If you were a mouse...
Discussion in 'General Tundra Discussion' started by NHPig, Oct 6, 2018.
  1. Oct 6, 2018 at 10:33 AM
    NHPig
    NHPig [OP] Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
    ...how would you make it to the center console of a 2016 CrewMax?
    So, two years in a row, evidence of mice in the center console. Fortunately, not a lot of damage, piss, or shit. Mostly chewing up my supplies of tissue. However, today, I found a damn live mice hanging out in the tissue box. I threw the box to the pavement and stomped it... lil' bastard still managed to escape.
    I have ZERO evidence that the mice are getting in through the air cabin filter. ZERO.
    Any ideas on the next likely access? I appreciate their abilities to fit through tight spaces, but I hoping to identify the obvious ones. I am bewildered why I cannot find any other evidence of mice ANYWHERE else in my truck.
    Darkness and 4x4_Angel like this.
  2. Oct 6, 2018 at 10:48 AM
    15whtrd
    15whtrd Mr. Blonde
    Look at all the rubber grommets or plugs under the truck and anywhere on the firewall. Also check between the cab and bed, I think there is some rubber or plastic hole plugs there as well.
    Or that little mofo got in when you left the door open?
    Black Wolf likes this.
  3. Oct 6, 2018 at 11:20 AM
    tundras00
    tundras00 New Member
    Put some dryer sheets everywhere you can on the outside fo the truck.
  4. Oct 6, 2018 at 11:29 AM
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    Is this some essential-oil-voodoo-shit? I have never heard of dryer sheet mouse repellent. Does it work?
    Darkness likes this.
  5. Oct 6, 2018 at 11:31 AM
    I put mouse poison everywhere outside. Pick up dead mice all over.
  6. Oct 6, 2018 at 11:38 AM
    tundras00
    I've heard of it from guys that had rodent problems before and apparently it worked for them.
    What kind did you use?
  7. Oct 6, 2018 at 11:41 AM
    Funny, I’m sitting in line buying some right now. I also made some traps at home I’ll post up when I get back. F873E12F-4496-494D-BD71-BEAAB3EE8E88.jpg
  8. Oct 6, 2018 at 11:46 AM
    tundras00
    I know the old decon worked, but didn't read good things on the new one. I have a collection of bars and pellets I use around the house.
    ColoradoTJ likes this.
  9. Oct 6, 2018 at 11:47 AM
    dud13
    I’ll have to give it a try. Seems pretty cool.
  10. Oct 6, 2018 at 11:47 AM
    Sometimes adding a little something helps them out. Peanut butter or nuts work great.
    4x4_Angel and 15whtrd like this.
  11. Oct 6, 2018 at 11:59 AM
    trdprobped17
    trdprobped17 New Member
    It’s a good thing to keep them out, but, it’s also important to know what is attracting them inside your truck. I would ensure that there aren’t any food items or anything like that in your truck. Rats usually like to scavenge through items and areas that are permanent or immobile in nature. If your truck moves daily, then, there is something in it that they love.
    My neighbor across the street is a electrician and he keeps lots of electrical supplies in his truck for work. Rats found something there that they love and ate through the electrical wiring in his dash. His F159 was only a month or two old at the time. Let’s say that after approximately $8K of electrical work replacement, his truck still has electrical issues.
  12. Oct 6, 2018 at 1:43 PM
    NHPig
    New Hampshire
    All things considered, I run a pretty tight ship in the truck. Two girls aren't too bad inside truck with food (better in truck than in wife's car) and leading up to the first incident last year, I only kept unopened granola bars as an emergency backup. After that first incident, all food was removed. Side note, mice never touched the granola bars, but I am sure the scent didn't help. Only thing that remained in the last 12 months or so was a hard plastic case of gum. This gum was untouched. My daughter's gum (mint, btw) was chewed on from today's incident.
    I won't say my truck is flawless when it comes to food, but it's on the upper side of the bell curve. Obviously, I still need to improve somewhere.
    That is the information I was looking for. I am familiar with the two in the rear corners, I used them once upon a time to dry out a wet truck from leaving the rear window down. SMH
    Those, along with the rocker panels ones are fine.
    I crawled under the truck and looked everywhere. On the firewall, I only see the traditional ones topside (under hood). Everything looks solid.
    Last year, and today, I stuffed dryer sheets doused with peppermint oil. I put one in each corner (rear corner of engine bay, a.k.a. lower corner of windshield.)
    I am at a loss for entry. Needless to say, the entire garage is lined with traps. I've been running the ol' bucket of water with a few inches of water topped with a handful of sunflower seeds. The small glue traps my wife bought (knowing I wanted large) were useless. Big ones are now set.
    Last year's acorn crop was over the top. Our rodent/squirrel population blew up. Now, this year's acorn crop is non-existent, and I have a feeling deer season might go well, but rodents are going to be desperate.
    4x4_Angel and 15whtrd[QUOTED] like this.
  13. Oct 6, 2018 at 2:38 PM
    trdprobped17
    @NHPig It doesn't take much for rats to come knocking. Another contributing factor may be where you park your vehicle and what's in that area. Down here in South Florida, I had problems with snakes. It drove me crazy. My wife wouldn't go out to her truck until I cleared the area for snakes. I tried everything to get rid of them, from moth balls, to stuff from Home Depot made for repelling snakes. But, nothing worked. Then, one day my pool guy from Brazil came by and I told hold the problem that I was having. He checked out the area, then told me that I needed to get rid of the red mulch and fern hedges by my driveway. I have a pond near the driveway and the cottonmouths loved the mulch and fern hedges. Once I got rid of both, the snakes stopped coming.
