My over-the-top Diff Breather mod...
Discussion in '2nd Gen Tundras (2007-2013)' started by scotch, Jun 11, 2016.
  1. Jun 11, 2016 at 1:01 PM
    scotch
    scotch [OP] New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    I had the morning free, so I went a little overboard on doing the diff breather mod...
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. Jul 16, 2016 at 1:19 PM
    Ardnut
    Ardnut New Member
    Not even sure if I fully understand what you did there.
    looks slick though.
    What benefit does that have over running a line up behind the tail light?
  3. Jul 16, 2016 at 2:59 PM
    Pretty cool vent block you built with a clean install. You sir, just gave me some ideas for my TJ build if I don't use bellows on everything (probably just use bellows).
    However, I give credit when due, and this is sweet!
    scotch[QUOTED][OP] and bandit like this.
  4. Jul 17, 2016 at 7:26 AM
    scotch
    Denver, CO
    2010 Tundra
    I just ran all the breathers to one location, and raised the breather higher up (by the brake booster)
    None... I had some free time and had the parts....
    Ardnut[QUOTED] likes this.
  5. Jul 17, 2016 at 10:25 AM
    Ardnut
    Ardnut New Member
    Gotchya. Very cool
    scotch[OP] likes this.
