18LED HEADS INSTALL/depin turns qstn
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundramaniac, Sep 13, 2018.
  1. Sep 13, 2018 at 1:26 PM
    Tundramaniac
    Tundramaniac [OP] New Member
    14 tundra limited dc
    When you re-pin turn signal connector and you have 3 wires going to it-pink purple and white w/black stripe. Am I supposed to depin and not reconnect the purple and place pink and the stripe in the 2 outside openings? So f I leave all 3 in the Amber park light stays on with the drl strip. Basically with three pins in connector there's no way to turn the drl strip by itself, the Amber park light comes on with it. If anyone has an answer I sure appreciate it.
  2. Sep 13, 2018 at 1:51 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    This is what my turn signal connector pinning looks like after doing that upgrade.
