Trans cooler location
Discussion in '2.5 Gen Tundras (2014-2021)' started by jcop1, Sep 30, 2018.
  1. Sep 30, 2018 at 5:33 PM
    jcop1
    jcop1 [OP] New Member
    Trans cooler location on 2019 tundra 5.7 or is not part of ac condensor please help
  2. Sep 30, 2018 at 6:11 PM
    15whtrd
    15whtrd Mr. Blonde
    You should have two lines coming out of the transmissions, a feed and return line. Follow them up front. You may need to remove the skid plate.
  3. Sep 30, 2018 at 6:18 PM
    15whtrd
    15whtrd Mr. Blonde
  4. Sep 30, 2018 at 8:10 PM
    jcop1
    Thanks for the reply I will check it out but definitely looks different than a 2018 model
  5. Sep 30, 2018 at 9:18 PM
    15whtrd
    15whtrd Mr. Blonde
    I can almost guarantee that 2019 isn’t any different.
  6. Oct 1, 2018 at 3:45 AM
    timsp8
    NY
    I think the cooler is only on the trucks with a tow package. Look for the 2 lines on the upper left side as you face it of the black radiator/ac condensor. Lines go along and up the passenger side of the truck.
  7. Oct 1, 2018 at 9:27 AM
    jcop1
    Thanks for the answers the 2019 I looked at
    T 5.7 tow package the ac condensor is no silver with no trans lines running to the top of it I checked a trd pro also same thing
  8. Oct 1, 2018 at 2:26 PM
    timsp8
    NY
    15whtrd likes this.
  9. Oct 1, 2018 at 2:29 PM
    jcop1
    No the condensor is now a silver color and I don't see any trans lines going to the top of it may be they moved it it was not able to look under hood
  10. Oct 1, 2018 at 2:31 PM
    timsp8
    NY
    Here are my hoses going in on a 2018 Limited w/ tow package.
  11. Oct 1, 2018 at 2:33 PM
    timsp8
    NY
    That’s weird. Maybe crawl under and see if there are any lines coming out of the transmission going anywhere. Tundras before 2010 I believe had a separate trans cooler.
  12. Oct 1, 2018 at 2:34 PM
    jcop1
    Thanks for the pic on the 2019 I do not see the lines on the top ac condensor is now silver color
  13. Oct 1, 2018 at 2:48 PM
    timsp8
    NY
    Wonder why they changed it. I had a bully dog to monitor trans temps on my 2010, and it got hot sometimes. I’d think the truck needs it. I think it worked as a warmer too somehow to get the trans up to temp sooner.
  14. Oct 1, 2018 at 2:50 PM
    jcop1
    I just looked at the truck it says on the build sheet it has it but it is not part of ac condensor
