looking for suggestions
Discussion in '1st Gen Tundras (2000-2006)' started by lc69hunter, Sep 21, 2018.
  1. Sep 21, 2018 at 2:04 PM
    lc69hunter
    lc69hunter [OP] New Member
    Don
    2001 Black Tundra SR5
    gooseneck hitch, trailer brake
    Am ready to pull the trigger on a Relentless front bumper, and putting a winch on.
    In preparation, I am considering the Toytec Boss Coilovers for the front to add some lift and counter the extra weight.
    In the rear, here is my situation. The previous owner installed a gooseneck hitch, which I haven't used, and may never do so. However, he apparently did, because the rear springs have no spring and look flat as a pancake.
    Do I just do a add-a-leaf pack, do airbags, or both. Not a fan of blocks.
  2. Sep 21, 2018 at 8:55 PM
    I'd say maybe replace with a heavier set with an AAL? Airbags probably aren't needed unless you plan to tow/haul heavy weight.
  3. Sep 22, 2018 at 7:00 PM
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    If I remember right 1994-2000 dodge 1/2 tons pretty much had the same rear spring dimensions as tundras.
