D-ring tie downs in bed?
Discussion in '2.5 Gen Tundras (2014-2021)' started by lowrider60, Aug 14, 2015.
  1. Aug 14, 2015 at 7:56 AM
    lowrider60
    lowrider60 [OP] New Member
    2015 Toyota Tundra TRD 4X4
    I was looking at the bed on my new tundra and wondered why Toyota would not install plugs or bolts in the threaded cargo system nuts in the bed.I'm considering having a LINE-X bedliner installed but don't want those holes filled in with the material.Has anyone installed any D RING type of tie downs in those locations?
  2. Aug 14, 2015 at 8:07 AM
    [​IMG]I actually did the D-ring thing. @matluth's build thread begins sort of
    TruckyTruck and rons23 like this.
  3. Aug 14, 2015 at 9:49 AM
    lowrider60
    I assume these bolts would be metric?
  4. Aug 14, 2015 at 10:40 AM
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
    I told the Line X guy I wanted to keep the holes open and he did. I assume he put temporary bolts in prior to spraying.
  5. Aug 14, 2015 at 10:40 AM
    Definitely metric. Forgot the size offhand. I re-used the bolts that came with my slide rail system (sold that)
  6. Aug 14, 2015 at 10:41 AM
    JMB
    Chesapeake, VA
    M6-1.0 if I remember correctly.
  7. Aug 14, 2015 at 10:42 AM
    Pretty sure you are correct on that M6/1.0
  8. Aug 14, 2015 at 10:59 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    This thread and this one and this one may give you some ideas
    Bolt size for the bed rails is M6x1.25 (qty 12)
    TruckyTruck likes this.
  9. Aug 14, 2015 at 11:44 AM
    Going to stop by Home depot and pick up some Unistruts and Unistrut channel nuts. Going to mount them at the lower D-ring fastening points. This way I regain slide rails and still have 12 stationary D-ring mounting points. I should be able to still do the ammo can mod without getting in the way of the tonno(in theory.) Worth a shot. A good weekend project.
  10. Aug 15, 2015 at 3:04 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    TruckyTruck and Black Wolf like this.
  11. Aug 15, 2015 at 3:25 PM
    Welcome from CO. Seems you had the same idea as me. heh heh.
  12. Aug 15, 2015 at 3:47 PM
    JMB
    Chesapeake, VA
    Yeah. I checked the package from leftover cap screws. It's M6-1.0
  13. Aug 15, 2015 at 6:40 PM
    The Uni Struts are not going to work with my "D-ring" set up. The Uni Struts are too wide height wise. I can retro fit actual D-rings like @alalmcgrath did and make the Uni Struts work so I can use Brian's/csu vipers ammo can mod. I will make it happen!!!
  14. Feb 21, 2016 at 9:32 PM
    csuviper
    Broomfield, CO
    I was originally incorrect on the bolt size.
    M6 x 1 is confirmed to be the correct size.
  15. Jun 17, 2016 at 8:43 AM
    Ryan Mc.
    Ryan Mc. New Member
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    Following.
  16. Jun 19, 2016 at 7:22 AM
    Ryan Mc.
    Ryan Mc. New Member
    Mission Viejo
    Where did you buy these? Ive checked my local Home Depot and Lowes.
  17. Jun 19, 2016 at 9:52 AM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Bought them on AMAZON. They are called "flush anti-rattle D rings". They come with a backing plate (plastic) that I did not use.
