could tackle on my own.
  3. Oct 13, 2018 at 10:55 AM
    #993
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    Im trying to do this set up right now.....but I cant seem to get it tight enough with the bracket and washers.... Im stumped!
  4. Oct 13, 2018 at 12:46 PM
    #994
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
    @ktemple what size corner bracket did you use?
  5. Oct 13, 2018 at 5:08 PM
    #995
    ProtoJ
    ProtoJ New Member
    Ok I figured out a mount for the 18 honeycomb grille. Drilled a small pilot hole in the plastic tab behind the emblem and used the little wood screw that came with the 90 degree bracket. Home Depot sells the bracket in the hardware isle. D88ADEFB-2905-47B9-840E-95FBC0D3DBC1.jpg 803F87C1-D369-4F0E-8129-761E2E057440.jpg 11797113-D334-486C-9835-B3FBADBBA81D.jpg
  6. Oct 20, 2018 at 11:55 PM
    #996
    ForceV4
    ForceV4 Pull my finger
    Sacramento
    2018 DC TRD 4x4
    I'm ordering up the FRAC this evening. Is there anything else I should be doing while the stereo is out? I really don't want to tear into the dash more than I have to. Things that I want to do (but can't afford right now) that may require pulling the dash apart would be an amp & speaker set up, painting or plasti dipping a few chrome pieces and adding some under hood and bed lights. Thanks in advance.
  7. Oct 21, 2018 at 12:02 AM
    #997
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I would do the plastidipping while you have it apart then. That's actually cheap to do. I get not wanting to take it apart multiple times....so save up for the rest and do those all at the same time. That way you're only taking it apart 2x
  8. Oct 21, 2018 at 8:12 PM
    #998
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I'll be looking for your order!
    As for the stereo amp/speaker replacement, you don't have to remove the Head Unit to do that work. Check out my Audio Build or a host of other audio build threads here on the forum for more info.
  9. Oct 24, 2018 at 7:39 AM
    #999
    Jai LI
    Jai LI New Member
    2018 CM 1794 5.7 4x4 FFV
    Rear sway bar, CAI and sound deadening
    Thanks for the post, I have the TSS as well and your info is really going to help. Just placed my order. TundraTex, nice piece of hardware.
    TundraTex[OP] likes this.
  10. Oct 24, 2018 at 4:26 PM
    #1000
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Thank You! Just processed your invoice.
  11. Oct 24, 2018 at 4:26 PM
    #1001
    Jai LI
    Jai LI New Member
    Just paid... looking forward to this mod.
  12. Oct 24, 2018 at 4:34 PM
    #1002
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Excellent. Your Harness will ship tomorrow. I'll send tracking info to your e-mail. Thanks for the order. Looking forward to seeing your install pics!
  13. Oct 24, 2018 at 4:39 PM
    #1003
    Jai LI
    Jai LI New Member
    TundraTex, with your experience and what you've seen, will the camera you bought and listed work easily for a 2018 Tundra with TSS? Looking for the simplest mounting solution.
  14. Oct 24, 2018 at 6:45 PM
    #1004
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I don't think you want to get the camera that I bought. My camera is designed to fit inside the open Toyota logo on Non-TSS grills. I would go with the camera and mounting approach used by @DarthMurdicide in post 966 or @ProtoJ in post 996 above. You can see the links to various cameras used by others in the product link window at the bottom of the thread page.
  15. Oct 26, 2018 at 2:34 PM
    #1005
    ForceV4
    Sacramento
    2018 DC TRD 4x4
    I wanted to do the plasti dip, but @TundraTex managed to screw that up for me. He managed to get the harness delivered to me faster than I could remember to buy Plasti Dip. My desire to get this thing installed is overpowering my want to ditch the awful 'wood' trim and chrome atrocities in my truck.
    My better half has asked me to make myself scarce tomorrow morning on account of her friends coming over. Maybe I'll see if I can get this installed then. How much time should I expect to spend on this if I don't paint or Plasti Dip anything?
    @TundraTex Thanks! I'm going to love this.
