Mad scientist (aka cheap bastard) DIY Chrome Removal
Discussion in 'General Tundra Discussion' started by dud13, Sep 26, 2018.
Worth the effort?
  1. Yes, worthy of adding to the arsenal.
    27 vote(s)
    44.3%
  2. Meh, I’d rather buy color matched.
    9 vote(s)
    14.8%
  3. FU! Plastidip is the shit!
    4 vote(s)
    6.6%
  4. Too much work, chrome isn’t that bad.
    21 vote(s)
    34.4%
  1. Sep 26, 2018 at 3:57 AM
    dud13
    dud13 [OP] níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    TLDR: Start at post #17 from @Heatonrx for the solution.
    On a mission to either blackout or color match my blinding ass chrome door handles. Seriously I think these things store solar energy and discharge it like a nuclear powered glow stick.
    Step 1: Remove chrome plate.... This is not your daddy’s chrome plate from the ‘90s. Toyota being the “relentless pursuit for quality” fuckers that they are, decided not to cheap out on the process. This is the expensive, industrial strength, suck my cannon balls, copper-nickel-chrome on ABS layered process. Tried sanding, it is possible but extremely labor intensive. Internet research has suggested that a bleach soak will do the trick. 8 hours of concentrated bleach soak and the MF’n chrome is even more shiny. The next “not so safe for skin” option was oven cleaner. Not regular oven cleaner, the yellow heavy duty spray bottle. One overnight soak later and the chrome is still there. Laughing. Taunting. Found someone in LA (the city, not the state) who took their entire grill to a local electroplating company the does a lot of chrome work. Apparently there is an acid bath, nitric acid and another one I forgot, that does a good job. Cost him about $3 to do his entire grill. Pictures looked very nice. There is a company close by me that does the electroplate thing. I’m calling them today to see if they remove chrome.
    I’ll update this and take you along with me on this magical journey.
    Edit: changed title from door handle paint to chrome removal. Better description of what’s going on.
    cavalry bear, Skippy, Ostrich and 5 others like this.
  2. Sep 26, 2018 at 6:55 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    If you're goin thru all this effort I'd say definitely color match them. You can buy the black and sell chrome for pretty much a wash, right here on this forum too.
    You could sand or scuff with a scotchbright pad, use adhesion promoter, prime, paint, clear. It's been done with nice outcomes.
    Inquiringone and Black Wolf like this.
  3. Sep 26, 2018 at 7:07 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    sounds like a lot of time...just buy color matched ones from Roman and be done.
    Blueknights75, joonbug and Black Wolf like this.
  4. Sep 26, 2018 at 7:23 AM
    Read my mind....
  5. Sep 26, 2018 at 7:26 AM
    fairclothr1
    fairclothr1 Here and There Member
    2009 Sand Mica Tundra TRD
    Plasti Dipped grill and badges. Shorty antenna.
    I have a 2009 and ended up pulled the handles off and giving them a good coat of plastidip. Been about a month or more and working well so far. I hated the chrome and was too cheap to buy a set of black.
    dud13[OP] and Pudge like this.
  6. Sep 26, 2018 at 8:14 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    “This is not your daddy’s chrome plate from the ‘90s. Toyota being the “relentless pursuit for quality” fuckers that they are, decided not to cheap out on the process. This is the expensive, industrial strength, suck my cannon balls, copper-nickel-chrome on ABS layered process. “
    :rofl: Very funny! I’ve heard of a couple people successfully dechroming with bleach, but it took days not hours.
