Help.. backflip g2 install
Discussion in 'Tonneau Covers, Caps and Shells' started by xj2202009, Sep 27, 2018.
  1. Sep 27, 2018 at 4:08 PM
    xj2202009
    xj2202009 [OP] New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Hi everyone..blakflip g2 came in the mail.. We have a few situations: 120180927_184927.jpg
    do I need to use the wether stripping if I have the rhino sprayed bedliner?
    2. Factory rails block drainage port on the bed and the drainage hose don't fit through the port and I'm trying to avoid drilling ..any advise?20180927_184927.jpg
    3.Is this going to be a problem?
    And do I still need the wedges for this?
  2. Sep 27, 2018 at 5:55 PM
    bsktball55
    bsktball55 New Member
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I used the weather stripping, I have the factory sprayed in bed liner. My drain tubes go through the plastic covers that are on the rear wall of the bed. I drilled a hole through the plastic and it holds the tube in it. That shouldn't be a problem the amount of water that will get through there will be handled by the drainage system. As it gets hot, it will mold to it a little more anyway. I didn't need any wedges on my MX4, but not sure about your issue.
  3. Sep 28, 2018 at 7:54 AM
    xj2202009
    x
    Lutz, Fl
    Thank you @bsktball55. The dealer rhino those vents but I can still through them.
