Power Outlet Installation
Discussion in '2.5 Gen Tundras (2014-2021)' started by crafty762, Oct 5, 2018.
  1. Oct 5, 2018 at 8:39 PM
    crafty762
    crafty762 [OP] New Member
    Minneapolis
    2017 Toyota Tundra SR5 TSS Offroad
    Neon floor lighting, LED bed lighting, Google mini, front LED light bar, custom USB power ports
    I added a power outlet to my 2017 Tundra last week. I'm pretty happy with the outcome.
    Potek 500W power inverter
    Mini power desk 3-prong socket
    I used an office desk power outlet which gave me the desired flush-mount look and feel as well as a similar texture to the rest of the interior. Cut a hole in the side of the center console on the passenger side (plenty of room behind the console wall) and ran the wire behind the console wall across the floor to the underside of the driver seat where the power inverter sits. Power inverter is wired to the fuse box.
    IMG_7489.jpg IMG_5203.jpg IMG_7131.jpg IMG_9295.jpg IMG_6665.jpg IMG_6563.jpg
  2. Oct 5, 2018 at 8:44 PM
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    That is freakin cool!
    crafty762[OP] likes this.
  3. Oct 5, 2018 at 8:53 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Pretty bad ass
  4. Oct 5, 2018 at 8:54 PM
    BigGreek
    BigGreek New Member
    Evan
    2016 Tundra Platinum
    I love it!
  5. Oct 5, 2018 at 9:03 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    That's sweet and very affordable. Thanks
  6. Oct 6, 2018 at 4:27 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Nice work, I've been thinking about doing something like that.
  7. Oct 6, 2018 at 5:41 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
  8. Oct 6, 2018 at 5:57 AM
    dud13
    Forgot to ask, but what is the white box?
  9. Oct 6, 2018 at 6:05 AM
    Very nice job. :thumbsup:
  10. Oct 6, 2018 at 7:46 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Which fuse box do you have the inverter hooked up to and did you tape into a power source that turns on with the key?
  11. Oct 6, 2018 at 7:50 AM
    crafty762
    Minneapolis
    The white box is a TP Link mini travel router which is powered by the inverter via USB. I use it for creating a wireless network in my truck so the kids can play Minecraft with one another on a LAN.
  12. Oct 6, 2018 at 7:52 AM
    crafty762
    Minneapolis
    It is wired to the fuse box on the lower left of the driver's side behind the floor panel. I used a fuse tap from a slot that is dependent on the ignition; that way I don't drain the battery if I exit the truck and leave something plugged in.
    SpeshulED[QUOTED] likes this.
  13. Oct 6, 2018 at 8:14 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    This is a very clean and functional mod for sure! Great idea!
  14. Oct 6, 2018 at 9:24 AM
    Outbound
    Aaron
    Northern Alberta
    Very cool mod. I've been wanting to install and inverter in my truck. I may use your clean install as inspiration.
    That's really cool. I suppose it uses your phone's data as a wifi hotspot?
  15. Oct 6, 2018 at 9:26 AM
    crafty762
    Minneapolis
    That is correct; the TP Link is somewhat unique in that it will bridge to your phone's hotspot. Once I turn on my hotspot, everything connects to the internet. Turning off the hotspot still allows for the local network to continue working.
    Outbound[QUOTED], aperezsh and 1UPPER like this.
  16. Oct 6, 2018 at 10:08 AM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    Great work.
    I’m going to attempt this mod. Thanks for the inspiration!
  17. Oct 6, 2018 at 10:12 AM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    Great piece of work. Looks factory installed option. One thing for sure, no one can take away crafty762 name from u......
  18. Oct 6, 2018 at 10:19 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Nicely done!
  19. Oct 6, 2018 at 10:19 AM
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    Is that enough to power a laptop?
  20. Oct 6, 2018 at 10:20 AM
    dud13
    Very cool!
    crafty762[QUOTED][OP] likes this.
  21. Oct 6, 2018 at 10:22 AM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    So, do u see a need to use the router? Other devices can connect your hotspot directly as well...
    Just asking for my own learning
  22. Oct 6, 2018 at 10:28 AM
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    Looks like a clean outlet install!!! Nice work... I don't like any sort of electrical work. So can u take a pic of where u are grabbing the power from too
  23. Oct 6, 2018 at 10:30 AM
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    VERY NICE! I also have an inverter in my truck, much much larger, 3000 watts 5000 watts peak.
    I'd suggest a larger one as you never know what you'll need to power. I use mine for a coffee maker and a microwave when we are camping.
    i do love the the flush mounted outlets, if i ever have the inclination to do more shit to my truck, that would be on the list.
  24. Oct 6, 2018 at 11:08 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Great install! Just took a look at the Plug on Amazon, was curious about connections. There are none which is really nice.
  25. Oct 6, 2018 at 11:14 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
  26. Oct 6, 2018 at 11:59 AM
    Fiestee23
    SOCAL
    White sr5 4wd
    As a matter of fact @crafty762 where do you live? You can just come help a sister out... Lol
  27. Oct 6, 2018 at 12:34 PM
    crafty762
    Minneapolis
    Yes it is; I have a MacBook Air and it uses between 60W and 85W of power. It should be enough power for a small air compressor to fix a flat, too.
  28. Oct 6, 2018 at 12:37 PM
    crafty762
    Minneapolis
    I like the flexibility, that's all. You're right about other devices uses my hotspot directly. However, I wanted a closed private network for the kids' tablets without getting out to the internet. I also have my Google Mini connected to the TP Link so that when I start the truck and do not turn on my hotspot for some reason I don't have to listen to "I can't connect to your wifi right now" from Google over and over.
    Coolhardy[QUOTED] likes this.
  29. Oct 6, 2018 at 1:07 PM
    crafty762
    Minneapolis
    Houston area!
    Fiestee23[QUOTED] likes this.
  30. Oct 6, 2018 at 1:10 PM
    crafty762
    Minneapolis
    I'll post a photo when I have that panel back open again for another job I'm planning!
    SpeshulED and Fiestee23[QUOTED] like this.
