Papasmurf's 07 4x4 LT Build Thread and now with more other stuff too!
Discussion in '2nd Gen Builds (2007-2013)' started by papasmurf, Jan 11, 2017.
  1. Sep 13, 2018 at 7:31 PM
    #301
    ryanjboutin
    ryanjboutin Weapons grade dickhead.
    Las Vegas, NV
    2013 Tacoma 4x4 with mid travel and 6 speeds.
    They got to him now. Lol
    Hi shipmate. @papasmurf
  2. Sep 17, 2018 at 10:22 AM
    #302
    papasmurf
    papasmurf [OP] Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    OK so update from last friday...
    @jc153 came over and gave me a hand and we made great progress. Im a little short on pics as i was trying to get through this step, but i can add more later
    First I finished off the cage install
    got the last two bed holes cut and place the cage in and marked the holes ontop of the frame for drilling..
    Then temp bolted the cage in. Im still waiting on the material to trim the hole edges.
    Out with the old shocks and leafs
    Im short on pics from here, but i cut off the old lower shock mounts and ground down and prepped the axle housing for the leaf spring perch, once that was done we mounted the new SUA leafs and shackles. temporarly mounting the up with the spring plates. and lowered the truck back down onto the wheels. So this is where it sit currently. The height is great and holy down travel.. when it was on the jack stands there was 16" of droop from the factory bump mount to the axle housing.
  3. Sep 17, 2018 at 10:29 AM
    #303
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  4. Sep 17, 2018 at 10:33 AM
    #304
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Looks like you'll be finished in time for the Sep 28 SGU trip
    papasmurf[OP] and dcsleeper408 like this.
  5. Sep 17, 2018 at 10:51 AM
    #305
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    bwhahaha yeah we shall see, i still have to do the following steps, and cant do shit this week cause i am watching my god kids all week while mom and dad are in alaska
    1. set pinion angle
    2. tack weld leaf spring perch
    3. cut shock pass through in bed
    4. cut out old upper shock mount and bump mount
    5. install new bump mount
    6. uninstall leafs
    7. strip leafs to the main leaf
    8. re-install the main leaf
    9. mount shocks
    10. tack weld in lower shock mounts
    11. cycle suspension
    12. figure out where i fu#ked something up
    13. fix whatever it was i fu$ked up
    14. cycle again for bump placement
    15. once everything is good to go strip everything off
    16. finish weld everything
    17. paint everything
    18. put leafs back together
    19. reinstall everything
    20. hope and pray nothing breaks
    831Tun, Sunnier, ColoradoTJ and 5 others like this.
  6. Sep 17, 2018 at 10:53 AM
    #306
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    just realized in those pics, the bed cage is not mounted, so when it is mounted you actually dont see the cage above the bed edge.. so just keep that in mind.. Ill take a new pic later
    smslavin and dcsleeper408 like this.
  7. Sep 17, 2018 at 11:00 AM
    #307
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    welp looks like sep 28... 2020 ;).
  8. Sep 17, 2018 at 11:01 AM
    #308
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    thats good it sits lower. I was kinda suprised how high it was sitting in the picture.
  9. Sep 17, 2018 at 11:02 AM
    #309
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i need a picture. not quite able to make the mental leap to visualize that. what does it bolt to?
    dcsleeper408 likes this.
  10. Sep 17, 2018 at 11:02 AM
    #310
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Yeah look at the second pic it shows better as far as where it sits when bolted in compared to the bed level
    dcsleeper408[QUOTED] likes this.
  11. Sep 17, 2018 at 11:03 AM
    #311
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    The frame... I’ll take more and post sorry for any confusion
  12. Sep 17, 2018 at 11:04 AM
    #312
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    as you should be :cool:
  13. Sep 17, 2018 at 11:36 AM
    #313
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    froggy78 and smslavin[QUOTED] like this.
  14. Sep 17, 2018 at 11:37 AM
    #314
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Pics definitely don’t do it justice. Sooo much droop and the height is perfect.
    I actually really enjoyed helping out, I learned a lot about the fab/work LT takes. Serious props to Bruce for taking this on. It’s a huge leap of faith to just start cutting shock hangers, etc. off your truck. Most people leave that stuff to the shops but Bruce isn’t scared, hahaha.
    Your truck is gonna be badass, I can’t wait to hit the trails and see your setup in action.
  15. Sep 17, 2018 at 11:45 AM
    #315
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Thanks brother for the help! always glad to dive head first and learn as we go... gotta take risks for a reward...
    its gonna be sweet just have a lot of work to do
  16. Sep 17, 2018 at 11:59 AM
    #316
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    multiple understatements in one sentence. good job. gold star for you.
    i can only imagine how that thing is going to run. permagrin territory for sure. hope i get to see it someday.
  17. Sep 17, 2018 at 12:12 PM
    #317
    TheBeast
    TheBeast The Beach
    looking mean
    831Tun, froggy78 and papasmurf[OP] like this.
  18. Sep 17, 2018 at 1:20 PM
    #318
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Bruce do you know the exact sizing specs on your u-bolts from the SUA kit?
  19. Sep 17, 2018 at 1:26 PM
    #319
    froggy78
    froggy78 Loco Moco Bastrd
    JP
    SF Bay Area
    1794 TRD
    secret
  20. Sep 17, 2018 at 1:27 PM
    #320
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    i dont, i might be able to find out, however i think i need longer ones, because the pack is custom and thicker than normal i96 packs, they are not long enough.
  21. Sep 17, 2018 at 1:37 PM
    #321
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Good job Bruce. Props for taking this project on yourself and everything else you’ve done.
  22. Sep 17, 2018 at 1:40 PM
    #322
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I’ve been having issues trying to get a ubolt flip to work. Almost there but I’m getting a small gap at the bottom of the axle housing which is causing the ubolt to not snug up.
    I grinder the seam down a bit to see if it would help. It brought the ubolt more snug but this was the best I can get.
    I should’ve just got an sua kit w/ ubolts. I ended up using an sua plate for the pack anyway.
  23. Sep 17, 2018 at 2:13 PM
    #323
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    831Tun and dcsleeper408 like this.
  24. Sep 17, 2018 at 2:17 PM
    #324
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    That’s pretty much what I am using. Just reverse.
    My current u bolt is 3.5” wide 5/8” thick.
    GodlessPro, joonbug and TheBeast like this.
  25. Sep 17, 2018 at 2:18 PM
    #325
    TheBeast
    TheBeast The Beach
    someone building something up in NorCal :spy::spy:
    Sunnier, 831Tun, joonbug and 2 others like this.
  26. Sep 17, 2018 at 2:20 PM
    #326
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    just trying to figure out a way we can do a Ubolt flip. almost got it just not sitting the way we would like.
    GodlessPro, 831Tun, joonbug and 2 others like this.
  27. Sep 17, 2018 at 2:42 PM
    #327
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    @papasmurf if you get the chance to find the size of sua ubolts can you send me the info please.
    GodlessPro and papasmurf[OP] like this.
  28. Sep 17, 2018 at 2:51 PM
    #328
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    yeah let me check with Joey @sdhq_offroad they sold me the kit...
  29. Sep 17, 2018 at 2:52 PM
    #329
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    Hey Bruce looks awesome. I don't know if this will help I ended up using Tim's @DMZ Mr. Beefy Spring plates and I got my U-bolts from Deaver's and told them I was using Tim's plates. Although I think Tim has the U-bolts as well.
    osidepunker and dcsleeper408 like this.
  30. Sep 17, 2018 at 2:54 PM
    #330
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    do you happen to know the size specs on em greg?
