Tow haul with big tires
Discussion in 'General Tundra Discussion' started by Ironside35, Sep 23, 2018.
  1. Sep 23, 2018 at 11:05 PM
    Ironside35
    Ironside35 [OP] New Member
    2011 tundra rock warrior
    7" lift on 35x12.50r22
    I have a 2011 Tundra Rock Warrior with7" lift on 35s. My question is, should I be running tow haul on with the bigger tires? And if I do will it save on the transmission on daily driving?
    JoshuaA likes this.
  2. Sep 23, 2018 at 11:51 PM
    Welcome from CO!!!
    The TH function will hold gears longer, so this will work in your situation so the transmission isn't always hunting for gears.
    The best thing is to really consider re-gearing.
    Pudge, Watt maker, 1UPPER and 3 others like this.
  3. Sep 23, 2018 at 11:56 PM
    Ironside35
    What gears would be good to go with? Maybe 4.56?
  4. Sep 23, 2018 at 11:57 PM
    4.88's
    Watt maker, 15whtrd and T-Rex266 like this.
  5. Sep 24, 2018 at 6:07 PM
    Ironside35
    Its wierd that you would say that. At a low speed its only 1 to 2 mph off on the speedo. I wonder if it has been regeared already.
  6. Sep 24, 2018 at 6:44 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Regearing has nothing to do with the speedo.
  7. Sep 24, 2018 at 6:47 PM
    Ironside35
    So how do know if it has been regeared or not?
  8. Sep 24, 2018 at 6:57 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Other than your butt dyno or asking the PO, not sure there’s a way to tell. Does your truck hunt for gears on the highway going uphill? The speedo won’t tell you because that just measures how fast your wheels are spinning. Putting on 35’s will increase rolling diameter by about 8%. So when you’re driving 50mph, your speedo will be off by 4mph. 2mph when you’re going 25. Regearing won’t change that.
  9. Sep 24, 2018 at 6:59 PM
    Ironside35
    Yep at 25 its 27
    joonbug likes this.
  10. Sep 24, 2018 at 7:00 PM
    Ironside35
    It does not hunt for a gear going up hills at all.
  11. Sep 24, 2018 at 7:03 PM
    Lift rear of truck, place rear axle on jack stands. Since we have an open differential, you may need to place one of the rear tires on the ground.
    Mark tire off ground, mark the driveshaft.
    Put truck in neutral, and spin the marked tire one full revolution.
    Did the driveshaft spin 4.3, 4.5, or 4.8 times around?
    Normally you would just count the ring/pinion teeth after removing the differential cover, but we have 3rd member designs, and that is a lot more involved.
    I doubt someone re-geared the truck.
    15whtrd and joonbug like this.
  12. Sep 24, 2018 at 7:04 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Honestly, it might not be obvious unless you’re towing or going up fairly steep at a pretty high speed. It is possible the PO regeared. But I would say more unlikely than likely. Most people who go to 37’s regear and most who go to 35’s don’t.
  13. Sep 24, 2018 at 7:05 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Damn you’re smart! :bowdown:
    15whtrd, Pudge and ColoradoTJ[QUOTED] like this.
  14. Sep 24, 2018 at 7:10 PM
    Ironside35
    Thanks guys that helps alot. I will jack it up this weekend.
    joonbug and ColoradoTJ like this.
  15. Sep 24, 2018 at 7:49 PM
    Generally as a whole, Tundra owners IQ are much higher than most. However, just use common sense when doing this procedure. I know someone that damn near killed himself attempting this very procedure.
    I have faith in you!
    joonbug and 15whtrd like this.
  16. Sep 24, 2018 at 8:19 PM
    Ironside35
    Will do. It will be easy to do. Esp when I build sandrails for a second job.
    ColoradoTJ likes this.
  17. Sep 24, 2018 at 8:24 PM
    See, I knew it!!!
  18. Sep 24, 2018 at 8:26 PM
    Ironside35
    Colorado Tj what did you know? Lol. Would you like to see a pic of one that I just built?
  19. Sep 24, 2018 at 8:35 PM
    TheFreshMouse
    TheFreshMouse learning as i go...
    Mouse
    18 CM MGM
    Pinstripes
    :popcorn:
  20. Sep 24, 2018 at 8:35 PM
    I knew you had a higher IQ.
    Hells yeah!!!
  21. Sep 24, 2018 at 8:37 PM
    Ironside35
  22. Sep 24, 2018 at 8:43 PM
    TheFreshMouse
    Mouse
    18 CM MGM
    Pinstripes
    @ColoradoTJ since we're on the topic of regearing, at what point should we start to consider a regear? i'm assuming tire size and added weight both tie into the equation?
    All I've done (so far) is went to 32.5" tire, would a regear be something i should be looking at? thinking about adding full skid plates, sliders, and bumpers in the future- maybe then it might be needed?:notsure:
    ColoradoTJ and Ironside35[OP] like this.
  23. Sep 24, 2018 at 8:52 PM
    Ironside35
    The Fresh Mouse what I have read in other threads is going past 35" tires you might want to regear.
  24. Sep 24, 2018 at 9:05 PM
    TheFreshMouse
    Mouse
    18 CM MGM
    Pinstripes
    that's what i thought but wouldn't 32" tires and any of the mentioned added weight also require the same?
  25. Sep 24, 2018 at 9:07 PM
    I would kill myself in that.
    When can I get a ride?
    TheFreshMouse likes this.
  26. Sep 24, 2018 at 9:08 PM
    Ironside35
    I test drove a lot of tundra's before i bot this one. They were all stock. The only thing that was different was the turning radius. Other than that, no change in power.
  27. Sep 24, 2018 at 9:11 PM
    Keith @dirtydeeds has been re-gearing to 4.88 gears to gain fuel economy.
    Give him a call. Great vendor to work with and is happy to offer any information your looking for.
  28. Sep 24, 2018 at 9:11 PM
    Ironside35
    When ever you want to Chris. Wife and I have 2. They run close to 100mph. The Tundra pulls them down the highway with no issues.
  29. Sep 24, 2018 at 9:12 PM
    Well if I’m ever up in the NW...you can bet I will hit you up!
  30. Sep 24, 2018 at 9:13 PM
    Ironside35
    For sure. I am down