  14. Oct 6, 2018 at 4:08 PM
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    In my F150 I had a mouse problem. Two different times. They made a nest under the back seat under the carpet, where you can see the padding underneath. I put snap traps with peanut butter to catch them. Good luck, it sucks
    trdprobped17 and 4x4_Angel like this.
  15. Oct 6, 2018 at 4:14 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    I spray rat poison under truck every week. I can barely walk to my truck in the morning without stepping on the dead mouse carcasses they are everywhere. :bananadead: Just kidding. I have heard fryer sheets and don’t leave snacks in your truck. My GF always buys me snacks to “leave in the truck Incase I get hungry”. And I’m always like Thanks so much but NO :der:
  16. Oct 6, 2018 at 5:34 PM
    This is what I use around the house:
    8F6ECCA5-D010-4077-996F-38884EEAD430.jpg 1FF66550-FDF4-4EED-A5EC-76570EB925D4.jpg
    I have two of these made up and around 8 of the small ones. You can see that it’s been working. Eating the bait and then it just slides down. Works like a champ.
    Only crappy part about the small ones is the poison fades and deteriorates in a very short time.
    I had like 6 mice in my garage. I hooked them up with poison and water buckets with about 4” in the bottom. 4 of the six fell for the bucket and the other two pigs just couldn’t get enough of the peanut butter covered poison.
  17. Oct 6, 2018 at 5:47 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Cool idea right there,:thumbsup: thanks.
  18. Oct 6, 2018 at 6:28 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Baits used wisely in traps where dogs and cats cannot access them are great! Just don’t throw these baits out openly where dogs and cats can eat them. They are attracted to the same stuff as rats/mice.
  19. Oct 6, 2018 at 6:32 PM
    I got the build off YouTube. Cost about 9.00 each to build.
    Mice like eating where they are safe.
    We have a lot of owls, hawks, coyotes, cats of all sizes that enjoy a small snack.
  20. Oct 6, 2018 at 6:42 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I need this.....
    Will they drink antifreeze too?
    I'm sick of rats being in my Damn house. And being butted up against a field doesn't help. I have squirrels in the yard and apparently some other critters my dog chases awayfrom the house
  21. Oct 6, 2018 at 6:48 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I've got garbage cans full of ABS fittings and loads of pipe, contractor thing. And, I live in a similar setting with more critters than neighbors, thankfully.
  22. Oct 6, 2018 at 6:49 PM
    Peppermint oil, they hate the odor.
  23. Oct 6, 2018 at 7:05 PM
    Fred
    Hand Protectors
    The best thing to keep rats out is to block all penetration points. That means anything bigger than 1/4” gaps. Once you start looking around the outside of your home you will realize how much work needs to be done to prevent them from entering. Most homes have multiple intrusion points.
    Second defense is baiting.
    Third defense is hot pepper caulk. Yes they make it. Gets on their fur and they take it back to the nest. Baffles the colony and they go elsewhere.
    All three used together are perfect.
  24. Oct 6, 2018 at 7:54 PM
    tundras00
    Not from what I've seen.
  25. Oct 6, 2018 at 7:57 PM
    I started to use it on my lawn tractor during the off season and no more nests in the engine.
    Did you use 100% pure peppermint oil?
  26. Oct 6, 2018 at 8:04 PM
    tundras00
    Yep. I had a mouse running around last winter and tried everything. Would eat the pellets and come back for more too. I think the only thing that worked was a glue trap for rats. Got also another one later in my storage with a victor rat trap set up with nuts. I mainly use the oil for spiders now.
    4x4_Angel and trdprobped17 like this.
  27. Oct 6, 2018 at 8:11 PM
    Wow, that's weird it works for me. I've been told that a bar of Irish Spring soap also works because of the scent.
    4x4_Angel likes this.
  28. Oct 6, 2018 at 8:17 PM
    trdprobped17
    My neighbor across the street who had his F150 electrical wiring eaten by rats, told me that he has been lacing his fence line with aspirin and his expired blood thinning meds. He claimed that rats will eat the tablets, then, bleed to death. So, like I always do, I looked it up and found this information.
    “Coumadin is one of those drugs which are frequently considered poisons more than medicines. It is common to hear the word Coumadin in the same sentence with “rat poison.” This is because, it’s true. Coumadin is the brand name for the drug “warfarin.” This is the story of warfarin and how it came from killing cows to becoming the most widely used rat killer in the world, to being one of our greatest drugs used in certain patients for the prevention of strokes.
    "All things are poisons, for there is nothing without poisonous qualities. It is only the dose which make a thing a poison . . . a lot kills, a little cures" Aureolus Paraceisus (1493 - 1541) "Grandfather" of Pharmacology
    In the early 1900's, the northeastern United States was being plagued with a dreadful cattle disease that was causing cows to die from internal and external hemorrhages. Cattle would be found dead with pools of un-clotted blood around them. The cattle ranchers were at a complete loss to know why this was happening. Veterinarians and scientist began to respond to pleas from the ranchers for an answer.”
    ColoradoTJ and 4x4_Angel like this.
  29. Oct 6, 2018 at 8:20 PM
    tundras00
    Might depend with location, or maybe it was because it was too cold to be outside (typically 0F) and said screw it, I can deal with it.
  30. Oct 7, 2018 at 2:43 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    Cool thank you. Looks like my weekend without my girls will be spent working on the house
