MPG when Towing?
Discussion in 'Towing & Hauling' started by Volchek, Sep 30, 2018.
  1. Sep 30, 2018 at 6:36 AM
    Volchek
    Volchek [OP] New Member
    18 Tundra DC XPS 5.7
    Just completed a 700+ round trip ATL > Gulf Shores AL > Navarre FL > ATL towing a Winnebago 21ft camper with a total weight of @ 4100lbs. Towing with a 2018 Tundra Double Cab 4x4.
    I was expecting better MPG with the Tundra compared to the Tacoma we used to tow with. I averaged about 7.8mpg on the interstate averaging 75mph. This is marginally better than the Tacoma, which was about 6mpg. There aren't any long steep grades on this drive (I-85 to 65 to 10 and back to 65 then 85)
    Didn't appear to be struggling at all with the camper, only broke 4k RPM a few times when passing uphill. At @75mph the RPM would settle at @ 2300. Only getting @ 160 miles on 3/4 of a tank.
    I was in tow/haul mode the entire time. I expect air flow drag because we're towing a blocky rectangle but I would expect better MPG given the weight of the trailer and the power of the 5.7 V8.
    What do you guys get towing with your Tundras?
  2. Sep 30, 2018 at 6:42 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Same. You're trip and description all sound accurate.
    28ft tow behind. 8k loaded with gear and ready to roll.
  3. Sep 30, 2018 at 6:48 AM
    NorthWoodsTundra
    NorthWoodsTundra Hehehe, you said 'member'...hehehe
    2021 GMC 3500 SRW Gasser
    I did 800 miles rountrip to pick up a Bobcat that I purchased in my ‘18 CM with 3000 miles on it.
    The first half, with just the empty utility trailer at 2200#’s, got 12 mpg.
    After adding a 4000# Bobcat it dropped to 10mpg.
    I drove 65 mph the entire trip and suspect that doing 75 may have been the reason yours was so low. You’re pushing a lot more air at that speed.
  4. Sep 30, 2018 at 6:59 AM
    Slow down, even 5 mph and this will help significantly.
    Here is a trip we had horrible wind, pushed the truck hard due to time restraints. FD802922-2232-4E24-BD51-8C2D9BEF1D11.jpg
    This trip, was harder pulling but slower speeds:
    Same camper and truck.
    Black Wolf and Stroke250 like this.
  5. Sep 30, 2018 at 7:15 AM
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    Sounds about right. Like the others have said. I’d slow to about 60-65 while towing a block like that. You should come up to about 9 to 11ish mpg. Also drain your black/gray/potable tanks. There is also a fiberglass deflector you can put on the front of the trailer that may help if you have the squared front end. Every little bit helps.
  6. Sep 30, 2018 at 7:32 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    I concur on the speed, the truck and I are happy at 68. I'm almost twice the weight and a little longer than you, but still around 8mpg.
  7. Sep 30, 2018 at 7:37 AM
    Notachickmagnet
    Notachickmagnet New Member
    I towed my small camper over 2,000 miles a month or so ago. 12.9 to 13 mpg
    I was pleased !
    My mpg are usually 13 !
  8. Sep 30, 2018 at 10:23 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    I tow a 25 ft travel trailer about 5600lbs. I average around 10 to 11 mpg towing in between 60 and 65.
    -Jason
    ATHiker likes this.
  9. Sep 30, 2018 at 10:29 AM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    Dependa on what I am towing. I got 11 mpg towing wood and fence posts for a friend trailer and load was 4k in weight and speed was 70 mph from one expressway. I towed a Dodge Dakota for a friend that had a bad engine pushing 7k in total weight with trailer and got 9 mpg that had more stop lights and town driving than expressway driving though. Towing my Jeep Cherokee I get 10-10.5 mostly highway at the speed limit of 65-70.
  10. Oct 9, 2018 at 4:15 PM
    Mithrandir
    Mithrandir New Member
    mike
    2018 4x4 Tundra Color of Victorville Dirt
    Pulled a empty 17 foot cargo trailer to vegas and back....
    Average of 10... 8 mpg against the wind, 12 mpg with the wind...
  11. Oct 9, 2018 at 4:36 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I'm getting 10 mpg pulling 3000 pounds on a 6 inch lift with 35's.
    Y0TA PR0 likes this.
  12. Oct 10, 2018 at 2:01 PM
    TRD_RTC
    TRD_RTC Overlander
    Robb
    2007 Toyota Tundra CM SR5 TRD Off-Road
    TRD Intake Tinted Windows Color Match Cap CB Radio Valentine 1
    I get 11-12. Nothing less but nothing better either.
  13. Oct 10, 2018 at 2:04 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    2018 CM 4x4 and I get about 7.9 towing a 9,400 TT