  16. Oct 26, 2018 at 5:00 PM
    #1006
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I would guess 1 to 3 hours, depending on how familiar you are with these type of installations. Let us all know how it turns out!
  17. Oct 26, 2018 at 5:03 PM
    #1007
    ForceV4
    Sacramento
    2018 DC TRD 4x4
    I'll give it a go in the morning and report back.
    In my kit, I've got 2 of the same switches, each with 3 prongs out back. Which 2 prongs do I use for the green wires?
    2018 Limited DC 4wd if it matters
  18. Oct 26, 2018 at 5:31 PM
    #1008
    alyosha01
    alyosha01 New Member
  19. Oct 27, 2018 at 5:42 AM
    #1009
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    Have had the FRAC in for about a month now, invaluable for a long trip across the US (Tennessee to Montana), I can actually park the beast like I need to. Older brother was in agreement that it should be factory installed...he will be ordering one when his new Limited arrives this spring...
  20. Oct 28, 2018 at 4:55 AM
    #1010
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Glad everything worked out for you, @Worriedman50. Thanks for the report.
  21. Oct 28, 2018 at 1:38 PM
    #1011
    alyosha01
  22. Oct 28, 2018 at 3:12 PM
    #1012
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes. As we discussed, follow the directions on page 6 of the FRAC installation manual. Connect the blue cam switch wire to the circuit you want to use for the forward camera and the white switch wire to the circuit you want to use for the Rear Camera. I suggest installing a blocking diode in the white wire circuit as shown in the directions to avoid any voltage from feeding back into your relay module. The red switch wire needs to be insulated and not used if you use your switch panel. The red wire has 12 volts on it whenever the ignition is on, so be sure to tape it up or otherwise insulate it well.
    alyosha01[QUOTED] likes this.
  23. Oct 29, 2018 at 2:33 AM
    #1013
    alyosha01
    This is helpful. Much appreciated.
    TundraTex[QUOTED][OP] likes this.
  24. Nov 2, 2018 at 11:21 AM
    #1014
    Jai LI
    Jai LI New Member
    I've been "FRAC"d, lol. Took longer than I expected (mainly cause I didn't want to break anything). To be honest, the process isn't hard, just the mounting of the camera and getting the wire through the rubber nipple is what takes the longest. Took me an hour to get my mounting set. Will probably adjust it later or remount the camera now that I know how it looks and the angle (crazy, initially had it mounted upside down). It's not in the center of the grill, I used the existing screws. Used ProtoJ method with a corner brace from Home Depot. But very happy with this mod. Thanks TundraTex.
  25. Nov 2, 2018 at 1:27 PM
    #1015
    PMG
    PMG New Member
    Just to update: I had a switching delay issue with my frac harness ( 1st batch made ). Discussed a few things with Lou and was able to solve the issue without much trouble. @TundraTex not only stands by his product, but is a good human being. Buy with confindence!
    TundraTex[OP] and Worriedman50 like this.
  26. Nov 2, 2018 at 1:49 PM
    #1016
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    Has anyone done a backup camera switch mod on an entune head unit with "eagle eye" 360 degree view? I tried to add a switch in the backup signal line and it just makes the screen go blank, not showing any of the cameras.
  27. Nov 2, 2018 at 7:07 PM
    #1017
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Good job, @Jai LI !
  28. Nov 5, 2018 at 6:54 PM
    #1018
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    If you have a camera that gives you an eagle-eye view, you can definitely plug it into the FRAC Harness for an anytime view.
  29. Nov 6, 2018 at 6:53 AM
    #1019
    blackoutt
    NWA
    OEM+
    This is the factory 4 camera system that I'm talking about, 2017 Rav4. I tried the "anytimebackupcamera" harness and it did not work. Grounding the reverse camera signal wire makes the screen blank, not display any of the cameras. I see that the Frac works on 4runners and Tacomas but the anytimebackupcamera harness does too. Was just looking for confirmation before I drop the money on it since I'm already out one harness. Sorry to muddy up your thread with non-tundra stuff! Thanks!
  30. Nov 6, 2018 at 7:31 PM
    #1020
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Added to my list of future mods