  7. Sep 26, 2018 at 8:47 AM
    dud13
    So, to get the following:
    Color matched handles: $111.83
    https://parts.toyotaofcoolsprings.c...ssories-door-handles-door-handles?parent=1001
    Color matched bulge: $193.82
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-hood-bulge-magnetic-gray-1g3-761800c030b1/?c=aT04MTkzMTQ1NSZyPWxheWVyXzU=
    Color matched surround (not sold separately, so you have to buy the insert as well): $328.35 for the Platinum version since there is no 1794 version. If you like the insert style for the 1794 (which i prefer over the Platinum) but don't like the chrome... you are SOL.
    https://parts.toyotaofcoolsprings.c...rille-assembly-magnetic-gray-1g3-531010c040b1
    Color matched mirror caps: $81.92
    https://parts.toyotaofcoolsprings.com/toyota-tundra-accessories-mirror-caps-mirror-caps
    Front bumpers (with sensors): $221.44 for both... then you have to have them painted, so add another $100 give or take. Also add on the seals: $26.42 for both
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-end-cap-with-parking-sensor-521120c908/?c=aT04MTkzMDA1NSZyPTQ=
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-end-cap-with-parking-sensor-521130c908/?c=aT04MTkzMDA1NSZyPTQ=
    https://parts.toyotaofcoolsprings.c...nsion-seal-538820c060/?c=aT04MTkzMTUwNSZyPTE2
    https://parts.toyotaofcoolsprings.c...nsion-seal-538830c050/?c=aT04MTkzMTUwNSZyPTE2
    Rear bumpers (with sensors): $264.92 for both... again, you have to get them painted, so we will add another $100 give or take. Add the Side Reinforcements: $339.76 for both, 6 x Retainer Plate Clips: $6.42, 14 x Wheel Opening Molding Retainer Clips: $14.42, and 2 x Center Pillar Trim Clips: $2.44
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-end-cap-with-parking-sensors-521560c903/?c=aT04MTkzOTMyNSZyPTY=
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-end-cap-with-parking-sensor-521550c903/?c=aT04MTkzOTMzNSZyPTY=
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-side-reinforced-521540c030/?c=aT04MTkzOTMyNSZyPTk=
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-side-reinforced-521530c040/?c=aT04MTkzOTMyNSZyPTk=
    https://parts.toyotaofcoolsprings.c...plate-clip-9046804059/?c=aT04NTE5Njg1NSZyPTEw
    https://parts.toyotaofcoolsprings.c...heel-opening-molding-retainer-clip-9046707215
    https://parts.toyotaofcoolsprings.c...rim-clip-9046706165c0/?c=aT04MTkzNzE2NSZyPTEz
    Now if you want to black out your badges you have to buy all those as well... we will say the average price is $50 each (also, there are no options for OEM blacked out 1794 so again, you are SOL): 2 x Tundra: $100.00, 2 x 4x4: $100, 2 x "5.7liter IForce": $100... i think thats it for everything.
    Grand Total for: Handles, Mirror Caps, Front Bumpers, Rear Bumpers, Badges, Bulge, Surround, and Insert: Approximately $2091.74 depending on your body shop paint prices for the Front and Rear Bumpers.
    Now, there are a great many here that have used plastidip, paint / primer over chrome, etc. with varying degrees of success. Im just trying to find another option for those that don't have or want to spend almost $2000 if there are $100-$500 options. I can't get ANY printshop to paint over the chrome in my area. However, if i brought them raw ABS or metal parts, they would have no problem painting them. Im trying to find a way to do that.
    Not taking your comments personally, so please don't take my reply as an attack... just laying out my reasoning for doing what Im doing.
    :cheers:
  8. Sep 26, 2018 at 8:59 AM
    FoghornTX
    FoghornTX Proud American and Infidel since 1968
    Ft Worth, Texas
    2022 Camry XSE (Black w/blackout package)
    If someone was close to the DFW area, I'd trade my black 2018 CrewMax door handles for their chrome ones.
    dud13[OP] likes this.
  9. Sep 26, 2018 at 9:55 AM
    speckmon
    Thornton, CO
    I thought this was bout door handles, not the whole truck, but yeah obviously that's expensive. you're just SOL because you have a newer model and they have a ridiculous amount of parts on them.
    FWIW i painted mine myself. i bought a new Grill assembly off of rockauto.com because it comes in bare plastic, same for the mirror caps. paid $120. quality is OEM.
    for the handles i just scuffed them up good, used adhesion promoter, primer, base, then clear. and everything looks good enough. paid maybe $100 for paint from automotivetouchup.com
    doesn't look bad at all, but i'm an expert rattlecanner and have done this before. make a makeshift paint booth to control debris and you'll be fine. then after a few weeks wet sand, polish, wax and boom, done.
    don't cheap out or your truck will look like a Ford.
