New Tundra Owner with LOTS of Questions!!
Discussion in 'New Member Introductions' started by matt1142008, Sep 6, 2018.
  1. Sep 6, 2018 at 4:30 PM
    matt1142008
    matt1142008 [OP] New Member
    2017 SR5 CrewMax 2x4 SuperWhite
    Tri-fold Bed Cover Sprayed Bed Liner Step Rails
    Hi All!! I do service work and am required to use my own vehicle so I figured why not get a Toyota due to them having the best depreciation value. I got a Used Tundra a couple weeks ago, pictured below. I have been reading about the Bilstein 5100's for leveling the truck out. I still haven't decided if I am going to do them in the front on the max setting and the 1" ones in the rear or just get them in the front on the middle setting for the level ride. I have looked around a bit and don't see much about it, but do the 5100's on the max setting require an other front end changes? I.E. UCA? I see where some recommend the Diff drop on the 4x4, but with mine being 2x4 thats not needed. TIA!! Glad to be a part of this community!! You guys have helped a ton already!
  2. Sep 6, 2018 at 4:33 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Welcome from CO! Nice truck...you dont "need" UCA's with the 5100's at the top, but it sure does help with alignments.
    robzillaaa likes this.
  3. Sep 6, 2018 at 4:35 PM
    Welcome. Fronts are adjustable. How much of a lift are you looking for?
  4. Sep 6, 2018 at 4:44 PM
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
    With 5100s on the top setting I got the alignment in, but it's maxed out on the adjustment. Truck is level within 1/8 on all four corners.
    boostedtrdpro likes this.
  5. Sep 6, 2018 at 4:45 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! Beautiful truck!! Check the 6112 shocks out as well.
    dandailey likes this.
  6. Sep 6, 2018 at 4:48 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO.
  7. Sep 6, 2018 at 4:56 PM
    Welcome from NY.
    White is a great color for a service truck.
    Prostar 190 likes this.
  8. Sep 6, 2018 at 5:04 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
  9. Sep 6, 2018 at 5:41 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Welcome from OK
  10. Sep 6, 2018 at 6:04 PM
    KiltedWolf1
    KiltedWolf1 New Member
    ‘16 Platinum Crewmax White
    Welcome from TX
  11. Sep 6, 2018 at 6:07 PM
    Welcome from Texas
  12. Sep 6, 2018 at 6:11 PM
    Welcome from Ohio!
  13. Sep 6, 2018 at 7:28 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Welcome from CA
  14. Sep 6, 2018 at 7:41 PM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    Welcome from SoCal
  15. Sep 6, 2018 at 7:42 PM
    matt1142008
    Thanks everyone for the kind words. So I'm stuck between doing the 5100's max in the front and the 1" shocks in the rear or just using the 5100's on the middle setting in the front to level it out and being done with it. If tie rod ends and Ball joints are going to suffer greatly I may not do the front and rear, but at minimum I want it level. I put about 40-50k miles on it a year so i try and avoid extra maintenance fees if I can, but like to look "cool" too. Haha.
  16. Sep 6, 2018 at 8:18 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  17. Sep 6, 2018 at 8:29 PM
    Welcome from CO.
    I really liked the 6112/5160 combo. Check into that setup.
    matt1142008[OP] likes this.
  18. Sep 6, 2018 at 8:34 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from Ca.
  19. Sep 6, 2018 at 8:35 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME!
  20. Sep 6, 2018 at 8:36 PM
    Fireace
    Fireace New Member
    Oregon
    2018 Crewmax SR5 CM
    BAmuffler Pro Comp 6” lift ADD bumper Smittybilt 10k winch
    Welcome from OR
  21. Sep 7, 2018 at 6:11 AM
    Notachickmagnet
    Notachickmagnet New Member
    Welcome from Ohio!
  22. Sep 7, 2018 at 6:16 AM
    captain_bij
    captain_bij New Member
    Bijan
    15’ Tundra Crewmax Platinum 4x4
    Welcome!
  23. Sep 27, 2018 at 3:54 PM
    matt1142008
    So for my most recent mod, I converted all interior lights, tag, reverse, cargo, and 3rd brake light to LED. Trying to modernize this truck one step at a time! Hit 12,500 miles today too. Been driving my F150 with 280k miles to keep miles off the Tundra while I can.
  24. Sep 27, 2018 at 4:08 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Welcome from SE VA......:)
    If you can afford it, 6112's are the way to go.
  25. Sep 27, 2018 at 5:30 PM
    NHPig
    NHPig Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
    Welcome from NH!
  26. Sep 29, 2018 at 11:47 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  27. Oct 3, 2018 at 5:44 PM
    matt1142008
    Most recent mod, I made it so I can turn my fogs on without having my headlights on! I also ran my wires for the pop and lock install, just waiting for my Actuator. Loving all the Tundra owners help!
    NHPig likes this.
