Remote start
Discussion in '2.5 Gen Tundras (2014-2021)' started by Whitetundra1054, Sep 23, 2018.
  1. Sep 23, 2018 at 5:33 AM
    Whitetundra1054
    Whitetundra1054 [OP] New Member
    2018 white tundra limited
    Wanting to add remote start to my 2018 crew max. I want to use the factory remote. Which one is everyone using? TIA.
  2. Sep 23, 2018 at 7:46 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Fortin Evo will allow you to use the OEM remote key...…...the range is rather limited though.
  3. Sep 23, 2018 at 8:58 PM
    bbrhm
    bbrhm USN, ΠΚΑ, Utah Football
    B
    North Denver, Colorado
    '18 1794
    The other option is 12 volt solutions.
  4. Sep 24, 2018 at 6:11 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I second this one, very quick install. You can setup the OEM remote with different sequences like lock 3x or lock, unlock, lock. The range is still the same as the OEM but you can get compatible extended range remotes if you need to. I have had mine a year and no problems what so ever, also if you get the firmware flasher, which you will need to change the settings like the remote sequences or some other options. Plus it's cheaper than the OEM option.
    sbbrown333 likes this.