    Pudge likes this.
  10. Sep 26, 2018 at 10:08 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If Roman has your color available, I would just buy the color matched handles. Pretty much the same price as having them painted and you get to keep or sell your chrome ones. The handles take a lot of abuse. It's the only mod I've purchased for my truck that is purely for aesthetics.
    Inquiringone likes this.
  11. Sep 26, 2018 at 10:10 AM
    dud13
    LMAO! I had a Ford... you are right.
    It did start out as door handles, but morphed into this.... "mission creep" is the technical term. looking at rock auto now
  12. Sep 26, 2018 at 10:18 AM
    dud13
  13. Sep 26, 2018 at 4:13 PM
    dud13
    Update with Rock Auto prices:
    Color ready handles (can't buy all 4, you have to buy each individually): Toyota (Color Matched) $111.83, Rock Auto (Need Paint) $83.26
    W/Key 81299: x 1
    No/Key 81301: x 3
    Color ready bulge: Toyota (Color Matched) $193.82, Rock Auto (Need Paint) $174.79
    TO1231101
    Color ready surround: Toyota (Color Matched) $328.35, Rock Auto (Needs Paint) $180.79
    TO1200375
    Color ready mirror caps (you can't buy caps only on Rock Auto, this is the entire mirror assembly): Toyota (Color Matched) $81.92, Rock Auto (Needs Paint) $129.58
    TO1320340, TO1321340
    Color ready front bumpers (with sensors): Also add on the seals: $26.42 for both (can't find them on Rock Auto): Toyota (Needs Paint) $221.44, Rock Auto $125.58
    Bumpers: TO1004183, TO1004182
    Color ready rear bumpers: Add the 6 x Retainer Plate Clips: $6.42, 14 x Wheel Opening Molding Retainer Clips: $14.42, and 2 x Center Pillar Trim Clips: $2.44 (can't find them on Rock Auto) Bumpers: Toyota (Needs Paint) $264.92, Rock Auto (Needs Paint) $159.58; Reinforcements Toyota $339.76, Rock Auto $89.58
    Bumpers: TO1105130, TO1104130
    Reinforcements: TO1126100, TO1127100:
    https://parts.toyotaofcoolsprings.c...reinforced-521530c040/?c=aT04MTkzOTMyNSZyPTk=
    $2091.74 estimate for the "straight from Toyota" all in one bundle from earlier post.
    Using the best estimate on the above from Rock Auto is about: $1792.68 assuming about $500 to get all items painted if you bring them in all at once.
  14. Sep 26, 2018 at 4:48 PM
    Heatonrx
    Heatonrx New Member
    I bought a set of chrome door handles and mirror caps of Ebay for $50. I've done the bleach for two days changing it. Took off about 20%. Then I tried oven cleaner which doesn't touch it. Now I just did hydrogen peroxide mixed with muriatic acid 2:1. I read some posts it works. Kind of wish I primed and painted but I've committed to removing it.
  15. Sep 26, 2018 at 5:49 PM
    speckmon
    Thornton, CO
    You're a freak
    Inquiringone and dud13[OP] like this.
  16. Sep 26, 2018 at 5:56 PM
    dud13
    lol, im told you have to be to do what i do.
    Inquiringone and Heatonrx like this.
  17. Sep 26, 2018 at 7:16 PM
    Heatonrx
    Heatonrx New Member
    We have a winner!! Only a few hours. Don't mix muriatic acid and bleach, chorine gas will kill you. Check these out.
  18. Sep 26, 2018 at 7:58 PM
    dud13
    Was that the muriatic acid and peroxide?
    Care to detail?
    Pudge likes this.
