Squealing brakes while backing up - 2002 Tundra SR5
Discussion in '1st Gen Tundras (2000-2006)' started by BurgundyTundy, Oct 3, 2018.
  1. Oct 3, 2018 at 2:26 PM
    BurgundyTundy
    BurgundyTundy [OP] New Member
    Rob
    2002 Tundra SR5
    2002 Toyota Tundra SR5
    Recently when backing up in reverse at slow speeds the brakes scream. This is louder than any other squeal I've heard on any vehicle. It happens when the brake pedal is pressed from about 1/4 to 1/2 of the way down.
    Took it to my local shop and they said it needed cleaning and they cleaned them with no change in brake squealing.
    Does anybody know what the problem is or have a similar issue?
    If so what can I do to fix it?
  2. Oct 3, 2018 at 3:23 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Release the e-brake? :D
  3. Oct 3, 2018 at 3:25 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Seriously, Welcome Rob. I'd check to be sure the e-brake cable isn't too tight. Then I'd start looking at the calipers and what the space 'tween caliper and pad looks like. How new/old are the pads and rotors?
  4. Oct 3, 2018 at 6:13 PM
    Professional Hand Model
    Fred
    Hand Protectors
    I had this problem when my rear shoes were replaced for the first time. Lived with it for 5 years and considered the squeal a form of reverse warning system.
    Rear axle seals leaked and had to get another set of new shoes and the problem is gone. Must be the type of shoes? Not of shoes type as the shop did all the work.
    bmf4069 and 831Tun like this.
  5. Oct 3, 2018 at 6:39 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I forgot 1st gen = shoes 2nd & 3rd = pads.:thumbsup:
  6. Oct 4, 2018 at 10:48 AM
    bmf4069 Captain wtf
    Mine does the exact same thing. But only in the mornings. And my axle seals are leaking. Hmmm......
  7. Oct 4, 2018 at 2:31 PM
    Fred
    Hand Protectors
    Do your axle seals and bearings and brake shoes all at the same time. Thats how they did it for me.
    Black Wolf likes this.
