Oh boy...I screwed up. I could use some advice
Discussion in '2.5 Gen Tundras (2014-2021)' started by kxshook, Sep 16, 2018.
  1. Sep 16, 2018 at 11:06 AM
    kxshook
    kxshook [OP] New Member
    Houston, TX.
    2017 SR5 CM MGM TSS 4WD
    I'm putting in a new USB charger to replace the drivers side cig port under the radio. Just as I was about to solder the connection my hand hit a screwdriver that was laying on the seat and sent the screwdriver down into into the dark abyss of the center console. To make matters worse, this was one of those micro screwdrivers (about 6 inches long). I've tried digging around with my hands but that thing is no where to be found.
    There's a plastic piece that sprawls across most of the space making it difficult for me to move my hands around. Can that plastic piece be removed or would it be easier to get one of those magnetic tip retrieval tools to see if I could fish it out? The plastic piece I'm talking about sits directly under the center console tray fascia.
    Any advice is much appreciated!
  2. Sep 16, 2018 at 11:12 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Are you referring to the center tray area around the shifter? That is very easy to remove and get access to.it doesn’t take but a few minutes to remove.
    831Tun likes this.
  3. Sep 16, 2018 at 11:18 AM
    1UPPER
    TEXAS
    Flux capacitor!
  4. Sep 16, 2018 at 11:19 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Telescoping magnet?
    ARES, Buildn, NewImprovedRon and 5 others like this.
  5. Sep 16, 2018 at 11:22 AM
    Twinky
    Twinky Keep the shinny side up!
    Kemah, Texas chillin on my ChrisCraft 480
    07 double cab work horse
    Stereo upgrades: -HU, Pioneer Mvh bs501 -Tweeters, Peerless(vifa) XT25SC90-04 1" Dual Ring Radiator s in custom pods. -Mids, Silver Flute W17RC38-04 6.5" Wool Cone Woofer. -Subwoofer, American Bass XR12. 2.3^3ft tuned @33-34 hz. -Tw Amp, Old School 2ch Sony. -Mids Amp, Old School Autotek Sx275. -Sub Amp, Old School Memphis 16-pr1.1000 -Zero gauge big 3. 0 and 4 gauge copper runs to amps.
    Pretty sure you can remove most of the center console parts without to much trouble.
    Shouldnt be anything to worry about.
  6. Sep 16, 2018 at 11:40 AM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    2nd that, if you have one. If not, by the time you go buy one you could have everything disassembled, and put back together. Even a kids magnet on a string might work for you.
    4x4_Angel and 831Tun[QUOTED] like this.
  7. Sep 16, 2018 at 11:47 AM
    boloson
    boloson New Member
  8. Sep 16, 2018 at 11:54 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Bubble gum on a stick. Worked in Guatemala, should work in USA.
    4x4_Angel likes this.
  9. Sep 16, 2018 at 12:03 PM
    kxshook
    Houston, TX.
    I'll give this a shot. Thanks!
  10. Sep 16, 2018 at 12:08 PM
    kxshook
    Houston, TX.
    BTW, this is the tray I'm talking about
  11. Sep 16, 2018 at 12:08 PM
    Twinky
    Those are handy so might as well get one.
    831Tun likes this.
  12. Sep 16, 2018 at 12:21 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I use one waaay too frequently.:anonymous:
  13. Sep 16, 2018 at 12:44 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Oh yeah, you just need a micro screwdriver to remove that.
  14. Sep 16, 2018 at 12:52 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  15. Sep 16, 2018 at 3:28 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    All jokes aside, best bet is start carefully taking things apart. Look up how to remove the whole console on YouTube, that's what I would do.
    I've lost plenty of small tools and bits of hardware into engine bays and the like, I normally consider them consumed and buy another.
  16. Sep 16, 2018 at 4:50 PM
    15whtrd
    15whtrd Mr. Blonde
    I always lose my 10 mm socket.
    GJXJ4545 and 4x4_Angel like this.
  17. Sep 16, 2018 at 5:05 PM
    boloson
    boloson New Member
    I think they sell socket kits & forget to include the 10mm because the manufacturers themselves cant find their 10mm sockets
  18. Sep 16, 2018 at 5:11 PM
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    Harbor freight sells a telescoping magnet with a flexible head. I dropped a screw down there the other day and managed to get it out with it. 06865F2B-CFD9-4CD3-9733-DF87BFAE9563.jpg
  19. Sep 17, 2018 at 3:19 AM
    jstchilln
    jstchilln New Member
    Larry
    Eastern Kansas
    2017 Tundra 4X4 SR5 Double Cab / TRD Off road Package
    TRD Pro Grille
    I just bought one of these using my 25% off coupon at Harbor Freight. I dont know how many times I wished I had one for a situation like this guys.
  20. Sep 17, 2018 at 4:21 AM
    timsp8
    NY
    I had a marble that somehow got in to the vents under the console that go to the rear floors. Could hear it rolling around. I tired to take the console apart but gave up. I just went to a country road, backed up as fast as it would go, and slammed on my brakes. Marble came out. Maybe if you can’t get to it, try to jar it loose by driving around.
    Or it might get deeper in there.
    Cause of this, I also found out the truck will only go about 10 mph in reverse.
    T-Rex266 and 15whtrd like this.
  21. Sep 17, 2018 at 6:31 AM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    ROTFLMFAO!!!!!
    You know you're old when you can remember manufacturers not including 1/2" sockets in their socket sets...;-)>
    B