  19. Sep 27, 2018 at 3:21 PM
    dud13
    Ok, I found a mix as well. It’s used as an enchant in electronics. I’d post a “How to” but I don’t want to be liable if you kill your neighbors dog or burn your driveway down. Use Google.
    It does work well though just like @Heatonrx pic shows. Here’s my test pieces after 20 min. You can see the chrome “flaking” off. Should take about an hour to hour and a half to complete.
    Heatonrx likes this.
  20. Sep 27, 2018 at 4:20 PM
    dud13
    1.5 hours of soak. About 75% of the chrome is gone from the larger piece of the handle. 95% of the chrome is gone from the smaller piece. Should be done in another 30-45 min.
  21. Sep 27, 2018 at 4:34 PM
    Heatonrx
    Heatonrx New Member
    I found it on Youtube. Was a video using bleach on some Datsun chrome. The comments below it discussed the mix.Looks similar to use since the muriatic acid is green.
    https://www.youtube.com/watch?v=jDpObLuJVeQ
  22. Sep 27, 2018 at 5:56 PM
    dud13
    2 1/2 hours soak. Rinse. Ready to paint.
    FU chrome. FU $2000. $25 in materials and we are cookin with crisco.
  23. Sep 27, 2018 at 6:10 PM
    Aron9000
    Aron9000 New Member
    Aaron
    I got a set of black front door handles and black mirror caps lying in my shed. Took them off and put chrome pieces on, didn't want my truck looking like a freaking work truck with black plastic crap all over it. Thinking of getting some sort of chrome mesh grill insert, not sure on that though.
    I don't get why everybody is so anti-chrome all the sudden. I swear 5-10 years ago, black trim=standard, chrome trim $1000 extra, buy next up trim level. Now days chrome trim standard, black or body color trim $1000 extra on next trim level.
    usmchawk, LiftMeUp and Thee_Oddball like this.
  24. Sep 27, 2018 at 6:57 PM
    dud13
    I like chrome on some trucks. I think it looks good in moderation on black. But I like color match and black on mine. I’m doing my door handles in MGM. The mirror caps black. The grill surround and bulge will be color match, and now that I can effectively remove the chrome from my 1794 grill the center will be black. Front end caps and center bumper will be MGM.
    Mostly it’s just a matter of taste. Some people like their truck a certain way, be it: rims, tires, chrome, plastidip, tonneau covers, level, lift, stock height, line-x... you get the point. Mod list goes on forever. Some people will never use the mods for what they are for. Pavement princess with lift, nitto’s, sliders, that will never see dirt etc... I don’t care, do what you like. You be you. If you aren’t hurting anyone don’t ever apologize for it.
    Thing is: I just spent $2000 on wheels and tires, tryin to save a few bucks... and with the amount of people de chroming one here I figured “what the hell” someone may find this info useful.
    :notsure:
    Mountun Goat, jewsNbrews and Boerseun like this.
  25. Sep 27, 2018 at 8:16 PM
    dud13
    2 coats of primer, 1st coat of MGM. One more coat of MGM, wet sand, and 3 coats of clear to do tomorrow and more wet sand in a couple days.
  26. Sep 27, 2018 at 8:25 PM
    Pudge
    CT
    Looking good!
    dud13[QUOTED][OP] likes this.
  27. Sep 27, 2018 at 10:40 PM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    Looks awesome. Where did you get the mgm paint? Thanks in advance .
  28. Sep 27, 2018 at 10:49 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yep, I did it. What a PITA!
    joonbug[QUOTED] likes this.
  29. Sep 28, 2018 at 4:23 AM
    dud13
    Amazon. Look up Duplicolor MGM. I’m using their primer, MGM, and clear coat. If you have a different color look up your paint code. 99% positive they have it.
    Ostrich and tinman10101[QUOTED] like this.
  30. Sep 29, 2018 at 2:05 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    @dud13 do you know how that chrome removal mix does on steel bumper end caps? I was wondering if the mixture does some kind of oxidation or chemical reaction to the steel under the chrome plating. In any case, thanks for this write up. I just might do this with my steel endcaps and color match my MGM if it proves worthy. Thank you in advance.
