bed rail fire extinguisher mount?
Discussion in 'Recovery & Gear' started by smslavin, Aug 24, 2018.
  1. Aug 24, 2018 at 12:39 PM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i've been looking for a bed rail fire extinguisher mount. rago had one awhile back, which i didn't grab, but now no longer offer it. i'm willing to buy or cobble one together but i have no idea what kind of parts i night need for that.
    looking for some ideas.
  2. Aug 24, 2018 at 1:46 PM
    Vizsla
    Vizsla 2 = 2.5
    This is what I made for mine. It would be best to pick your extinguisher first. Once you know what extinguisher you want, I can help with sourcing brackets if needed.
  3. Aug 24, 2018 at 1:50 PM
    smslavin
    Hudson Valley
    Some stuff
    Rad. Thank you. Looking at the HG250r from H3R.
    Sas likes this.
  4. Aug 24, 2018 at 2:02 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I have a hg250... it comes with its own bracket but if you want a third strap you will have to get another or Amerex b417 bracket or equivalent and steal a strap off it. Just go to your local fire equipment supply or wherever services fire extinguishers.. they have what you need cheaper than ordering online I have found. The rail mount is simple fab.
    Sas and smslavin[QUOTED][OP] like this.
  5. Aug 24, 2018 at 2:12 PM
    Vizsla
    Vizsla 2 = 2.5
    Same extinguisher body as mine. I just combined 2 brackets, 1 definitely was not enough. Ordered brackets from Zoro.com. Few more pics.
    joonbug, blue16, aperezsh and 3 others like this.
  6. Aug 24, 2018 at 2:20 PM
    smslavin
    Hudson Valley
    Some stuff
    Thanks for the input guys.
    @Vizsla what did you use for the rail mounting? Looks like 3 pieces of flat bar and some bolts.
  7. Aug 24, 2018 at 2:21 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I think I saw a pic of one mounted in @GiantsFanDan's bed as well. Maybe he'll chime in.
  8. Aug 24, 2018 at 2:50 PM
    Vizsla
    Vizsla 2 = 2.5
    1” bar stock and steel plate. Home Depot or Lowe’s. I use a few different methods to attach to the bed rail, but in a rush just used 2 elevator bolts. Ground a flat on opposite sides till it was 1” and forgot about it.
    1” bar stock fits in the bed rails perfect. For light stuff I just weld a bolt through 3/16” bar stock and grind the head down. If you don’t it hits the rail attachment bolts. For heavy stuff like my bed bars I use 1/4” and just drill and tap it accordingly. Never felt good about how the available t-nuts fit, maybe I tried the wrong ones.
    DA8A9519-DFFA-44DB-B487-61C931C53690.jpg E608C106-D228-4DC0-A5F1-06AC6DECBDF8.jpg
    blue16, Sas, aperezsh and 1 other person like this.
  9. Aug 24, 2018 at 3:02 PM
    smslavin
    Hudson Valley
    Some stuff
    easy enough. thanks. :cheers:
  10. Aug 24, 2018 at 3:35 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
  11. Sep 14, 2018 at 12:13 AM
    Drew05
    Drew05 New Member
    GiantsFanDan[QUOTED] likes this.
  12. Sep 14, 2018 at 11:23 AM
    GiantsFanDan
