NEED HELP - Sensors flashing / no one can figure it out
Discussion in '2nd Gen Tundras (2007-2013)' started by Konger76, Jul 18, 2018.
  1. Jul 18, 2018 at 12:33 PM
    Konger76
    Konger76 [OP] New Member
    Anthony
    2014 Tundra TRD
    Hey guys -
    I have a 2014 Tundra TRD - my ABS and Traction lights are on and solid and 4LO and 4HI flash as soon as I start driving.
    In September this happened and was put in shop and it was a Rear Right Speed Sensor. It was replaced and all was good - light came off until.... March.
    Went back into the shop that replaced the speed sensor the first time and it was under warranty, so they got a new sensor and it did not fix the problem - lights still flashing.
    It has since been into 3 shops and no one can figure out what it is. One shop cleaned some dust under the sensor and it removed the flashing lights for half a day.
    One shop said wiring, another said maybe a wheel baring BUT know one knows for sure.
    I am hoping SOMEONE out there has dealt with this. Please help
  2. Jul 18, 2018 at 12:55 PM
    koditten
    Kirk
    Midland of the Mitten
    Sounds like a cut WSS wire. Check the wires that run across the top of the rear axle.
    NewImprovedRon likes this.
  3. Jul 23, 2018 at 9:19 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    CANBUS wiring is very thin and delicate. Just tugging on them, or them being weighted by mud or ice and snow can break the wiring inside the insulation causing an intermittent connection. This will oftentimes be resolved by replacing the faulty section of the wiring harness.
    treihing and NewImprovedRon like this.
  4. Jul 23, 2018 at 10:12 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    To get a wheel speed sensor fault, you’d have a harness failure, a failed sensor (probably unlikely with new sensor, unless they are aftermarket of questionable quality) or the reluctor ring within the wheel bearing is damaged.
    The trouble code description the shops are reading should indicate if the fault is electrical (open or shorted circuit in harness or sensor), or a signal issue (faulty sensor or reluctor ring in wheel bearing)
    They are able to monitor the wheel speeds with the scan tool while driving, which can be a big help if the code is related to signal, rather than circuit.
    That’s about all the help I can give diagnosing via the internet - hope it helps some.
  5. Jul 28, 2018 at 8:10 AM
    2016tundracrewmax13!
    2016tundracrewmax13! New Member
    Black sr5-trd
    custom headlights by eldobleu 6inch rough country lift 20x12 wheels with -44 offset and 35 inch tires full subwoofers all halogen lights replaced with leds fog lights led from retrofit.com rough country floor mats
    I am having a very similar issue. I took it to the dealer and the code read front passenger abs sensor. replaced the sensor and same errors. replaced the wiring from the abs sensor to the 1st connection before it goes into the box in the engine compartment and same issue. My abs sensor was grooved from something wearing on it. That is why i went with the replacement but immediately the error returned. i do have a 6 inch rough country lift and the dealer blamed the lift as the wheel bearing and abs sensor was place in the aftermarket raised knuckle. My lift guy seems to think it is the wheel bearing race coming out ... it is the only thing i have not tried (replacing the wheel bearing assembly and bearing)
    any updates on this thread will be helpful.
  6. Jul 28, 2018 at 8:26 AM
    koditten
    Kirk
    I hate shooting the parts cannon, but front wheel bearrings are easy on our trucks. I just did mine last month.
    Sas and Les7311 like this.
  7. Jul 30, 2018 at 8:07 AM
    Black sr5-trd
    I am planning to try the wheel bearing probally mid august. Hopefully will resolve the issue. Yes i also hate the dreaded parts cannon lol
  8. Sep 11, 2018 at 7:02 PM
    TundraDude772
    TundraDude772 Shake N’ Bake, Ricky Bobby
    Eric
    FL
    2010 & 2020 SR5
    2010 SR5 CrewMax Silver Sky Metallic 7” BDS/Fox 17x8.5 Method MR705 40x13.50 Toyo M/T Transfer Flow 46 gallon ICI Magnum front bumper PML Transmission Pan Hooke Road 18” bed rack Nature Nest Hard-Shell RTT Ironman 4x4 awning Coachbuilder upgrades SuperPro LCA Bushings Total Chaos UCA’s Energy rack bushings Moog LCA Cams 2020 SR5 Double Cab Voodoo Blue 40/20/40 Front Bench TRD Pro Grille TRD Pro headlights 17x9 Vision 351 285/70 Toyo A/T3 PML Transmission Pan RCI Skidplates eBay bumpers TRD rear sway bar
    Having a similar issue on my 2010 4wd. I changed a needle bearing in the front diff, got everything back together. now my 4-hi light flashes constantly. Ive already experienced a snapped ABS wire and the dash lights up like a tree, so it’s definitely not that. I’ve tried un plugging and re connecting the actuator on the transfer case, and the plug going to the front diff. I’ve tried tapping the actuator while turning 4wd switch (plus while driving forward, reverse, turning, neutral, everything). The only other thing I Haven’t checked are fuses, but I’m stumped. I’ve verified the truck is not turning in 4wd, but does clunk like it’s trying to engage every time I back out of the driveway. Anyone any input or suggestions??
